BORLA
View Poll Results: Best aftermarket heads for my mild cam ?
Texas Speed:...PRC Aftermarket LS3 250cc CNC Heads 17 56.67%
Lingenfelter:.....CNC Ported LS3 Cylinder Head 11.0 Compression 5 16.67%
Livernois:.........CNC Ported Stage 3 GM L92 Cylinder Heads 2 6.67%
Other:.............please explain your vote 6 20.00%
Voters: 30. You may not vote on this poll
Old 03-31-2012, 02:21 PM   #1
mike.nite
mike.nite's Avatar
Drives: 2011 2SS L99, 2010 LT RS
Help me pick the best aftermarket Heads
In combination with my new Cam I'd also get a set of new aftermarket heads. Since I just go for a very mild "stealth" cam I want to get the most out of my Cam/Heads combo.
My new cam: 218/229 .600"/.600" 117.5
So which of those heads will fit my cam best / will show the best gains?
Update: I just ditched the GMPP heads. According to 3 independent flow tests I found, the advertised numbers doesn't seem to be reality.
mike.nite is offline   Reply With Quote
Old 03-31-2012, 02:41 PM   #2
mike.nite
mike.nite's Avatar
Flow Specs (advertised):
LIFT..........INTAKE........EXHAUST
Texas Speed:
68ccs / 10.8:1 compression
.200............154............117
.300............221............170
.400............281............205
.500............325............225
.600............354............235
.650............358............240
.700............361............243
Lingenfelter
89ccs / 11.0:1 compression
.200............158.............116
.300............230.............161
.400............282.............201
.450............302.............213
.500............322.............220
.550............340.............226
.600............350.............231
.650............358.............234
.700............344.............237
Livernois
.100...........71.9...........51.8
.200..........157.5........105.3
.300..........220.4........154
.400..........263.4........196.2
.500..........308.3........223.1
.600..........346.6........232.5
.700..........357.8........237.2
.800..........359.9........245
Old 03-31-2012, 08:23 PM   #3
bucketobolts
bucketobolts's Avatar
Drives: 2010 2SS
I voted for the GMPP. Of the choices given they are most likely the best bang for the buck and with your cam you could probably have them milled for a bump in compression.
bucketobolts is offline   Reply With Quote
Old 03-31-2012, 09:11 PM   #4
mike.nite
mike.nite's Avatar
Yes the GMPP costs definately less than the others. The thing I just dont get is that according to the flow specs the GMPP heads seem to flow best - so why do the other heads cost more although they dont flow as good as the GMPPs?
Old 03-31-2012, 09:31 PM   #5
FIGRRL
aka Bubbles
FIGRRL's Avatar
Drives: 2010 Silver Ice Camaro 2SS/RS
I have the GMPP CNC heads on my car and had them flow tested before install.
Drive fast.
Live in the Chitown area? Ask me about C5G!
FIGRRL is offline   Reply With Quote
Old 03-31-2012, 09:35 PM   #6
Tampa Tuning
Drives: TAMPA TUNING FACEBOOK & INSTAGRAM
I voted for the GMPP. Of the choices given they are most likely the best bang for the buck .
your heads for flow great. A little porting to reduce flashing is a big bang for the buck.
I think you'll get tired of that cam fast and pay for labor to have a larger cam installed and another tune.
If you want "stealth" go FI and love the car.
Tampa Tuning is offline   Reply With Quote
Old 03-31-2012, 09:47 PM   #7
G8RAM
Drives: 2009.5 G8 GT
Take a look at Land Speed Performance / Street Smart Heads before you buy anything else. I own a set and they are going to be installed with an EPS 222/226 .597/.605 lift 115 LSA in a G8 GT Auto 6 Speed in a couple of weeks.
Many are making the mistake of buying LS3 heads with intake runners ported too much and loosing torque and power. Look at the intake runner sizes on Mast Med Bore, PRC 250CC Aftermarket, & Landspeed Street Smart II CNC heads and you can confirm what I'm talking about. The runner size is smaller to keep the air velocity up and still flow good CFM.
G8RAM is offline   Reply With Quote
Old 03-31-2012, 11:11 PM   #8
Fiftydriver
Fiftydriver's Avatar
Drives: 2010 Camaro 2SSRS RJT L99
Looks like the GMPP heads flow much better without the really aggressive lifts so to me I would think that would make life much easier on the entire valvetain.
Fiftydriver
2010 SSRS, RJTC, L99, Maggie 2300 SC, 3.4" pulley, Roto-Fab CAI, Dynatech Supermaxx LT headers, Dynatech High Flow cats, Corsa Cat back exhaust, Dual Elite Engineering catch can, MSD wires and Jannetty custom tune, JRE custom diff w/ posi mod, 3.91 LPE gears, Pfaht trailing arms, Pfaht trailing arm and Diff bushings, drop springs and sport sway bars front and back, Fesler dual guage pillar pod w/ AM Cobalt Boost and A/F guages.
More to come!!
Fiftydriver is offline   Reply With Quote
Old 04-01-2012, 06:54 AM   #9
FIGRRL
aka Bubbles
FIGRRL's Avatar
Also keep in mind the max lift on a GMPP CNC head is 550. After that you need to change the valve springs.... So take that into you figuring cost out.... I good set of valve spring could run you anywhere from 250 - 1000 plus install.
hope that helps!
P.S. Lingenfelter has patriot gold valve springs with a 650 max lift on sale cheaper then anyone else....
Drive fast.
Old 04-01-2012, 11:27 AM   #10
mike.nite
mike.nite's Avatar
Originally Posted by G8RAM View Post
"Many are making the mistake of buying LS3 heads with intake runners ported too much and loosing torque and power." ... "The runner size is smaller to keep the air velocity up and still flow good CFM."
Yes - this is what I like about the TSP PRC heads. They flow like the ported GM LS3 castings, but through a 12cc smaller than stock intake runner. This equals more velocity.
I just have two questions:
  • TSP claims they laid over the valve angle slightly which helps to get about .040" better than stock piston to valve clearance. Doesn't this new angle put more stress on other parts?
  • They are offering 60-68cc Chambers. Which number do I have to choose to get the most gains in combination with my mild cam?
Old 04-01-2012, 02:38 PM   #11
G8RAM
OP
I can answer your first question about the valve angle.
The improved valve angle provides better piston to valve clearance, allowing for larger cams.
Also the relocation of the valves offers better air flow.
Hope this helps.......
Old 04-01-2012, 03:39 PM   #12
mike.nite
mike.nite's Avatar
OP
Thanks for chiming in G8RAM - so the improved valve angle doesn't have any downsides? So not more risk for failures than with the stock valve angle?
Old 04-01-2012, 04:39 PM   #13
mike.nite
mike.nite's Avatar
bump:
Old 04-01-2012, 05:45 PM   #14
G8RAM
OP
If there is a downside to a better valve angle I don't know what it would be?
There are other after market heads that have been modified the same for sure.
TSP's PRC CNC ported heads VS Summit Racing CNC ported heads hunt Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 16 03-14-2012 07:41 AM
Opinions on aftermarket Cylinder Heads S3XPanther Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 20 12-17-2011 08:53 PM
New aftermarket LS3 heads. Ovenmitt Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 47 03-23-2011 06:56 AM
PRC LS7 Cylinder heads On A LS3/L99 Bore Nearing Productions! Jason 98 TA Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 15 12-01-2010 11:10 AM
World Warhawk LS1x / TEA Heads xssive99 V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment 0 11-19-2010 08:24 PM
