SDPC
Old 03-31-2012, 05:23 PM   #1
2kformula
Drives: 2012 Corvette Grand Sport
Installed a few mods today
It's pretty nice out today, finally, so I was able to install the CAI intake, rotofab W/W relocation reservoir, and ADM air scoop. All WITH OUT taking off my wheel!!!
I've had them in the garage for a few weeks, and wanted to do them all at once, so I was waiting for a friend to bring me my jack, and then barrow some jack stands...but I got tired of waiting and just did it on my slanted driveway w/o taking off the wheel. I removed the wheel well and had at it. The CAI intake and W/W were pretty easy, it was the air scoop that was a pain in the ASS! Though I wouldn't recommend this way if you have access to a jack and stands, it is possible to be done. Used a sharp box cutter and cut the piece off the plastic air break as needed, put the scoop in place. However, the horn bolt and nut caused an issue, the nut is either painted or welded on so I couldn't bolt up that brace. but should hold fine with the stock W/W bolt used on the inside of the air scoop.
2kformula is offline   Reply With Quote
Old 03-31-2012, 06:16 PM   #2
BowlingSS
Camaro Owner Since 1987
BowlingSS's Avatar
Drives: 2011 2SS/RS L99 RJT
I installed the same items. I did pull my wheel off. You do not remove the horn bolt. The scoop tab/bolt screws into that orn bolt if I remember right.
Bill
2011 Camaro 2SS/RS L99 RJT
CAI, Inc. Cold Air Induction;ADM Scoop
Rx Catch Can;Rx Breather;Roto-Fab Washer Container
VMax Ported RJT Throttle Body
XSPower Headers and XSPower 3" Exhaust System
Elite Engineering Tunnel Brace,
Gorilla Wheel Lock System; Bear Rotors, Hawk HPS
Tinted Windows 35%;EFILive Tune
BowlingSS is offline   Reply With Quote
Old 03-31-2012, 08:15 PM   #3
2kformula
yeah I used the same bolt, it was the nut that didn't come off, so I couldn't get the air scoop tab bolted in.
Old 03-31-2012, 08:25 PM   #4
BowlingSS
BowlingSS's Avatar
I just used the nut that was welded on.
Bill
Went to the strip today after new mods stikSS Dragstrip and Launch Techniques Discussion 61 02-17-2011 07:15 PM
Installed Kooks Headers & Dyno'd My L99 Today thesnoopster Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 34 01-08-2011 06:52 PM
Dealer installed mods? LS1owner 5th Gen Camaro SS LS LT General Discussions 2 08-15-2010 10:00 AM
I got my 3.73 Gears installed today!! Camaro21 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 33 07-15-2010 04:47 PM
