Old 04-01-2012, 09:37 PM   #1
S3XPanther
by Odeon
S3XPanther's Avatar
Drives: '12 SS/RS A6 IOM SOLD, '13 1LE IOM
Question Strange rattling sound when under light load.
My 2012 SS L99 (just broke 1000mi a few days ago) has of late developed a strange noise. When in either drive or reverse, and while feathering the throttle, I hear a rattle that would seem to be coming from directly under the cabin. My original inclination was to attribute the noise to the exhaust, however, when revving in park I cannot duplicate the noise. In addition, the noise is only evident when the car has really warmed up and has been running for at least 20min. This is why I believed it to be exhaust related; possibly an improperly torqued clamp expanding from warm up and causing the pipes to move around a bit more.
I know there is a TSB on an exhaust rattle, but again this doesn't happen when not under load; so I therefore assumed it couldn't be the exhaust.
So I'm stumped. Am I mistaken in believing that it isn't the exhaust? Or is the issue something else entirely?
Thank you.
"It works 60% of the time, every time."
"Some say it's a waste of time, others say it's an incredible waste of time."
"The ultimate measure of a man is not where he stands in moments of comfort and convenience, but where he stands at times of challenge and controversy."
2013 IOM SS/RS - 1LE. Born 5/6/2013 (1 of 32 1SS IOM 1LE's)
S3XPanther is offline   Reply With Quote
Old 04-02-2012, 01:09 AM   #2
S3XPanther
by Odeon
S3XPanther's Avatar
Never mind. I just read up on exhaust pressures under load and free revving. I'm an idiot.
Guess it is the same problem stated in the TSB.
Old 04-02-2012, 01:42 AM   #3
TAG UR IT
www.Camaro5store.com
TAG UR IT's Avatar
Drives: 2014 ZL1 #705
I had a rattle that progressively got worse directly under the cabin. Happened only between 15 to 20 mph (or so). Not with the clutch in stopped revving. Only between those speeds.
Turned out my center bearing in the drive shaft went out. Had to replace the entire thing drive shaft. FYI.
Old 04-02-2012, 01:59 AM   #4
S3XPanther
by Odeon
S3XPanther's Avatar
Damn that's scary. Do you honestly think that could happen with a car with just over 1000mi? In may case, I'm getting a faint rattle at about 5mph and only when warmed up. Either way, a trip to the dealer is a good idea I guess.
Old 04-02-2012, 06:12 PM   #5
OBSSEST
Drives: 2010 Camaro 2SS RS, Black
You may also be hearing the AFM kick into 4 cyl. mode. When you blip the throttle, it turns off and goes back to 8 cyl. AFM makes our L99's vibrate and rattle. Sadly enough, this is normal operation and the only fix is to have AFM turned OFF via a tune. In which case, you risk that your powertrain warranty is void.
OBSSEST is offline   Reply With Quote
Old 04-02-2012, 06:47 PM   #6
S3XPanther
by Odeon
S3XPanther's Avatar
No I know what the AFM sounds like, this is actually my 2nd SS. This happens at a crawl.
Old 04-02-2012, 07:04 PM   #7
S3XPanther
by Odeon
S3XPanther's Avatar
Tell you what, I'll attempt to shoot a video sometime this week.
Old 04-02-2012, 07:11 PM   #8
S3XPanther
by Odeon
S3XPanther's Avatar
Ok guys, check this out. Found a video which contains a similar if not identical noise I'm experiencing. According to the user, the issue was a bad gasket that caused the O2 sensor to fit improperly. Forward to about 0:17. Anyway, here it is:
Old 09-12-2015, 11:13 AM   #9
kraut1971
81TCHN Camaro
kraut1971's Avatar
Drives: 2013 Blue Ray Metallic 2LT RS
Bump - Am experiencing the same annoying rattle while driving between 25-30 MPH.
It this something that justifies a warranty claim???
Kraut
kraut1971 is offline   Reply With Quote
Old 09-12-2015, 06:21 PM   #10
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2010 Camaro 2SS A6
The L99 is never on 4 cylinders when idling out of gear.
Rattling could be any of the many heat shields or something in the drivetrain.
I have a rattle when passing through about 2500 rpm under light load. But it's hard to duplicate, so far. Sounds like sheet metal like a heat shield, but you never know. Rattles can be very hard to characterize.
Rock-It Man is offline   Reply With Quote
Old 06-14-2016, 03:21 PM   #11
JohnBrain
Drives: Hot Wheels SS Conv
Heat Shield Rattle
Since day one I received the car there was a rattle but only from about 30 to 40mph coasting so not engine rev related. Noise is there in gear or neutral. Have been several times to the dealer and they tray each time but comes back. Now have to have a regional tech come out to look at it. Hope I can get it to make the rattle since it sometimes goes away.
Anyone else have this same issue might need support to argue warranty.
JohnBrain is offline   Reply With Quote
Old 08-18-2016, 07:14 PM   #12
Quicksilver-SS
Quicksilver-SS's Avatar
Drives: 2014 1SS / RS M6
Took mine in for it's last free oil change and had them look for the rattle on my M6 SS.
They said it was Gear Rattle and common on manual cars and trucks. They gave me of copy of TSB 03-07-004K And it describe the low speed, light load rattle I am hearing.
https://www.google.com/url?sa=t&rct=...zTC5i4Sfs7JHpw
Quicksilver-SS is offline   Reply With Quote
Old 08-19-2016, 05:29 PM   #13
Jayjellyfish212
Jayjellyfish212's Avatar
Drives: 2014 1LE
Mine has a light rattle on warm up and only when I'm clutching the car In drive. Seems to be in far back area of trunk. Goes away once clutch is completely let out and slight gas is given. Don't last long and seems to be only at warm up. I'm thinking might be loose exhaust part or heat shield and once hot it's tight again.
Mods: It's an addiction!
Jayjellyfish212 is offline   Reply With Quote
Old 08-19-2016, 05:41 PM   #14
HyperV117
HyperV117's Avatar
Drives: 2010 Camaro 1SS
That video sounded like a loose heat shield.
HyperV117 is offline   Reply With Quote
exhaust, load, problem, rattle, revving
Clicking sound under load! M6 Bad70supreme V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 3 11-30-2010 10:55 AM
Got Pulled over... TRSS2 Cosmetics and Lighting Modification Discussions 39 03-08-2010 12:57 PM
A6 noise during light load. Anyone else JohnForeman V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 9 10-03-2009 08:25 AM
Exhaust sound bulldog Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 13 07-07-2009 03:43 PM
