Old 04-01-2012, 09:35 AM   #1
2012REDSS
Drives: 2012 Camaro SS
160 degree Tstat question
If I'm running a ud pulley would a 160 degree Tstat be worth puttin in? Next time I go to the dyno I'm going to have the fans programmed to come on sooner but I've heard this Tstat does nothing? Advice?
2012REDSS is offline   Reply With Quote
Old 04-01-2012, 10:14 AM   #2
Fiftydriver
Fiftydriver's Avatar
Drives: 2010 Camaro 2SSRS RJT L99
I have been told by some top tuners not to use them as these engines are designed to run at the warmer temps, take that for what its worth.
Fiftydriver
2010 SSRS, RJTC, L99, Maggie 2300 SC, 3.4" pulley, Roto-Fab CAI, Dynatech Supermaxx LT headers, Dynatech High Flow cats, Corsa Cat back exhaust, Dual Elite Engineering catch can, MSD wires and Jannetty custom tune, JRE custom diff w/ posi mod, 3.91 LPE gears, Pfaht trailing arms, Pfaht trailing arm and Diff bushings, drop springs and sport sway bars front and back, Fesler dual guage pillar pod w/ AM Cobalt Boost and A/F guages.
More to come!!
Fiftydriver is offline   Reply With Quote
Old 04-01-2012, 10:16 AM   #3
The SwiftChancelor
The SwiftChancelor's Avatar
Drives: SGM, 2011 2SS/RS, L99
I've heard the same, it does nothing. What I've been told by mechanics is that its possible to be more of a problem than helpful.
K&N air intake, Solo w/Jpipes axleback, SP 1 7/8 LT headers
The SwiftChancelor is offline   Reply With Quote
Old 04-01-2012, 11:15 AM   #4
2012REDSS
I've read to where the LS engines like the higher temps but I was curious with the ud pulley and slower water pump rotation would it put it back to the normal operation temps or be a headache. 2 for no and 1 lsx doc for yes. Other opinions?
Old 04-01-2012, 11:25 AM   #5
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
LOL, I put a 160 degree in ever LSx car I have ever owned and built, worth every penny! I've been working on these motors for about 13 years.
Motors running 'higher temps is good for emissions and that's it. Why do you think people let they cars cool off between runs at the track and get better times? Following you guys' logic you car should get faster the more it gets hot lapped and heat soaked.
SUX2BU is offline   Reply With Quote
Old 04-01-2012, 11:48 AM   #6
VR Baron
SoCal Camaro5 Race Team
VR Baron's Avatar
Drives: 2012 VR 2SS RS M6
Originally Posted by The LSX Dr. View Post
I have the same set up on my Silverado with no problems. With the combination of the underdrive pulley and lower temp t-stat it puts the engine in the optimum operating temp. Keep in mind there are variables on what the climate is where you live.
With a 160° T-stat the engine will typically run in the mid 180°s.
The stock T-stat is rated at 186°. The engine will run a bit over 200°. There is the ability to fine tune operating temperature with fan settings.
Told by all tuners aluminum engines run best 190-205 for best power,so yeah set fans to be on 185-200 or so as stat will run in that range anyway. My old ls1 ran right at 190(fan 1) and 200(fan 2). was good for 5 hp
Mods: Magnaflow 3" comp catback/Rotofab CAI/Apex Scoop/VMax T/B/ G.M. Blade Spoiler/SLP Splitter/ Forgestar cf10 wheels & Michelin Super Sport tires/JBA Shorty Headers,HiFlow cats & tune/ Pedders Supercar coilovers and Pedders 27mm/32mm sway bars /BMR cradle bushings, toe links and trailing arms/Stage 1 cam-445/430 RW HP/TQ
VR Baron is offline   Reply With Quote
Old 04-01-2012, 02:17 PM   #7
IndeedSS1
IndeedSS1's Avatar
Drives: 2010 Camaro SS LS3
http://performanceunlimited.com/cobr...hermostat.html
Years ago I ran across the above link. Near the bottom of the page was the reason I've never ran a thermostat colder than 180 (stock on my Impala SS was 195). But my cars have always been high mileage daily drivers. Being in the mid west, during the winter, even the 180 wouldn't allow the cabin to get warm even after my 26 mile drive to work.
She is only memory now.
IndeedSS1 is offline   Reply With Quote
Old 04-01-2012, 03:56 PM   #8
2012REDSS
I read your link and it makes a good arguement and I didnt consider this until I did the UD pulley and noticed it runs a lil bit warmer and its going to get real hot here in NC pretty soon. I figure for 30 bucks cant hurt.
Old 04-01-2012, 04:00 PM   #9
formare
Suspension by Pedders
formare's Avatar
Drives: Synergy Edition 13.71@102 1.95 60'
What about your ring gap? Aren't you running your rings at a larger gap at a lower temperature? Seems like a bad idea.
Alos, heat soak is more about the intake temps not the block temps, no?
My first Love. She was called "Miss Carriage" (still cry when I think about her)
383, Muncie 4 speed, custom linkage mated to hurst short throw shifter.
formare is offline   Reply With Quote
Old 04-01-2012, 04:43 PM   #10
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
What most people don't understand is that you run a 160 degree thermostat so your car runs at 175-185 degrees.
A 160 degree thermostat
WILL NOT
make your car run at 160 degrees.
It means the thermostat is closed until 160 degrees. At 160 degrees the thermostat begins to slowly open and isn't fully open until about 185 degrees (put one in a pot of boiling water and watch it work, it's actually pretty cool).
The absolute coolest my car runs is maybe 177ish and the hottest it runs is about 186ish.
Reading that article it looks like even more of a reason to run a 160 degree thermostat. But then again, it also looks like they don't understand how a thermostat works.
That "magic" number lies in the 175-180 degree range, which requires a 180 degree thermostat..The all too commonly used 160 degree thermostat is way too low to be considered for performance or engine longevity.
Like I said earlier a 160 degree will put you temps in the 175-185 degree range. Exactly where their graph says is the best.
Old 04-01-2012, 04:48 PM   #11
BLACK10
BLACK10's Avatar
How can any tuner say that running an LS motor at 185* is bad? Lol
Thats rediculas!
Old 04-01-2012, 04:54 PM   #12
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
Thats rediculas!
Those must be some really good tuners!
My tuner puts a 160 degree thermostat in EVERY car. His personal 5th gen runs 9s in the 1/4 and he is shooting for mid 8s this year.
Old 04-01-2012, 06:44 PM   #13
2012REDSS
Ok SUX2BU and LSX doc sold me. 160 tstat ordered. Thanks for all the opinions and such.
Old 04-01-2012, 07:19 PM   #14
IndeedSS1
IndeedSS1's Avatar
http://www.camaro5.com/forums/showpo...8&postcount=23
New member, hi! Question about the GFX package... TheDayday New Member Introductions 5 04-24-2011 02:32 PM
stereo question bigted83 Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 2 04-07-2011 04:56 PM
Question about tire sizes Jram1588 Wheels and Tires Talk Sponsored by The Tire Rack 9 07-17-2010 07:27 AM
Custom wheel offset question ... Bowtie Junkman Wheels and Tires Talk Sponsored by The Tire Rack 4 04-23-2010 05:16 PM
Question Involving 4.10 gears & Bushings Deric884 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 1 02-13-2010 06:53 AM
