Solo Performance
Old 03-31-2012, 11:10 PM   #1
dekan513
chevy pride
dekan513's Avatar
Drives: 2ss/rs
3.91 gear question
if i go with one just wondering what the car run rpm wise at say 65 mph i dont want to be driving and it running 3500 rpm in 6 th gear anyone have a video of them driving their car with a gear ratio around this size
check out ky speeds fb page https://www.facebook.com/kyspeed
dekan513 is offline   Reply With Quote
Old 03-31-2012, 11:41 PM   #2
rick john
Drives: 2010 camaro ss
DEKAN,I just got my 3.91 installed last week and your 3.91 will only increase your r.p.m's by about 200 rpm's... believe me do it, you won't be disappointed. in sixth gear you'll go from cruising at 1700 or 1800 to 2000... trust me worth every bit
rick john is offline   Reply With Quote
Old 04-01-2012, 10:55 AM   #3
dekan513
chevy pride
dekan513's Avatar
Drives: 2ss/rs
sounds like a happy camper to me i think i may do it did u do lpe or whatever they r and if u dont mind pm how much things costed for complete kit
Old 04-01-2012, 11:01 AM   #4
bmorecam
I used to turn 2k rpm doing 70mph, now I am right under 2500 rpm. I have a V6 tho.. just remember that low gears are a low rpm mover. Don't expect to see a big difference in the higher rpm.
Old 04-01-2012, 01:22 PM   #5
UCI CamaroFan
Zot!
UCI CamaroFan's Avatar
Drives: Toyota 4Runner
I don't want to start another thread on this same topic, so I will ask my question here too. Do 3.91 gears with a supercharger (with maybe around 500 rwhp) need any other suspension mods to keep from breaking? How is traction with this combination?
UCI CamaroFan is offline   Reply With Quote
Old 04-01-2012, 01:48 PM   #6
Bad70supreme
Bad70supreme's Avatar
Drives: 2010 aqua blue SS/RS M6
These cars need suspension mods even when stock! The gears will make traction worse to a point, you need some good rubber out back to really make it stick with or without suspension work. Either way gears would be a great upgrade, I plan on doing 3.91s at some point also. You will feel a huge difference in the butt dyno, almost like you added a 100ft lbs of torque!
10.91 at 122 H/C stock block N/A
Bad70supreme is offline   Reply With Quote
Old 04-01-2012, 07:24 PM   #7
NinoSS
Drives: 2SS/RS CGM LS3
I was always under the impression that gears make a car faster period. There are some here that say they slow you down on the top end? I would like to see before and after 1/4 mile runs in the same car (similar conditions) to see how they really work in these cars. I think I am ready...
Convince me...
SOLD Vengeance stage I cam (442rwhp/412rwtq) / CAI intake w/ADM race scoop / Dynatech LT's / ATI udp / JRE tuned / Eaton Posi LPE-JRE 3.91's / L99 Corsa / Whiteline Sways & Bushings / UMI Trailing Arms & Toe Rods / ZL1 wheels / NT05 275/315
NinoSS is offline   Reply With Quote
Old 04-01-2012, 08:49 PM   #8
Big Daddy Kane
Big Daddy Kane's Avatar
Drives: Red 1SS
I know with 3.91 gears and a supercharger, my car doesn't get traction. But thats with street tires. I love the 3.91. Not too steep in my opinion. I actually think the 3.73 would be a waste.
Kooks LT Headers/catback exhaust, E-force supercharger, JRE fuel line upgrade, JRE differential, 3.91 LPE gears, Roto-fab intake, JRE tune, DSS Carbon Fiber driveshaft, MGW shifter, Hotchkis chassis braces
Big Daddy Kane is offline   Reply With Quote
Old 04-01-2012, 08:59 PM   #9
UCI CamaroFan
Zot!
How would this be corrected? With drag radials?
Old 04-02-2012, 08:37 AM   #10
flht99b
flht99b's Avatar
Drives: 2010 Camaro 2SS/RS RJT
I installed AAM 3.70's in my LS3 M6 trans car and after the speedo re-calibration turn 2,000 rpms at 80mph in 6th. The 3.91's should turn another 175 to 200 rpm at 80mph.
Ed M.
RJT 2SS/RS, AAM 3.70's, MTI Sway Bars, Shifter & SS brake lines, ZLI calipers & rotors, BMR Trailing & Toe Arms, full rear cradle & diff bushings, Pedders XA's, Camber/Toe eccentrics, Radius arm inserts, ZL1 Brembo Brake pads, GTO clutch reservoir, LS9 cam, Comp Cam valve springs, Melling 10296 oil pump, CR 5 timing chain, LS2 damper, CAI Cold Air Induction, ARH LT headers w/HF cats, GMPP touring axle back, Elite Engineering Catch Can, Forgeline 20x9.5 & 20x11 DS3 wheels w/Vredestein 275/40/20 & 315/35/20 tires, '11 Convertible spoiler, Lloyd "SS" Floor Mats, GM Camaro Trunk Mat
flht99b is offline   Reply With Quote
Old 04-02-2012, 09:18 AM   #11
Slickcas
Drives: 12' 2SS/RS LS3 IBM
With my new 3.91's I just took the car out and at 2,000 rpm I was running 75mph with the stock 3.45's I was going 81mph at 2,000 rpm. So not a big change and you will be under 2k if you cruse ar 70 or so on the interstate like I do(Illinois 65 is speed limit) But man the car feels so much better.
Slickcas is offline   Reply With Quote
Old 04-02-2012, 09:56 AM   #12
NinoSS
I would like to see two M6 cars with otherwise similar power, one with .391's and the other with .345's race from a roll. This way you could definitively see the difference the gears make.
Old 04-03-2012, 05:44 PM   #13
swiftkart
swiftkart's Avatar
Drives: 2010 SS/RS LS3 M6
When the new 1LE (3.91 Gear) comes out you will be able to see that or read about it in the mags.
swiftkart is offline   Reply With Quote
Old 04-03-2012, 06:52 PM   #14
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
Everyone in here needs to Google "MPH gear calculator"
Convince me...
It's amazing how misunderstood gears are on here.
The easiest way to describe what gears do is imagine two cars with the exact same amount of power racing each other. One can only use gears 1-5 and the other can only use gears 2-6. Obviously if the both cars can get traction then the car that can use 1-5 will win. If traction is a hug problem, then the 2-6 car will win. Now this is an exaggerated gear difference, this example would be like the comparing 3.45 gears to 2.37 gears.
The best way to choose your gear for racing down the 1/4 mile is figure out what mph you want to cross the traps at and choose a gear that will get you there right before your RPM redline.
SUX2BU is offline   Reply With Quote
Top Gear host Richard Hammond to get own car show on BBC America. Apex Motorsports Off-topic Discussions 11 07-26-2011 11:04 PM
Camaro on Top Gear chewy4ce 5th Gen Camaro SS LS LT General Discussions 234 03-22-2010 03:14 AM
Track / Gear question? 2SuperSport Dragstrip and Launch Techniques Discussion 9 02-24-2010 07:25 PM
Rear End Gear Question Badger V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 8 01-09-2010 01:11 PM
Question about double clutching Muscle Master General Automotive + Other Cars Discussion 4 02-05-2009 09:27 PM
