Cold Air Inductions
Old 04-02-2012, 04:52 PM   #15
Whos_Drivin
Drives: '12 Camaro ZL1, '16 Silverado Z71
Originally Posted by mr02Z/28 View Post
my wife got a flat on her 1 week old Terrain, my 1SS never had a flat yet..
My wife has had a flat on almost every vehicle she's had. I have never had one. Weird how that works...
Whos_Drivin is offline   Reply With Quote
Old 04-02-2012, 08:28 PM   #16
actireman
Drives: 2011 denali hd2500
One good reason to not let her drive it.
actireman is offline   Reply With Quote
Old 04-02-2012, 09:27 PM   #17
djsnoflake
Faith Keeper
djsnoflake's Avatar
So the guy that wrote the article had a shitty tow truck driver it happens
Old 04-02-2012, 10:28 PM   #18
Fenderaddict2
Opinionated bugger!
Fenderaddict2's Avatar
Drives: Boss 302, Mazda 2, Praga & Intrepid
Does she drive a Bimmer. I had 16 flats in 3 years.
Follow me on forums everywhere as Fenderaddict2 or my kid on the track and Twitter @fastmyles
Fenderaddict2 is offline   Reply With Quote
Old 04-02-2012, 10:28 PM   #19
bobmac427
bobmac427's Avatar
Drives: 2008 Z06
At 14mpg you shouldn't be far from a gas station at any one time.
bobmac427 is offline   Reply With Quote
Old 04-02-2012, 11:49 PM   #20
DangerZL1
Drives: Future ZL1 Owner
DangerZL1 is offline   Reply With Quote
Old 04-02-2012, 11:50 PM   #21
bvcamaro
Drives: '12 LFX
Keep a (low profile maybe?) deflated tire on rim in the spare tire cavity and stow the inflator in the middle of the rim. Then pull out both & inflate the tire up. That way you can have a just big enough rim to fit over brembos and a thin enough tire to put in trunk. Probably wont work but just a thought to keep the train rollin...
bvcamaro is offline   Reply With Quote
Old 04-02-2012, 11:53 PM   #22
2012ZL1
CaRaHoLiC
2012ZL1's Avatar
Drives: '12 ZL1,67 Cam,68 Biscayne 427 4 sp
Maybe a trunk monkey would be in order...
2012ZL1 is offline   Reply With Quote
Old 04-03-2012, 12:07 AM   #23
16floz470ml
16floz470ml's Avatar
Drives: 2012 ZL1 GLJ MG9 WBP RTQ
The best thing to do is carry a plug kit. Plugs are great for roadside repairs and they do very little damage to the tire when installing. The tire sealant will mess up your tire pressure sensor.
16floz470ml is offline   Reply With Quote
Old 04-03-2012, 01:47 AM   #24
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
Won't fit in the spare tire hole.
You my friend are incorrect.
#09-03-10-013: Statement on Tire Sealant Included in GM Inflator Kits (Supplied with New Vehicles or as GM Accessory) - (Oct 8, 2009)
Subject: Statement on Tire Sealant Included in GM Inflator Kits (Supplied with New Vehicles or as GM Accessory)
Models: 2010 and Prior Cars and Light Duty Trucks
Equipped with Tire Inflator Kits
Attention: IPC Dealers are not authorized to utilize this bulletin.
GM Warranty Statement on Tire Sealant
General Motors covers OE tires as part of the General Motors New Vehicle Warranty. The temporary use of tire sealant (as supplied with a GM inflator kit) may not be endorsed by certain tire manufacturers. General Motors has independently validated the temporary use of such sealant when used in accordance with the instructions provided in the vehicle's Owner Manual.
When the instructions found in the Owner Manual have been followed correctly, GM will continue to cover the tire under the terms of the New Vehicle Warranty, whether or not the practice conflicts with the policies of the individual tire manufacturer. Due to this policy, it is advantageous for a customer to return their vehicle to a General Motors dealership for tire warranty issues if GM Tire Sealant has been used.
Important: Road hazard is not covered. This includes punctures, cuts, impact breaks, etc. (road hazard is covered for run flat tires).
GM Inflator Kits/Tire Pressure Monitor Sensors
ONLY use the tire sealant included with GM Inflator Kits for temporary repair of tire air leaks. General Motors has tested this sealant and its compatibility with on-wheel mounted tire pressure monitor sensors. After inflator kit use, the on-wheel mounted tire pressure sensor should be inspected for any damage and replaced/cleaned as needed.
SUX2BU is offline   Reply With Quote
Old 04-03-2012, 03:41 AM   #25
Ciscokid
Drives: 2013 ZL1 Vert - BRM&2014 NRB Vette
I don't see any issues here. I had a blowout 35 miles away from my preferred dealer.
I contacted onstar, they connected me to roadside assist, they sent me text messages on the status of the driver showing up. The driver showed up exactly 40 minutes later. The tow truck knew he had to deal with ground clearance on a 2SS. He was prepared for that with a few pieces of wood to help with the clearence issue.
I prefer having someone tow the car, I don't want my wife or daughter trying to change a flat tire on the side of the freeway. I prefer the option of them calling someone to have the car towed.
They are too many other scenarios that can go really wrong with trying to swap a tire out on the side of the road.
Ciscokid is offline   Reply With Quote
Old 04-03-2012, 08:01 AM   #26
Ron66Vette&10SS
Plays with Hot Wheels
Ron66Vette&10SS's Avatar
Drives: '17 Jet Black ZL1
Exactly!
Previous Cars: '78 Z28, '92 Z28, '95 Z28, '85 Corvette, '01 SS, '96 Z28, '04 Z06 Corvette, '10 SS, '13 SS Hot Wheels
Current Cars: '17 ZL1(daily driver), '04 Trailblazer (rain & snow), '66 Corvette (restoring)
Ron66Vette&10SS is offline   Reply With Quote
Old 04-03-2012, 10:02 AM   #27
flyinlow
flyinlow's Avatar
Drives: 2017 Camaro ZL1
Every tow truck operator who is signed up to do flatbed service for the manufacturers roadside assistance programs should be carrying these, then there would be no issues. You might even be able to fit these in your car.
http://www.summitracing.com/parts/BTI-RR-TR-7/
http://www.discountramps.com/rack-ramps.htm
flyinlow is offline   Reply With Quote
Shno's House of Z Number 3 Camaro Z/28 Forum - Z/28 Specific Topics 17553 02-12-2018 03:59 PM
BREAKING: 2012 CAMARO ZL1 - 6.2L LSA Supercharged - 6MT Revealed! Tran Camaro ZL1 Forum - ZL1 Specific Topics 756 05-01-2013 07:22 AM
More Camaro ZL1 info!!! MS3DALE Camaro ZL1 Forum - ZL1 Specific Topics 94 06-24-2012 10:44 AM
Spied: Camaro ZL1 Track Package / High Performance Package In Testing?! Tran Camaro ZL1 Forum - ZL1 Specific Topics 321 10-21-2011 10:08 PM
