Gen5DIY
Old 04-02-2012, 09:54 AM   #1
Bad70supreme
Bad70supreme's Avatar
Drives: 2010 aqua blue SS/RS M6
Power increase after tune with cam?
Hey guys just wondering if you guys had a baseline number after your cam install and how much was the gain after the tune. Should I expect to pick up power across the bored? I never had the car even tuned for the headers so I am thinking there is allot to gain at this point. Not shure what to expect.
10.91 at 122 H/C stock block N/A
Bad70supreme is offline   Reply With Quote
Old 04-02-2012, 01:14 PM   #2
MikeOD
Drives: 2010 M6 2SS
I think you'll gain quite a bit. My cam in my car is big enough that I really couldn't even put the throttle down with the old tune in there, so I don't know what to tell you, but I'm sure your going to see your AFR and spark are off from optimal until the car is tuned.
2010 Camaro SS M6. Heads/Cam/Intake/Headers/Exhaust/Suspension
MikeOD is offline   Reply With Quote
Old 04-02-2012, 01:59 PM   #3
fourmz
Fourmz
fourmz's Avatar
Drives: 2010 2SS/RS 1968 Firebird 1994 Z28
With my build I went from 370 RWHP to 439 (On 90 oct).
Black-in-Black/Blue out 2010 2SS/RS LS-3 -Magnacharger TVS2300,OD cog belt drive, 3.4" pulley, Janetty smooth idle blower cam,ID-850 injectors,ZL1 fuel pump,MSD boost a pump, ADM FPCM Janetty custom tune,Doug Thorley long tube headers, Corsa catback,C.A.I. Intake, Roto-Fab Big Gulp Scoop, Monster LT1/SC Clutch assembly,Eibach pro kit plus, BMR cradle/diff bushings, Barton Shifter,JRE 3.91 Eaton Tru-Trac rear diff,Barton Short Throw SHifter, Boss 339 20" wheels,Painted heritage grille, Sparks Restoration Inverted blue/black SS emblems, Seibon BB carbon fiber hood, ZL1 front bumper conversion.
fourmz is offline   Reply With Quote
Old 04-02-2012, 02:06 PM   #4
BLACK10
BLACK10's Avatar
You should see around 80rwhp if you have headers also
Old 04-02-2012, 02:08 PM   #5
urr2slo
urr2slo's Avatar
Drives: 2010 2ss ss/rs abm, 2016 2ss/rs hbm
It depends on the cam you chose and how good your tuner is. Ballpark 35 to 80 rwhp so as you can see it is a big spread as well as it will vary as to what other existing mods are done.
URR2SLO - If you're not going fast enough, get out the way......
urr2slo is offline   Reply With Quote
Old 04-02-2012, 02:22 PM   #6
SSDan
Drives: 2016 1SS 6MT NPP
I think my experience is fairly typical for a mid range cam (many call it a stage II cam). With full bolt ons and cam ( see my sig for details) I gained 83 RWHP. That gain is for a stock baseline dyno to a full tuned result (same shop, same dyno and within a couple of days of each other for the runs - no big weather changes in between).
SSDan is offline   Reply With Quote
Old 04-02-2012, 03:08 PM   #7
mikeSS
mikeSS's Avatar
Drives: 2015 c7
pretty sure people are not really understanding what the OP wants. he is looking for gains from a TUNE. this can be a hard question to answer because most of our cams cannot run on stock tune. he already has a cam in with headers. but wondering how much the tune will add.
Old 04-02-2012, 03:14 PM   #8
Bad70supreme
Yep... I was wondering if you were shown somewhat of a base line before they completed the tune! For example your car was making around 430 and after the tune was complete they picked up X amount.
On the subject what were the gains from the tunes with your boltons? Was the tune a bigger impact then the headers?
Old 04-02-2012, 04:35 PM   #9
MikeOD
Drives: 2010 M6 2SS
If your car was already tuned to the max for your other mods on a stock cam, and then re-tuned for a cam, it probably wouldn't have gained 83 RWHP...you'd make the same number when all done, but you'd have made more prior to the cam.
But as was mentioned, the OP is asking that since he is able to drive his car with the stock tune and the cam he chose, and it actually has worked out well for him...how much will he gain with a tune. There is absolutely no way he'll gain ANOTHER 80+ horsepower from tuning it...probably 20-30, but maybe a little less since the cam is fairly mild and the stock tune reacted well to it already.
Old 04-02-2012, 04:53 PM   #10
Bad70supreme
It is running VERY rich, it actually burns my eyes sometimes Since I never had a tune for the headers, I am hopping to have a different car once this done.
Old 04-02-2012, 06:51 PM   #11
SGOS252382
SGOS252382's Avatar
Drives: 2010 Camaro 2SS/RS
It all depends on how well your car is running with the stock tune.
More aggressive cams will need more tuning and your gains will be greater with tuning. Less aggresssive cams (closer to stock specs) will need less tuning and your gains will be smaller with tuning.
Old 04-02-2012, 07:32 PM   #12
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Whatever way you look at it YOU need a tune! I would rather have the timing and afr right then both all over the place and risk damaging my engine. Like washing down the cylinders being that rich! You'll really be crying when it shows some rods some sunlight lol. Do mods the right way with a tune and not listen to people on here by saying you dont really need a tune for some crazy reason. Ps and take it to a reputable shop also.
Old 04-02-2012, 07:48 PM   #13
Parag
Drives: 2010 camaro 2SS LS3
you probably have less horsepower than stock with headers and cam with stock tune.
stage III cam, 4.10's, custom CAI, suede headliner
461 RWHP, 422 RWTQ
Parag is offline   Reply With Quote
Old 04-02-2012, 08:23 PM   #14
Bad70supreme
The car IS getting tuned in 2 days! I guarantee it's making allot more then stock right now, definitely not running to potential but it's way faster. I haven't been beating on it much and lately I have been babying it so it's all good, just a few days to go!
Supercharger / Turbocharger Results (INFO) Thread radz28 Forced Induction - V8 256 11-18-2016 08:50 PM
my dyno today(base for e85 tune) bmorecam Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 51 06-08-2011 12:35 PM
Standard vs Automatic Racing HarrisraTx Dragstrip and Launch Techniques Discussion 74 10-29-2010 10:26 PM
Nitrous Info Milk 1027 Wiki 0 08-12-2009 07:26 PM
