HURST
Old 04-02-2012, 11:29 PM   #43
Fraxum
Fraxum's Avatar
Drives: 2016 SS M6
Originally Posted by GEEo View Post
I just reliezed that. Lol. My apologies.
I know that the 1LE is not the Z28 or ZL1 or SS. But I wus just really hopping that the 1LE would be the car that would have the Recaro Seat stripped down interior, light weght, and Track Built suspension.
I guess the 1LE is not what I expected it to be.
No worries. It will have the last thing you mentioned and it will also have a number of other track upgrades. Looks good to me for the price.
But that Track Animal you are describing is what the Z28 faithful are hoping for. Not sure about the stripped down interior. That is an easy DIY. I saw somewhere else the Camaro front seats are incredibly heavy.
That lighter Camaro is coming later. Too expensive to do much with this one me thinks.
M6, Pray Ported TB and MSD, E85, LTs, cats, Rotofab Dry, BMR Trailing Arms
Old 04-02-2012, 11:33 PM   #44
2cnd chance
Too Many Great Choices
2cnd chance's Avatar
Drives: Grand Sport/Z07
Sorry I meant the Z28 section. Taking the car and doing some personalizing is part of the excitement. I listed my plans above.
And Fraxum I'm with you on price it's part of the reason I won't buy a ZL1. That and I want my Camaro to be NA.
2cnd chance is offline   Reply With Quote
Old 04-02-2012, 11:34 PM   #45
GEEo
OKCamaros
GEEo's Avatar
Drives: 4 banger Diesel
Ohh yea the stock seat are very heavy.
I guess we'll just have wait for the next Version of the Camaro. hopefully it's the track monster were hopping for. I dont really care what's its gunna get called but if it's like a GT3 RS version Camaro I would be interested.
Old 04-03-2012, 12:32 AM   #46
Bad@ssCamaro
Rogers' Rocks :-)
Bad@ssCamaro's Avatar
Drives: 2015 1SS/1LE
Does anybody know the exact weight for each seat?
2015 CRT 1SS/1LE RS/Recaro's/NPP/Nav/Rear vision pkg./BA speaker upgrade.
ARH 1 7/8 headers, CAI, BMR 1.25 drop springs, JPSS Billet Bushings, Peddars Cradle Bushings, DSS driveshaft ...421 whp...so far.
Old 04-03-2012, 10:53 AM   #47
2cnd chance
I dont but that's a good question. They obviously are much more than most thought they'd be. No wonder why they use a lift to install them at the factory. Seems getting a 1LE down to Mustang GT weight is possible with a few changes.
Old 04-03-2012, 12:12 PM   #48
LOWDOWN
Downright Upright
Drives: Daily
Not to question anyone's stats or intent, but here's a listing of GEN-FOUR CAMARO components, throughout the car:
http://www.lt1engines.com/tech/camar...f-body-weight/
Driver's 6-way Power Leather Seat = 42 lb.
Passanger's non-powered seat = 34lb.
Passanger Air Bag = 17 lb. (includes bracket)
Driver's Air Bag = 10 lb. (which is likely the weight of the seat bags)
So, removing TWO 6-way Seats (from a Gen-5) that contain TWO Air Bags is gonna total a bit over 100 total, imho. Add back the weight of the replacements (and their tracks/adjusters/adaptors), and you have a net weight loss of (maybe) 50-70 lb... One-piece seats will weigh less, but offer NO recline adjustment beyond fore-aft. Two-piece aftermarket seats, with adjustable seatbacks, will diminish the weight savings further. And typical aftermarket seats are NOT air bag-equipped.
Notice the difference in weight between non-powered and powered seats...6.9 lb/ea, so 1LS seats would save 14 lb (with Air Bags) over 1SS seats, while maintaining OE safety standards for street driving.
Notice deleting the rear seats (29 lb) and belts/retractors (5 lb) = less than ONE front seat...
Notice the A/C compressor and condensor, and Power Windows/Locks/Keyless weigh a total of 32 lb...which pops the "urban myth" that Gen-4 1LE F-cars weighed a LOT less...they didn't!
LOWDOWN is offline   Reply With Quote
Old 04-03-2012, 12:32 PM   #49
cbass
Drives: .
Are both the leather and cloth seats the same weight?
cbass is offline   Reply With Quote
Old 04-03-2012, 12:39 PM   #50
LOWDOWN
Downright Upright
Drives: Daily
For your edification:
Engine Compartment
460.9 lbs – LT1 (5.7L) Manual with oil and flywheel
428.8 lbs – L36 (3.8L) Manual with oil and flywheel
405.5 lbs – LT1 (5.7L) Auto with oil and flexplate
391.2 lbs – L36 (3.8L) Auto with oil and flexplate
40 lbs – Optima red-top battery (sounds heavy???)
32 lbs – Madman manual rack & PA chromemoly k-member
25 lbs – Pair of stock manifolds with AIR tubes off LT1
18 lbs – AC compressor with lines
18 lbs – ATI 3 core F-Body intercooler
17 lbs – AC compressor with lines
14 lbs – Dyna Battery
12 lbs – Plastic insulation on firewall
12 lbs – ATI 2 core F-Body intercooler
11 lbs – Full windshield washer reservoir
10 lbs – ABS unit
9 lbs – AC condensor
9 lbs – AC condensor with accumulator
8-9 lbs – OEM motor mounts (pair)
8 lbs – Bracket for PS/AC compressor
7 lbs – Competition Engineer solid motor mounts
7 lbs – AIR pump hoses and bracket
4.4 lbs – Cruise control
3 lbs – EGR valve and aluminum tube
3 lbs – Wiper motor
3 lbs – BMR 2 point strut tower brace
3 lbs – All exhaust heat shields
2 lbs – Factory oil cooler lines
1.5 lbs – Horns (pair)
1lbs – Heater core lines
Drive Train
190 lbs – Moser 9″ (3.250 bearing) w/35 spline axles, Strange nodular iron section, full spool, 3:70 gears, no oil
135 lbs – Stock 7.5 rear end w/3.73 gears and oil
40 lbs – Centerforce heavy flywheel
35 lbs – Vigilante torque coverter new in box (inc box!)
34 lbs – Steel 2pc V6 driveshaft including center bearing carrier
28 lbs – A TH400 with 9″ converter is 28 lbs lighter than the 4L60E
20.5 lbs – LT1 stock flywheel
20 lbs – LT1 stock flywheel
16 lbs – Stock steel LT1 driveshaft
12.5 lbs – TPiS lightweight flywheel
12.2 lbs – 3rd gen aluminum 1LE driveshaft
12 lbs – LPE aluminum driveshaft
11.5 lbs – Stock aluminum LS1 driveshaft
10 lbs – RK Sport aluminum 1pc driveshaft
10 lbs – ??? brand lightweight flywheel
4 lbs – Transmission tunnel insulation
Wheels & Tires
58 lbs – AFS chrome 17Χ11 GS offset wheel with new Dunlop SP8000 315/35/17 tire
56 lbs – AFS chrome 17Χ11 GS offset wheel with BALD Dunlop SP8000 315/35/17 tire
56 lbs – 18Χ9 chrome Cobra R replica wheels with 285/35/18 tires
55 lbs – AFS silver 17Χ11 GS offset ZR1 wheel with new tire
55 lbs – 17″ Prime chrome 5 Stars with 275/40 tire
55 lbs – 17″ chrome Firewhawk wheel with new tire
54.5 lbs – Replica SS wheel with Khumo 712 275/40 tire
52 lbs – AFS chrome 17Χ9.5 ZR1 wheel with new Dunlop SP8000 275/40/17 tire
50 lbs – OZ Monte Carlo 17Χ9.5 with 1/3 tread 275 GSC
50 lbs – AFS polished 17Χ11 GS offset ZR1 wheel with new 315 BFG Comp TA drag radial
48 lbs – 16Χ8 stock chrome 5 star with Kuhma Estca Supra 712 tires (V rated)
45 lbs – 99 TA stock 16″ chrome wheels and tire (SZ 50)
44 lbs – 93-96 Camaro wheel with Nitto drag
41.5 lbs – 93-96 Camaro wheel with bald 255 BFG drag radial
40 lbs – Weld Pro Star (15Χ10) with new Hoosier QTP 28Χ11.5-15 (no tube)
35.3 lbs – New Dunlop SP8000 315/35/17 tire
31 lbs – New Dunlop SP8000 315/35/17 tire – hmm?
31 lbs – Kumho Victoracers 275/40/17 tire
30 lbs – New Dunlop SP8000 275/40/17 tire
29 lbs – 97 to 99 Vette standard rear wheel
28 lbs – Kumho Victoracers 315/35/17 tire
27 lbs – Weld Pro Stars (15Χ3.5) with Cooper 165R tire
27 lbs – 18Χ9 chrome Cobra R replica wheel
25.5 lbs – Hoosier A3S03 Autocross tire 315/35-17
25 lbs – Firestone SZ50EP stock size tire
25 lbs – New Futura 275/40/17 tire
24.5 lbs – Goodyear GSC 245/50/16 tire
24 lbs – 97 to 99 Vette magnesium rear wheel
22.5 lbs – Hoosier A3S03 Autocross tire 275/40-17
22 lbs – 90 Vette stock wheel 17Χ9.5
22 lbs – Hoosier R3S03 275/45/16 tire
22 lbs – 01 Camaro SS 17Χ9 wheel
22 lbs – 2 piece Centerline Sabre type 17Χ9.5 wheel
21.5 lbs – 97 to 99 Vette 18Χ9.5 wheel
20.06 lbs – 00 Vette standard rear wheel
20.5 lbs – OE ZR1 17Χ9.5 wheel
20.5 lbs – AFS replica 16″ SS wheel
20.1lbs – 97 to 99 Vette magnesium front wheel
20 lbs – CCW 17Χ10 wheel
20 lbs – CCW 17Χ11 wheel
20 lbs – 3 piece Centerline Sabre 17Χ9.5 wheel
19.5 lbs – 1996 stock Camaro wheel
19.5 lbs – Stock 5 star 16″ Z28 wheel
19 lbs – 2000 stock Camaro wheel
19 lbs – 97 to 99 Vette 17Χ8.5 wheel
18-19 lbs – Centerline 17Χ9.5 wheel
18.08 lbs – 00 Vette standard front wheel
18 lbs – Fiske FM5 17Χ9.5 wheel
17 lbs – 2000+ stock Camaro wheel (different than above?)
13 lbs – Weld Pro Star (15Χ8)
10 lbs – Weld Pro Star (15Χ3.5)
10 lbs – Bogart DragStar 15Χ10 racing wheel
Interior
65 lbs – Wolfe weld-in 6pt. roll bar
42 lbs – 1997 Camaro front leather power seat
40 lbs – Carpet with the sound deadener
38 lbs – Spare tire and jack
36 lbs – Spare tire and jack
34 lbs – Passenger seat
32 lbs – 1997 Camaro front leather manual seat
29 lbs – Rear seats
24 lbs – Heater core
20 lbs – Front & rear seatbelts with bolts
17 lbs – Passenger airbag with bracket
10 lbs – Driver side airbag
9 lbs – Center console (Trans Am)
7 lbs – Under dash AC plastic moulding
7 lbs – Bose speakers (95 Z28)
6.9 lbs – 6 way power seats over manual seats
5 lbs – Stereo
5 lbs – Rear pair of seat belts and retractors
4 lbs – Rear panel with speaker
4 lbs – Rear hatch cover / divider
2.7 lbs – Power windows over manual windows
2.7 lbs – Sunvisor (pair)
2 lbs – Sunvisor (pair)
2 lbs – Glove Box
2 lbs – Rear hatch cover
2 lbs – Insulation glued to dash
2 lbs – Factory Monsoon amp
1.8 lbs – Power door locks over manual locks
1.8 lbs – Rear floor mats
1.3 lbs – Remote truck release motor
1 lbs – Rearview mirror
0.4 lbs – Keyless entry option over no keyless entry
0.4 lbs – Rear window defogger
Exterior
44 lbs – 93-97 Stock Camaro hood with insulation
31 lbs – Rear bumper reinforcement and brackets
23 lbs – Front bumper reinforcement and brackets
12.3 lbs – T-tops
4 lbs – Front impact absorber
3 lbs – Wipers
2.7 lbs – Z28 fog lamps
1.8 lbs – Body side mouldings
Suspension
33 lbs – Suspension Techniques 35mm front sway bar
14 lbs – Front sway bar and brackets
14 lbs – 2002 stock torque arm
13 lbs – Stock rear springs
13 lbs – Front sway bar
12 lbs – Edelbrock torque arm
8 lbs – Rear sway bar with end links
2 lbs – Rear spring perches
2 lbs – Front sway bar mount
Old 04-03-2012, 12:40 PM   #51
LOWDOWN
Downright Upright
Drives: Daily
Now? No. The Leather seats have heaters (and heavier-weight material)...a couple or three pounds each seat.
Old 04-03-2012, 01:41 PM   #52
2cnd chance
Engine Compartment
10 lbs – ABS unit
3 lbs – Wiper motor
Drive Train
Wheels & Tires
Interior
29 lbs – Rear seats
5 lbs – Stereo
2 lbs – Glove Box
Exterior
12.3 lbs – T-tops
3 lbs – Wipers
Suspension
VERY INTERESTING...wish we had this for the 5Gen!
Old 04-03-2012, 02:56 PM   #53
cbass
Drives: .
If we start unbolting parts and weighing them, then we shall.
Old 04-03-2012, 02:58 PM   #54
LOWDOWN
Downright Upright
Drives: Daily
Well, I doubt they sent the Gen-5 components to a FattenUp-Farm...excepting the side air bag-equipped seats...and, of course, those cast 20s...
Old 04-03-2012, 04:05 PM   #55
b4z
Drives: '06 Pontiac GTO M6, '09 V8 SRX RWD
A/C delete doesn't save a huge amount of weight but it IS weight at the front of the car which is generally a bad thing.
b4z is offline   Reply With Quote
Old 04-03-2012, 04:13 PM   #56
LOWDOWN
Downright Upright
Drives: Daily
A c/f Ram Air-Extractor hood and prop-rod on a Z28 would likely = A/C-delete, weight-wise...
An smc-based hood (like Gen-4 SS/Firehawk) would be a few pounds more.
Official: 2013 Camaro 1LE Performance Package: 426-hp, 1g cornering, under $40,000 MS3DALE Camaro 1LE Forum 1232 08-01-2015 05:56 PM
It's a labor of love; 91 Camaro RS garcmol 3rd Generation Camaros 96 08-17-2012 10:33 AM
The 2011+ Mustang Thread GatorBlue371 General Automotive + Other Cars Discussion 11874 08-23-2011 01:30 PM
