Old 04-02-2012, 09:23 PM   #1
blake-b
blake-b's Avatar
Drives: Black 2010
Does this look right? M6 Trans and wiring harness
Is the wiring correct?
1 and 4 will interchange. If I put 1 where 4 is in the picture, 2 won't reach. I know 1 is the CAGS and 4 is the reverse lockout. I guess if I can't get it into reverse I know the answer.
I just want to make sure I have it correct for new labeling.
Thanks.
Old 04-13-2012, 10:34 PM   #2
milesss
milesss's Avatar
Drives: 2010 hurst, 2-69s, 65 vette
i ran into the same deal, i bought a car with the drive train out of it. i ended up printing out a wiring diagram from the internet that showed what color of wires went to what. hope this helps.
milesss is offline   Reply With Quote
Old 04-14-2012, 12:06 PM   #3
blackonblacksls
Drives: 2011 2ss/rs
they will only fit one way.. Like you said, if you connect them wrong, 1 of the others will not work.
blackonblacksls is offline   Reply With Quote
Old 04-14-2012, 11:16 PM   #4
blake-b
blake-b's Avatar
Drives: Black 2010
I looked but couldn't find a good wiring diagram. I went ahead and installed it with the way it looks in the pic because that is the only way I could get them all plugged in.
BTW-putting that trans in was, BY FAR, the hardest thing I have done on the car. It was on jackstands, I used a trans jack for the front of the trans and used a floor jack under the tail of it so I could get the angle correct... I hope the clutch lasts awhile so I don't have to pull it again anytime soon.
B&M 70274 cooler into 5th gen (with 4L80) DietCoke V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 7 06-22-2013 08:54 AM
BMW Headlight Conversion *video added* wylde1 Cosmetics and Lighting Modification Discussions 110 05-29-2013 10:02 AM
Need Wiring Diagram carbon8 Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 1 03-12-2012 07:22 AM
1997 LT1 and T56 Trans ZooDad V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment 11 02-04-2011 05:30 AM
Wanted L99 / LS3 engine complete with computer & harness SSRSMAGNACONV Autos For Sale / Wanted 1 07-31-2010 08:38 PM
