sjm autoprod
Old 04-01-2012, 11:01 PM   #1
PewterPredator
Drives: 2000 WS6 Trans Am & 2010 SS Camaro
LSX 454 Swap : Helpful tips!
Just like the title says this is a list of things that i hope will help some of you guys out if you ever decide to go with the LSX 454 from GM, I'm sure most of you guys know this and for those that i don't i hope you find this helpful, i learned the hard way and after having the motor in and out several times and im simply doing this so you guys can have a smooth install... First off i wanna thank NC-V, he has helped me a lot with this swap and i can't thank him enough, great guy!
First of all i wanna list the sensors that you will have to swap over from your stock LS3 to the LSX.. If any of you run the LS7 setup like i did, most people run the FAST setup but unfortunately i couldn't afford to go with that right now... With that being said, the intake sensor located on the front of the intake near the TB is different, BUT you will have to make the whole a little bigger on the LS7 intake for the LS3 sensor to fit, Another is the rear oil sensor, located behind the intake will also have to be changed... Every other sensor will work..
The oil coolor that located on the driver side of the pan was one thing that kinda worried me during the swap until i got the motor out its simple, pull back the black round cover and remove the clip and the tube will come right out, on the LSX there will be a freeze plug located driver side front "there should be 3 of them" the front one is the one you use, this allen head is a 17mm, take that out remove the fitting from the LS3.. Place it on the LSX and bolt it all back up! Slide the tube up push the clip in and slide the black cover back up on it..
This is one of the most important parts for me, i had the motor in the car almost complete when i went to put the ac belt on the motor wouldn't turn over.. So to me this is the most crucial part... The LSX comes with a windage tray that is deeper for the crank, this tray will NOT work with the LS3 pan, i tried trimming it to work but it still will not work.. You will have to space out the LS3 windage tray a 1/4in and it will clear, I used 1/4in washers on each stud and it worked perfect..
This is the final thing i can think that i had to change/modify.. The a/c bracket will have to be trimmed down a little for it to fit flush against the block and so the bolts will line up..
One more thing.. My local dealer i ordered my motor from recommended the LSA clutch/flywheel, which is the clutch out of the new CTS-V.. This clutch will NOT work will factory LS3 slave.. I learned the hard way with this so i would def steer clear of the clutch setup..
Thats about it, i hope somebody can find these tips helpful!
Billy
2002 Z28 Camaro
"Silver Streak" - UNDER CONSTRUCTION
2010 SS Camaro
GM LSX 454 - ARH - Hotchkis - Katech - Centerforce - GM Performance Parts - SLP
Tuned by KK Performance *SOLD*
PewterPredator is offline   Reply With Quote
Old 04-01-2012, 11:06 PM   #2
xx_ED_xx
xx_ED_xx's Avatar
Drives: 04 Silverado
and dont add a blower to an lsx454 or pop goes the weasel
xx_ED_xx is offline   Reply With Quote
Old 04-01-2012, 11:06 PM   #3
The Stig
knows 2 facts about ducks
The Stig's Avatar
You should talk to Dangeruss and/or Darth Emma. I know off the top of my head that they have LSXs. Can't think of anybody else atm though
Click to view my build thread
Old 04-01-2012, 11:35 PM   #4
PewterPredator
I have got mine together, just waiting on clutch and it will be ready to rock, i'll get some pics as soon as i can! Dang didn't know they were popping under boost... What about spray??
Billy
2002 Z28 Camaro
2010 SS Camaro
Old 04-01-2012, 11:47 PM   #5
xx_ED_xx
xx_ED_xx's Avatar
yeah its a lil diferent when it is purpose built, but when you go buy a complete NA lsx454 and just throw a blower on it and then get mad because it blew up. search the old threads it is in there
Old 04-02-2012, 06:55 AM   #6
NC-V
NC-V's Avatar
Drives: cts-v
Glad you got it worked out and back together! Feel free to give me a shout if you need anything else or when you are ready to do your clutch!
NC-V is offline   Reply With Quote
Old 04-02-2012, 03:02 PM   #7
registrationsticker
Banned
Drives: black
i think you may be wrong. i looked at older posts and found this that dr jamie meyer of gm said you can do it. i copied and pasted below:
-MaxChevy Magazine Volume III, Issue 3, Page 52
Dr Jamie Meyer Interview Product Integration Manager for GM Performance Parts
“I don’t think we’ve ever had anything like what this LSX 454 will be with all-forged internals and cylinder heads that flow close to 400cfm. With a power adder on that, you’d be able to quickly create a 1,200 or 1,300 horsepower street car.”
certainly if dr jamie meyer says it can be done, it must be the truth.
registrationsticker is offline   Reply With Quote
Old 04-02-2012, 08:35 PM   #8
v8
v8's Avatar
Drives: GT500 and 14 ZL1
Thanks for the info
Gone but not forgotten:
1974 Corvette Stingray 454
1986 Z28
2009 Mustang GT convertible
2012 45th 2SS Vert
2013 ZL1 M6
v8 is offline   Reply With Quote
Old 04-03-2012, 12:53 PM   #9
PewterPredator
No Problem!
2002 Z28 Camaro
2010 SS Camaro
Old 04-03-2012, 03:34 PM   #10
Vette TPI
Vette TPI's Avatar
Drives: 1987 Corvette TPI
I still don't trust that, I read a couple stories on here about the 454 going out with a supercharger on top and he didn't reach 1000. I'd at least change for forged low comp pistons.
Vette TPI is offline   Reply With Quote
Old 04-03-2012, 03:41 PM   #11
xx_ED_xx
xx_ED_xx's Avatar
Yeah and someone did that and it blew up on the dyno. as i said there is a whole post or two about it, if i cared about the posters name i would remember it. He took this dr jackasses advice and it cost him a pretty penny. I posted in the thread so search for old post I made. I am sure you will find it. I even made a comment before it blew up about him not taking it apart and setting it up for boost. He called me an idiot and then it blew up.
Old 04-03-2012, 09:09 PM   #12
jeremywilson18
jeremywilson18's Avatar
Drives: 2011 Inferno Orange 2SS RS(LSX 454)
Send a message via MSN to jeremywilson18
I didn't run in to that many problems but we did change the slave. I do believe spay works very well under high compression and will be safe on the 454. My only issue on the install was that my pockets weren't deep enough and I'll be paying for a while
jeremywilson18 is offline   Reply With Quote
Old 04-04-2012, 06:09 PM   #13
registrationsticker
Banned
Drives: black
i'm sure you wont have core shift in the lsx454 block causing thin cylinder walls . spray away at will with confidence, because you purchased a crate lsx motor and there is no logical reason to tear it completely apart for sonic testing.
Old 04-04-2012, 06:21 PM   #14
Sack Rat 2SS
Sack Rat 2SS's Avatar
Drives: Silver SS/RS, Man 6
Pewter Predator - Nice tips on the install and things to work through. I would recommend you get a larger radiator like from Ron Davis. The iron block retains more heat than alloy plus you are cooling 80 more cubic inches. It is one of those things that can only help and not hurt. Good insurance for the money IMHO. Good Luck.
Silver 2SS/RS Man/6
CTS-V front 6-Piston Calipers,
GM 3.91 Rear Gears
Sack Rat 2SS is offline   Reply With Quote
OFFICAL 2012 LSX Challange series schedule from NMCA nmcajefftaylor Camaro Motorsports Discussions 5 12-11-2011 08:08 PM
LS9 / LSX 454 Crate engines showcased by GMPerformance Tran Forced Induction - V8 52 12-14-2010 12:38 PM
Can a V-6 model Fit a 454 lsx? LS376 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 6 06-27-2010 06:58 PM
LSX 454 2SSRS@Gen5diy Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 40 06-09-2010 08:42 PM
LSX 454 factory dealer option danraz98 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 14 05-06-2010 11:36 AM
