Old 04-02-2012, 08:31 PM   #1
EvoWake
SSTOCK
EvoWake's Avatar
Drives: 2010 Camaro 2SS/RS
Need some help! Clutch snaps up and down stuck in parking lot.
2010 Camaro 2SS/RS
EvoWake is offline   Reply With Quote
Old 04-02-2012, 08:32 PM   #2
The Stig
knows 2 facts about ducks
The Stig's Avatar
How much fluid did you lose? With the car on, pump the clutch pedal 6 or 7 times while leaving the shifter in neutral
Click to view my build thread
Old 04-02-2012, 08:34 PM   #3
EvoWake
SSTOCK
EvoWake's Avatar
3 oz maybe ? I tried that... Simply snaps up and back.
2010 Camaro 2SS/RS
Old 04-02-2012, 08:36 PM   #4
EvoWake
SSTOCK
EvoWake's Avatar
Feels as though the cylinder is drawing on a vacuum when you try to pull the pedal away from the floor and the springs of the pedal are the only thing allowing it to return to the top
2010 Camaro 2SS/RS
Old 04-02-2012, 08:46 PM   #5
EvoWake
SSTOCK
EvoWake's Avatar
Running across the street to grab some fluid to top off and try again
2010 Camaro 2SS/RS
Old 04-02-2012, 08:49 PM   #6
The Stig
The Stig's Avatar
good idea. I was about to ask how easily you could get fluid
Old 04-02-2012, 08:57 PM   #7
EvoWake
SSTOCK
EvoWake's Avatar
No luck. Looks like it dumped more.
2010 Camaro 2SS/RS
Old 04-02-2012, 09:03 PM   #8
EvoWake
SSTOCK
EvoWake's Avatar
Next question: is this something typical of these cars, or is this a fluke? I know I've read about a clutch sticking problem.
2010 Camaro 2SS/RS
Old 04-03-2012, 09:15 AM   #9
600hp-lpe
Drives: 2010
sounds like you got air in the system.. after the fluid loss.
600hp-lpe is offline   Reply With Quote
Old 04-03-2012, 09:16 AM   #10
EvoWake
SSTOCK
EvoWake's Avatar
Ended up towing back to my garage. Going to call up my local dealer and see if I can get a warranty claim on it.
Any advice from you guys on how to tip toe around this one, or is it the crap-shoot i'm expecting?
2010 Camaro 2SS/RS
Old 04-03-2012, 10:16 AM   #11
EvoWake
SSTOCK
EvoWake's Avatar
Thanks for your input by the way guys
2010 Camaro 2SS/RS
Old 04-03-2012, 10:26 AM   #12
nuptualnemesis
NuptualNemesis
nuptualnemesis's Avatar
Drives: Silver 1SS M6 - 480hp 11.57/120.79
This happened to me when my slave cylinder went out. The slave cylinder is specifically included in the warranty.
nuptualnemesis is offline   Reply With Quote
Old 04-03-2012, 10:55 AM   #13
The Stig
The Stig's Avatar
Yea you should be covered under warranty.
Old 04-03-2012, 11:11 AM   #14
EvoWake
SSTOCK
EvoWake's Avatar
Even with extensive modifications?
Obviously this type of failure of the fluid power system is not directly related to the power level, however i'm sure they'll try to pitch that. Hopefully when I tell them I smelled friction discs glazing up as I limped off of the street I'll get a new clutch too.
Thanks Again Guys!
2010 Camaro 2SS/RS
