JUICEDMOTORSPORTS
Old 03-31-2012, 07:37 AM   #1
injector
injector's Avatar
Drives: LS3
Unhappy Minor oil leak + Traction light on
Hey all
Always been a reviewer and this is my first thread in this forum. I've started having some problems when installed the below listed items and need some pro advise.
1. Pfadt Sport Sway Bars
2. Drop Springs from PFADT
3. Pfadt Rear Trailing Arms
4. Pfadt Solid Subframe Bushings
5. Pfadt Poly Differential Mounts
6. Pfadt Camaro Control Arm Stiffeners
7. GM Performance Oil Pump
Can anybody point out reasons for why there is minor oil leak and traction light goes on from time to time. when I start racing and the light goes on, i tend to ignore til i turn the engine off and on again then the lights are off.
but i'm feed up and taking my car to the workshop today, but thought will drop a thread to have some hints where to start looking.
injector is offline   Reply With Quote
Old 03-31-2012, 09:11 AM   #2
ssmike
BliSSard has come!
ssmike's Avatar
Drives: '16 Camaro 2SS, '13 Equinox CRT
First, welcome to the Camaro 5 forums! Couple questions, when you race are you holding the traction control button down for at least 7 seconds to turn TC off, and where is the oil leak coming from?
Old 03-31-2012, 09:56 AM   #3
2012InfernoSS
2012InfernoSS's Avatar
Drives: 93GMC sierra stepside/2012 SS
Wellcome to C5!
Did you get an alignment after installing all the suspension goodies? My guess is the oil is leaking from the oilpan from when the oil pump was installed
2012InfernoSS is offline   Reply With Quote
Old 03-31-2012, 09:59 AM   #4
audrey_m
audrey_m's Avatar
Drives: 2010 2SS/RS
It's probably an oil pan leak. Nine had a leak and that landed up being the problem. Took it to the dealership and got it fixed. Good luck
audrey_m is offline   Reply With Quote
Old 03-31-2012, 11:58 AM   #5
injector
injector's Avatar
Drives: LS3
hey mike Thanks really learnt so much from here.. usually i don't turn the Traction off.. the leak runs down between the gearbox and the engine area... i can see the trail but couldn't determine the cause.
Old 03-31-2012, 11:59 AM   #6
injector
injector's Avatar
Drives: LS3
Originally Posted by 2012InfernoSS View Post
Wellcome to C5!
true that what i thought as well... might needed an alignment.. the car at the workshop checking it now.. will check suspension goodies
Old 03-31-2012, 12:10 PM   #7
v8
v8's Avatar
Drives: GT500 and 14 ZL1
There is a problem with the oil pans leaking on the V8s, its not rare, thats for sure
Gone but not forgotten:
1974 Corvette Stingray 454
1986 Z28
2009 Mustang GT convertible
2012 45th 2SS Vert
2013 ZL1 M6
v8 is offline   Reply With Quote
Light came on? White light across traction control jmitt85 5th Gen Camaro SS LS LT General Discussions 3 03-20-2011 12:14 PM
Group Buy!!! LED Headlight and Tail Light HALOS, Only $99 Each!!! Wes@Flashtech Exterior Parts & Accessories 51 09-27-2010 09:19 PM
Press Release: Shift Light for Camaro MTI Racing Kevin Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 8 05-04-2010 12:01 PM
KITT light installed and Thoughts ttexxan Cosmetics and Lighting Modification Discussions 3 04-27-2010 08:53 AM
Tire Monitoring System monevz28 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 7 11-22-2009 04:42 PM
