Emblempros
Old 04-01-2012, 10:58 AM   #1
ULTRAZLS1
ULTRAZLS1's Avatar
Drives: 14 Silverado LTZ Z71, 16 Camaro SS
Strange whistling noise
After my H/C install I am noticing a strange whistling noice that sounds like its at the rear of the car.
It is very faint and it doesnt always happen. It almost sounds like a tiny little turbocharger spooling up or something.
What is this? Fuel pump? Im not sure.
Black 2016 1SS A8 NPP
Drag Pack, CAI, Headers, Mamo Ported MSD Intake, Pray Ported TB, Shrader RSD, E85
Best ET- 10.85
Best Trap- 125.39
ULTRAZLS1 is offline   Reply With Quote
Old 04-01-2012, 12:15 PM   #2
Bad70supreme
Bad70supreme's Avatar
Drives: 2010 aqua blue SS/RS M6
Omg... Not you too! I have this stupid whine noise but from the front of my car after the cam change I took it to the dealer and he said it seems like a pulley or alternator and of course right after I do my cam! Check your trans fluid, maybe they lost some fluid with the line out and forgot to replace it. This happen to me, was not much but it did loose some.
10.91 at 122 H/C stock block N/A
Bad70supreme is offline   Reply With Quote
Old 04-01-2012, 02:10 PM   #3
MikeOD
Drives: 2010 M6 2SS
When does it happen?
2010 Camaro SS M6. Heads/Cam/Intake/Headers/Exhaust/Suspension
MikeOD is offline   Reply With Quote
Old 04-01-2012, 02:41 PM   #4
ULTRAZLS1
ULTRAZLS1's Avatar
Happens in the first couple gears with gradual acceleration. The sound comes in at about 2k rpm and steadily increases in pitch (like a small turbo winding up is how i can describe it) until about 3000 rpm where it then goes away.
I havent noticed it cruising...just when going up through the gears at moderate throttle.
It sounds like it is toward the rear...but you know how that goes...it is hard to tell exactly where sounds are coming from sometimes. Especially if they are faint like this one.
As bad70supreme said...and I have read it elsewhere...this could possibly be the belt...and I did change to a different tensioner and belt.
Any other ideas?
Best ET- 10.85
Best Trap- 125.39
Old 04-01-2012, 03:37 PM   #5
MikeOD
Drives: 2010 M6 2SS
I'm running the same tensioner and belt as you as far as I know, and I don't have any noise like that. I don't know what it could be. I can't hear much of my car other than the exhaust though haha.
Old 04-01-2012, 04:13 PM   #6
AG454
I am not "Fast & Furious"
AG454's Avatar
Drives: 2010 Camaro LSX454 1LE
Maybe the tensioner is cranked to tight, check to see if there is a little play in the belt. The Katech tensioner should be torqued to 25 ft lbs, then tightend down.
The day I take a bend too fast
Judgement that could be my last
I'll be wiped right off the slate
Don't wait up 'cause I'll be late, I'll be late
AG454 is offline   Reply With Quote
Old 04-01-2012, 08:06 PM   #7
Bad70supreme
Sounds just like what i am going though. I have stock balancer and did not change anything other then the cam, gaskets and bolts. This is strange we both are dealing with this, I have heard there are problems with the air conditioner making this noise as well! I would love to figure it out, I plan on removing the belts and running the engine and see if it stops. Can you hear it when you are sitting still and just rev the engine a bit, I can.
Old 04-01-2012, 08:30 PM   #8
MikeOD
Drives: 2010 M6 2SS
I've also found that the FAST 102 just makes it louder under the hood...it's got basically none of the noise cancellation properties that the stock manifold has.
Old 04-02-2012, 11:37 AM   #9
ULTRAZLS1
ULTRAZLS1's Avatar
Still not sure yet guys.
I am going to look into it tomorrow. I have to work tonight so today is not a good day.
I will figure this out soon enough.
Bad70...let me know if you figure anything out.
Best ET- 10.85
Best Trap- 125.39
Old 04-02-2012, 07:03 PM   #10
AG454
AG454's Avatar
I thought of one thing you may check. The FAST manifold has a small vacuum port in the back that needs to be capped.It is next to the big port that is used for the brake booster.
Old 04-03-2012, 12:55 PM   #11
ULTRAZLS1
ULTRAZLS1's Avatar
I cant even get my hand in their or see it to check.
Hmmm...I wouldnt think they would leave that open.
Best ET- 10.85
Best Trap- 125.39
Old 12-07-2012, 01:45 AM   #12
victorious.legion
Drives: SS
i have this noise as well
victorious.legion is offline   Reply With Quote
Old 12-07-2012, 01:46 AM   #13
victorious.legion
Drives: SS
did you guys discover anything?
V6 Clutch making strange noise help!! NXC1978 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 2 04-30-2010 12:35 PM
Different noise from Dash (not the Heater Core noise) ColdCamaroSS Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 2 04-02-2010 09:49 AM
Whistling noise when drivers window is down? victoryred1ss Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 7 03-26-2010 03:07 PM
strange popping noise from exhaust bbossman Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 7 10-14-2009 12:21 PM
strange exhaust noise! bbossman Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 0 10-13-2009 12:52 PM
