| V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) Driveshafts | Differentials | Gears | Rearends | Clutch | Shifters |
Thread Tools |
UPDATE on post #60 HERE:
Has anyone else had an issue with the Strange Gears from their DSS 9" Kit? I installed a week ago Friday and from the moment I test drove my car. There is an Unbelievable loud whining noise from the rear gears that happens at ALL SPEEDS. The noise seems to lighten up on Deceleration. I am wondering if anyone else has had the same issue? I PM'd Frank with no response yet.
![]() Drives: old Join Date: Oct 2010
strange gear wine dss rear
do a search member ,becustom... he is a friend of mine had same issuse as you.. did it twice.. he was so dissipointed with strange..
220/221 whatever it takes
Drives: '10 1SS/RS M6 SW/Black Join Date: Jun 2010
That sure doesn't sound right. I know mine was quiet till I took it to the track last weekend. After 6 passes, it is now making a noticeable amount of noise. I figured it was my problem now that I've put a few miles on it and taken it down the track. Hopefully Strange will take care of it for you.
2010 Summit White 1SS/RS M6
Roto-Fab CAI, MNM 224/236 114, UD Pulley, VMax TB & Intake, Kook's LT's w/ Cats & X, Kook's Ex, Pedder's Xa Coilovers, UMI Trailing Arms, UMI Toe Rods, BMR Subframe Bushings, DSS 9" kit w/ 4.57's, MNM DynoTune 479rwhp/451rwtq 12.03 @ 121.62mph (1.9 60') |
I am going to a local gear shop to see what they can do with it !! I take it in this Friday for them to hear the noise and then they will schedule time for me to take it in and fix it after that. I will post up their findings and solution once it has been done !!
![]() Drives: IOM 2SS/RS M6 Join Date: Oct 2009
It seems as though the Strange built centers are about 50/50 on being set up correctly.... I have about 550 miles on mine and it just about as quiet as the stock diff.... I will be changing the fluid here this week now that it is broken in...
2010 2SS..LS3..Procharger..4l80e..DSS 9"
#6 |
![]() ![]() ![]() Drives: own more cars than i can list Join Date: Nov 2010
We had recently changed to a local builder called Spraker racing due to this problem, im not quite sure its the builder or the gears.
The Driveshaft Shop
Any of the parts we post about can be purchased thru our extensive dealer network If you want to see some of our latest Hi-Tech stuff click the picture below.... ![]() |
#7 |
The thirdmember was painted ORANGE if that tells you anything. I will let you know when I get it looked at and let you know what they find, maybe saving someone else the heartache that I am having with these gears !!
#8 |
Thats a Spraker diff, ill contact them. i have had some very good luck with them and the reason i had switched to them from Strange. ill send you a PM
The Driveshaft Shop
#9 |
Thanks !!
#10 |
I Wanna Go Faster!!
Drives: 2011 2SS Synergy Green M6 Join Date: Apr 2011
My Strange differential was like that out of the box too...I think I actually posted a YOUTUBE video of it as people kept telling me that 9" gears were naturally noisy...which is a load of crap. This is a very shrill, high pitched whine, not normal gear noise....I clearly know the difference. Once everyone heard the video they stopped that other nonsense quickly.
Vengeance got with Frank and Strange and they took care of it...the 2nd set sounds almost OE quiet and has been perfect ever since.
Built by Vengeance Racing
9.31@154.81 mph Procharger F1-X RPM Level 7 4L80e + Coan Converter Hendrix 9" Rear Axle + 3.50 Gear ARH 2" LTs+3.5" Exhaust Fore Fuel System, Bogarts + Hoosier Slicks Pfadt Drag Pack Suspension My Build Thread | Best Pass To Date |
#11 |
Frank contacted me and is working on getting me replacement gears.
Sent from my PC36100 using Tapatalk
#12 |
Damn, I guess I should have gone with a Moser unit. Glad Franks taking care of you Camaro21
#13 |
![]() Drives: 2010 Camaro SS/RS Join Date: Aug 2011
Had the same problem with my DSS 9" kit, although it's a Strange problem, DSS took it back and refunded 100% of my money. Great company!
Subsequently I bought the LPE 9.5" differential and it's quiet but blowing oil out the vent tube :-O |
#14 | |
Drives: First 9 inch-12 bolt IRS Camaro Join Date: Jun 2009
#15 |
DS1937
Drives: 2SS/RS M6 Join Date: Jul 2009
Sounds like incorrect pinion depth during installation by whoever assembled the rear. I seriously doubt it's the gears themselves.
#16 |
![]() ![]() ![]() ![]() Drives: 2012 45th Vert, 2011 4x4, 9sec Vega Join Date: Mar 2012
Most of the time gear noise is the result of a slightly off set up. But sometimes it is slightly off gear machining and there is no way you can get rid of the noise no matter what you do. I've also seen a few rare cases where the housing is off and every gear set you try will whine no matter how good you set the pattern.
#17 |
![]() Drives: 2ss Join Date: Oct 2009
I also had the same problem out of the box with a vibration getting it back this week will update
#18 |
We have had them checked and re-checked. i have one customer that even had a vibration and it turned out to be the Strange diff. its a shame this cant be an easy thing, Spraker said all they will do is give us a new gear. Looks like im buying an entire 3rd member again because of bad parts. We have sold over 150 of the kits and to be honest not all of them have the issues. i was thinking about setting up a jog so we could pr-test them in the high speed balancer but i cant put load on it.
The Driveshaft Shop
#19 | |
We have given most an exchange unit, its a little expensive but we feel its the right thing to do.
The Driveshaft Shop
#20 |
Hey Frank, should I contact Strange or just pay to have a local guy check mine out? The whine is pretty loud with the windows up.
#21 |
I must say how pleased I am with the way that Frank (Driveshaft Shop) is handling my issue. He contacted me and is getting a replacement replacement unit built and coming. This tells me that I made the right decision to purchase my 9" from him!!
Thanks again Frank for making this right. I anxiously await my replacement unit !! Keith
#22 |
Here is a video of how bad the gears are !!
http://s999.photobucket.com/albums/a...=VIDEO0021.mp4 This is at 65mph
#23 |
![]() Drives: Camaro SS Join Date: Mar 2010
Wow - very bad.....
No china cheap bolt-on's, buffet, or yubiwaza here.....
#24 | |
![]() Drives: 2010 Camaro 2SS Join Date: May 2011
Wow that sucks. Sorry for your troubles has to be very frustrating.
Whipple,custom cam,CAI,Kooks,Pedders and PFADT 626RWHP 549TQ ..
#25 | |
I Wanna Go Faster!!
That sounds EXACTLY like my first unit sounded....they got it right the 2nd time but still irritating.
| Tags |
| driveshaft shop, gear noise, strange |
| Thread Tools | |
| CAMARO WIKI | Tran | Wiki | 42 | Today 09:32 AM |
| Rear End Gears 101 | danhr | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 63 | 12-26-2012 11:02 AM |
| Gear for rear end | a6pk2go | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 14 | 11-16-2011 05:38 PM |
| 9" rear end question | se7en | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 5 | 10-18-2011 11:34 AM |
| Im sure this has been asked before.. But forgive my innocence :) | gmag21 | Suspension / Brakes / Chassis | 23 | 02-21-2010 10:29 PM |
