Solo Performance
Old 04-01-2012, 10:47 PM   #1
Jason@
Drives: 2016 1LT RS Camaro; 72 Chevelle
Send a message via AIM to Jason@ Send a message via MSN to Jason@
Newly developed oil leak... Could newly installed catch can be to blame?
I'm not real sure where to post this, it doesn't really seem mantenance related, or bolt on related, seems pretty general, so here goes...
Went to drive the Camaro today, got to my Dad's and the car smelled of burning oil. (SEE PIC 1) Pop the hood and see there was oil on the top of the catch can, and running down the side... Weird, I wipe it off.. Open the drain valve, nothing came out at all. I didn't expect anything to come out, because I just installed the catch can 2 days ago on FRIDAY.
Yes, the hoses are going to the correct locations to the valley cover, and to the intake nipple. I triple checked the install and checked on here to make sure it was right on Friday...
Came home to picture #2 giant oil leak where the Camaro was parked last night. Huh, wtf? I checked the oil, and sure enough it wasn't even on the hash marked area. Drive to the shop, jack the car up look for oil leak... It appears to be coming from between the engine and trans, I assume the rear main seal...
Double check hoses on can again, the center one goes to the valley cover, and the outer one goes to the nipple on the intake just behind the throttle body... Checked to see if valves on can, and breather cap are operating, they seem to function normally. The can drain valve is closed. Open drain valve, start car, there is vacuum at the drain hose with valve open. Shut off car, close valve. Everything seems to function normally.
Did I forget something on the can install? It seemed pretty straight forward.
Back to Friday when I installed the can I had to remove the throttle body to access the hose from the valley cover to the intake and discovered oil on the back of the TB (PIC 3), the intake was moist, but there were no puddles of oil (PIC 4)... Does my car have blow by issues?
I parked the car in a different spot in the driveway, we'll see if I get another big spot tomorrow. I also removed the breather and put the stock oil fill cap back on, and reconnected the hose to the intake elbow for the time being.
The only thing that has changed is the addition of the can. It is an RX can. I'm not saying it's the can's fault, and it seems to function as normal. The car never leaked oil before, and currently has 17,000 miles on it.
Jason@ is offline   Reply With Quote
Old 04-01-2012, 11:02 PM   #2
BLACK10
BLACK10's Avatar
The car is not supercharged correct?
Old 04-01-2012, 11:07 PM   #3
Jason@
The car is not supercharged, I'm too poor for that LOL
I see this was also moved, I guess it was not considered general. I didn't want to put it in the bolt on section as it could be a general problem not related to the bolt on RX catch can.
Old 04-01-2012, 11:10 PM   #4
formare
The Milano
formare's Avatar
Drives: 2017 Firefly ShipWorks
Did you open the valve on the bottom of the can and test for vacuum there? It might be a stuck ball valve in the nipples of the can.
My first Love. She was called "Miss Carriage" (still cry when I think about her)
383, Muncie 4 speed, custom linkage mated to hurst short throw shifter.
formare is offline   Reply With Quote
Old 04-01-2012, 11:11 PM   #5
Jason@
Yes I did, there is vacuum there with the valve open.
Old 04-01-2012, 11:34 PM   #6
formare
The Milano
formare's Avatar
I'm outa ideas, sorry. It sure does seem that your car is acting like the crank case is getting pressurized by a blocked PVC vacuum line though. Maybe send a personal message to sc1250 ?
Old 04-02-2012, 12:11 AM   #7
Jason@
I will send him a message asking him to view the thread...
Old 04-02-2012, 12:48 AM   #8
rberns
rberns's Avatar
Drives: 2011 Camaro 2SS/RS
To me, those who have this issue always have the breather installed with the RX CC. Anybody else notice this? I have the RX CC, without breather, and I have no problems so far.
2011 Camaro 2SS/RS, Circle D 3200, ADM Transmission Cooler, BTR Valvetrain, Cam Motion .621 .595 228/244 113+4, ARH 1 7/8, Cold Air Inductions, Katech C5R TC, Melling HV, BTR SLR lifters, Trunion Upgrade, LS2 Dampner, LS9 head gaskets, Bo White PTB, RX CC, GFX, Subs.
rberns is offline   Reply With Quote
Old 04-02-2012, 01:19 AM   #9
Jason@
I have also noticed there seems to be a connection between the breather, and problems similar to this.
Old 04-02-2012, 01:49 AM   #10
14pilot
Original Bumblebee Owner
14pilot's Avatar
Drives: 265hp ZX-14, 500hp Silverado, V-ROD
I wonder if you might have accidentally got a V6 breather cap instead of a V8 cap? I understand that the V6 breather is metered to let less fresh air in than the V8 breather...
Best of luck. Hope this gets resolved soon.
#5 - 2010 2SS/RS MN6 ABM #142-Silver Rallys-GFX / Med Titanium
My previous Camaros:
#4 - 1994 Z/28 6M Black over Arctic White / Graphite-Red Inserts - traded
#3 - 1981 Z/28 Bright Blue Metallic / Black - sold
#2 - 1970.5 RS Mulsanne Blue / Blue - endo crashed it and parted it out
#1 - 1967 RS Butternut Yellow w/ Black Bumblebee Stripe-RPO D91 / Parchment-Black - sold
14pilot is offline   Reply With Quote
Old 04-02-2012, 01:43 PM   #11
ShizzyIzzy
Novice Wrencher
ShizzyIzzy's Avatar
Drives: 2011 2SS/RS Summit White
I had the same problem
I had 10k miles on my car with no problems. Had headers/tune/CAI and it ran fine.
Then I put on the RX can and breather and after 2-3k miles my car was gushing oil from the rear main seal. The tech at GM said the oil pressure in my car was double what it should be and my crankcase pressure was about to blow the engine.
Long story short, I removed the can and now all is good and the car runs perfect. If you poke around on here you will find quite a few post identical to this. Same problem, same leak, same burnt oil smell. Im not flaming the cans, in fact I still have mine (just not on the car) and I also have the RX ported TB on my car currently, which I love. I even triple checked to make sure the hoses were hooked up right and the can was actually creating a vacum and the valves were not broken. It all came down to the can and breather.
p.s. The dealership where I took in the car replaced the rear main seal under warranty, but said if I didn't remove the can, next time its not free. For something that was supposed to be cheap insurance, it almost cost me an arm and leg.
2011 2SS/RS Summit White - Silver Stripes. Corsa Exhaust, CAI Inc. Intake, VMaxx Throttle Body, Pfadt Stage II Suspension Kit, Dynomax Headers, DynoTune, Rx Catch Can & breather
ShizzyIzzy is offline   Reply With Quote
Old 04-02-2012, 01:59 PM   #12
skar
skar's Avatar
Drives: 2010 2SSRS headers/CAI/tune/corsa,
Sounds like it may be the breather I will put stock cap and hose back on and leave can on. ( that cant hurt ? )I do get a oil smell once in a while since I installed can? yet no leaks but have less then 200 miles on can.
Stainless works headers/cats Roto fab CAI /
Corsa install and tune Livernois
TSW Nuburgring 9 &10" x 20 on Invos (315 & 275 )
JL Audio XD400/4 amp
Pfadt trailing arms & tie rods sway bars.
pedders street 1 package. ,Hurst short throw shifter
With bronze bushings .
skar is offline   Reply With Quote
Old 04-02-2012, 02:07 PM   #13
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
I too agree it sounds like to me to be a breather issue.
Everyone that I've see who posts this problem has the breather cap installed as well. I've yet to see a thread or post from someone who has had this happen only have the catch can installed.
I have the RX catch can. I installed it first thing as soon as I brought the car home and that was a year and a half ago. I have zero issues with the can nor with my engine.
Mr_Draco is online now   Reply With Quote
Old 04-02-2012, 03:01 PM   #14
DandD
DandD's Avatar
Drives: 2010 2SS and 2011 LS
Hey Tracy could you post the numbers here as to aprox. how many people have bought the CC and breather and how many have had this issue with the oil leak?
Around here we like baseball, hot dogs, apple pie, and Chevrolet
DandD is offline   Reply With Quote
Installed RX catch can, oil pressure high? GotGame55 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 5 02-07-2012 07:49 PM
OIL CATCH CANS john468 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 5 09-16-2010 03:02 PM
The 3,000 Mile Oil Change Myth KILLER74Z28 General Automotive + Other Cars Discussion 35 07-20-2008 10:02 PM
gas prices. Congoman775 General Automotive + Other Cars Discussion 65 05-28-2008 01:20 PM
