Old 03-31-2012, 07:15 PM   #1
rberns
rberns's Avatar
Drives: 2011 Camaro 2SS/RS
Solo performance catback advice
I just installed solo HF cats and it is amazing to hear the difference. My question in if I add solos cat back system will I notice much of a difference in sound? Will it be even louder?
Also, since the install, it seems my car has been sluggish. The fuel is 93octane, but it is 4 months old because of storage. Could that be my problem. I want to run this fuel out and put new fuel in and do a fuse pull, but I was curious if anyone else felt the same thing after installing HF cats.
2011 Camaro 2SS/RS, Circle D 3200, ADM Transmission Cooler, BTR Valvetrain, Cam Motion .621 .595 228/244 113+4, ARH 1 7/8, Cold Air Inductions, Katech C5R TC, Melling HV, BTR SLR lifters, Trunion Upgrade, LS2 Dampner, LS9 head gaskets, Bo White PTB, RX CC, GFX, Subs.
rberns is offline   Reply With Quote
Old 03-31-2012, 10:08 PM   #2
IndeedSS1
IndeedSS1's Avatar
Drives: 2010 Camaro SS LS3
It has to be the gas. Soon as I pulled out of the shop after having my SOLO cats installed I could tell a difference. The sound right now is probably optimal. I only replaced my catch because my stock muffler beffles were rattling. Don't get me wrong the SOLO cats and MachX were a great combo, but imo, their cats make the biggest difference.
She is only memory now.
IndeedSS1 is offline   Reply With Quote
Old 03-31-2012, 10:20 PM   #3
rberns
rberns's Avatar
I was waiting for you to post on this thread. Did you have your hf cats and catback system installed in the same day? The new cats sound good right now, but I am hoping solos cat back will give it more of a growl.
Old 03-31-2012, 11:03 PM   #4
TAPSHIFT
TAPSHIFT's Avatar
Drives: '11 IBM 2SS/RS '16 1GB Z51 ragtop
SOLO HI-FLOW CATS WITH MACH XL CATBACK/J-PIPES
Incase you haven't seen/heard this.....
TAPSHIFT is offline   Reply With Quote
Old 04-01-2012, 12:24 AM   #5
The SwiftChancelor
The SwiftChancelor's Avatar
Drives: SGM, 2011 2SS/RS, L99
I'm sure it would sound better with the Solo cat-back over stock. I don't store my car because I don't have this pleasure its my only car but can't you use stabil - a gas treatment you put in your tank when storing. I put it in my boat during winter when I had one. It still ran bad until I would burn up the old gas but it wasn't in storage just parked along the side of the house.
K&N air intake, Solo w/Jpipes axleback, SP 1 7/8 LT headers
The SwiftChancelor is offline   Reply With Quote
Old 04-01-2012, 02:00 AM   #6
rberns
rberns's Avatar
Hey Tapshift, its been awhile since I have last seen the video. I guess what i want to know is if the catback will make it even louder (which is what I am trying to accomplish). She already sounds good with the HF cats, but I guess I am looking for something just a little bit more so I was wondering if their catback will add more deeper/raspy noise. Also, does Solo Performance automatically adjust the J Pipes or do you have to adjust it yourself. If so, how do you adjust them?
SwiftChancelor, I did add stabil in november, but it still sluggish. I am thinking it is the fuel that has started to go bad.
Old 04-01-2012, 08:27 AM   #7
TAPSHIFT
TAPSHIFT's Avatar
SOLO EXHAUST
[QUOTE=rberns;4737631]Hey Tapshift, its been awhile since I have last seen the video. I guess what i want to know is if the catback will make it even louder (which is what I am trying to accomplish). She already sounds good with the HF cats, but I guess I am looking for something just a little bit more so I was wondering if their catback will add more deeper/raspy noise.
I had the Catback installed first, then the Hi-Flow cats later so I can't speak to the difference. I would think that the volume would go up due to the higher flow rate with the combination of both.
Also, does Solo Performance automatically adjust the J Pipes or do you have to adjust it yourself. If so, how do you adjust them?\
They are preset based on your vehicle. You can fine tune them by adjusting the end caps (in or out) which are clamped in place.
Old 04-01-2012, 11:04 AM   #8
IndeedSS1
IndeedSS1's Avatar
I did the HF cats long before the MachX. The problem is, after a while my stock mufflers baffles started rattling, so I had them cut off and a set of GMPP street added, then had the resonators removed, and finally went with the MachX. I liked the HF cats with the complete stock system and SOLO MachX best. I had to add J pipes later to kill the hiway drone.
There were enough variations between HF and stock versus HF and MachX that it's tough to give an accurate comparision.
SOLO Performance Camaro CONVERTIBLE Axle-Back Exhaust Kit GOINGSOLO2 V8 Bolt-Ons & Tunes 26 09-18-2012 01:15 PM
SOLO Performance Needs a Convertible To Make Catback and Axle Back Exhaust GOINGSOLO2 Camaro Convertible Forum 118 09-16-2011 07:51 PM
ARK Performance v6/v8 DTS Catback Memorial Day Sale Blowout ARK Performance V8 Bolt-Ons & Tunes 3 05-02-2011 08:19 PM
Solo Performance resonators review ssmike Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 5 10-03-2010 04:33 PM
SOLO Performance Camaro Exhaust Sound Clips Compilation GOINGSOLO2 V8 Bolt-Ons & Tunes 29 04-11-2010 09:11 PM
