Emblempros
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Garage / Tools Discussions
Old 03-31-2012, 03:56 PM   #1
cadyshac
It's in the hole!
cadyshac's Avatar
Drives: 2011 2SS L99 SGM 2013 2SSRS LS3 BRM
Problems Using a Bendpak Lift
I have a 10,000 lb Bendpak lift. Tried to use it to raise my 2011 2SS today, no dice, not happening. The car sits so low that in is a pita to get the arms under the body of the car. I removed 1 spacer to lower the lifting pads on the lift arms, problem is the lift arms then would "contact" the body panels before the lift pads engaged the frame. Has anybody else encountered this and how did you get around it??
cadyshac is offline   Reply With Quote
Old 03-31-2012, 08:26 PM   #2
vroomapunk
[COTW 5/12/14]
vroomapunk's Avatar
Drives: 2012 CRT NF Cammed 2SS/RS
Most people drive the car on 2x4s. Not ideal but it will work
Old 03-31-2012, 10:22 PM   #3
2L82RUN
2L82RUN's Avatar
Drives: ABM SS/RS
I have the bendpak XPR-10acx. I too had the same trouble. I solved my issue by getting race ramps to pull up on. They lift the car 3" and allows just enough clearance to get the arms under the car with the small extensions installed. Worth every penny and they are light and don't scoot around when pulling on or off of them.
2L82RUN is offline   Reply With Quote
Old 03-31-2012, 10:41 PM   #4
mws444
mws444's Avatar
Drives: 701 RWHP Lingenfelter/Pedders Beast
I have a Mohawk but had the same issue on the rear lift arms. I just used a floor jack to lift the rear end enough to use the 4" spacers on the lift pads. The front worked fine they clear the rocker panel behind the front wheels by 1/4"
Lingenfelter forged balanced and blueprinted LS3, Maggie TVS 2300 LPE 9.5" Rearend 3.73,LPE dual disk clutch,10/14 rib belt drive,
MTI shifter,RPM Level VI,Corsa stainless cat back, Racing Brake Rotors, LPE calipers, LPE twin fuel pumps, American Racing long tube headers, GT9 cam Port and polished heads and an ADM majic tune.
701 RWHP,Fully Pedderized w/complete bushings and Sportsryder Supercar Remote resevior coilovers.
CCW 505t's Nitto Invo's and DR's
Beware of the LPE Brotherhood!
mws444 is offline   Reply With Quote
Old 04-02-2012, 08:28 PM   #5
cadyshac
It's in the hole!
cadyshac's Avatar
Ok, I may try some kind of ramp just to get the car up a couple of inches.
Old 04-03-2012, 09:49 PM   #6
IDEALG
Chevy's "Rumble" Best!
IDEALG's Avatar
Drives: 2015 ZL1 6 speed
Send a message via AIM to IDEALG
i just put my lift on the lowest setting push the arms under the car then take a 2x4 and cut it to the same size as the lift pad and place it on top of lift pad. works every time
IDEALG is offline   Reply With Quote
Old 04-03-2012, 11:31 PM   #7
yotaman96
yotaman96's Avatar
Drives: 2010 Camaro SS, 2000 Trans Am WS6
I use a small block of wood on each lift pad.
2010 IOM Camaro 2SS/RS manual trans
Magnacharged 2000 Trans Am WS6 manual trans
2015 Ram Crew Cab Cummins
yotaman96 is offline   Reply With Quote
Old 05-02-2012, 01:25 AM   #8
doomsdayjesus081
Drives: VR 2010 Camaro SS/RS
If nothing else do what the corvette guys I know do: jack the car up slide the arm into position, place hockey pucks on the lift pads.
doomsdayjesus081 is offline   Reply With Quote
Old 05-02-2012, 01:29 AM   #9
christianmotox
christianmotox's Avatar
Drives: ( . )( . )
I wish I had a lift.
christianmotox is offline   Reply With Quote
Old 06-07-2012, 02:06 PM   #10
NEGXXIS
NEGXXIS's Avatar
Drives: 2016 Camaro SS A8
I also have 10K Bendpak lift.
I made some ramps out of 2x12 boards, the ends are cut at a 45 degree angle, and then I slip in hockey pucks on the rear. works great for me
here is the only 2 pics I could find of my ramps
2016 Camaro SS A8 White
2004 Chevy 2500HD Diesel - 601 rwhp / 1089 rwtq
SOLD - 2010 Camaro SS - Featured in GM High Tech Performance and Camaro Now Magazines - http://www.superchevy.com/features/g...of-perfection/
NEGXXIS is offline   Reply With Quote
Old 09-10-2012, 10:29 PM   #11
CEE
CEE's Avatar
Drives: 2002 WS6 T/A; 2013 Camaro 2SS
Don't I know it. Did build the nice shop, but ran out of $$$!
CEE is offline   Reply With Quote
Asymmetric Lift Points for 2010 Camaro jmcbeth Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 3 07-30-2011 07:14 AM
1st and 2nd gear problems. 1SS 6M jnm2003 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 6 08-17-2010 02:06 PM
Long Problem(s) GM techs or someone needed here... xpanda305x Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 37 07-04-2010 03:00 PM
Problems from cutouts LS3_Man Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 8 06-05-2010 03:57 PM
Camshaft Basics Milk 1027 Wiki 1 12-09-2009 01:00 AM
