Gen5DIY
Old 04-02-2012, 10:37 PM   #1
camaro1
camaro1's Avatar
Drives: 550+RWHP 2010 camaro
oil catch can, amount
how much oil are you guys getting,, i have about 1000 miles and not a drop of oil from the catch can. drawing from the valley cover and i know i was getting oil before because the hose was wet inside that went from the valley cover to the intake.
Old 04-02-2012, 10:49 PM   #2
rberns
rberns's Avatar
Drives: 2011 Camaro 2SS/RS
Not sure yet, I haven't even driven 100 miles with mine on so I bet if there is any inside there only be a couple of drops or so.
2011 Camaro 2SS/RS, Circle D 3200, ADM Transmission Cooler, BTR Valvetrain, Cam Motion .621 .595 228/244 113+4, ARH 1 7/8, Cold Air Inductions, Katech C5R TC, Melling HV, BTR SLR lifters, Trunion Upgrade, LS2 Dampner, LS9 head gaskets, Bo White PTB, RX CC, GFX, Subs.
rberns is offline   Reply With Quote
Old 04-02-2012, 10:54 PM   #3
Kmorpheus
Drives: Green Dream Machine
I get a half oz to an full oz every 1000 miles.
Kmorpheus is offline   Reply With Quote
Old 04-02-2012, 10:55 PM   #4
stso634
stso634's Avatar
Drives: 2010 Camaro 2SS/RS
Same amount here. My can was installed about 1 year ago.
stso634 is offline   Reply With Quote
Old 04-02-2012, 11:10 PM   #5
epstein
Drives: SS/RS
Send a message via AIM to epstein
2-4 oz every oil change
epstein is offline   Reply With Quote
Old 04-02-2012, 11:11 PM   #6
BullF-16
USAF retired! Thank God!
BullF-16's Avatar
Drives: 2011 1SS, 1LT red,1LT/RS SGM 98Z28
Make sure the valve on the bottom is closed. I.E turn it counter clockwise when looking down at the top of the can or imagine you are looking at the bottom of the can from underneath the car and turn it clockwise, righty...tighty. also you will see the threads on the valve exposed. if the can is open you wont see the threads.
look at the color of the clear hose from the valve. If it is discolored brownish at all it was open and always draining.
Also make sure the center port on the CC goes to the valley cover port or the rear of the drivers side valve cover port and the outer port on the CC goes to the nipple on the Maggie. I dont have a PD blower but i have done a lot of research and this should do it. Good luck.
HKE LSX427(Mast blk lbl 305 6bolt LS7heads, PatG231/246 blower cam, RWHP/TQ: 1281/1133 SNL Performance Custom Twin PT6766 BB turbos 4 to 25psi selectable on the Boost Leash controller, Squash dual 400LPH/ID2000s, ALKY 4 gal meth, Autometer AFR/Bst/oilpres/oiltemp/fuelpress gauges, Pedders Justice road crs pkg: All HD bushes, supercar 12kg coil overs, supercar ZL1 sways, camber plates all setup by JusticePete! :Gforce 9" 35spline S-Trac, 1500hp Outlaw axles, 3.5"alum DS, Monster Triple disc; 4xForgeline 19x10.5 4xBridgestone 305/30R19 RE-11, CTS-v calipers/rotors/Cobalt friction XR1/3 pads
BullF-16 is offline   Reply With Quote
Old 04-03-2012, 11:01 AM   #7
SSDan
SSDan's Avatar
Drives: 2016 1SS 6MT NPP
I'll admit that turning the valve the wrong way to close was very easy mistake for me. After I drained my can for the first time - I got distracted looking at the oil I caught and didn't close the valve right away. When I got back to it I had forgotten which way I tunred it to open it and got it wrong. I drove around for two days with the valve wide open.
I started getting weird idle issues and noticed a new strange sound under the hood. With the engine running I put my finger at the bottom of the drain valve and the vacuum was so strong it about sucked my finger up into the can (a dramatic overstatement but it was a strong suction). Closed the valve and all went back to normal. So, if you trapped no oil there is no harm in double checkling that the valve is closed. Here is a photo of mine closed properly with the thread exposed just as Bull F16 states.
To the OPs original question - I caught about 5 oz. of oil. Those 1300 miles were pretty hard ones - I must admit. Several dyno runs to get the tune calibrated after the cam install and then many WOT 1-2-3 runs enjoying my new power. The word is that LS engines push blow-by at high RPMs and I guess mine is one of them.
2010 Camaro 2SS Cam/Headers/CAI/3.91 gears
476 rwhp/440 rwtq (sold)
SSDan is offline   Reply With Quote
Old 04-10-2012, 10:41 AM   #8
camaro1
camaro1's Avatar
took the can off just to check things out,, felt like it had something in it so i pulled the valve out of the bottom and sure enough it had some oil in it,, looks like something was plugging up the valve, cleaned it all and re-installed. good to know it is working fine!
Elite Engineering PCV Oil Catch Cans | Instock | Best Prices with Free Shipping! JDP Motorsports V8 Bolt-Ons & Tunes 137 08-13-2014 04:06 PM
Oil Changes FaytalsCamaro 5th Gen Camaro SS LS LT General Discussions 14 03-29-2012 08:48 PM
Great Read and Info on Oil Weight Banshee Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 1 11-23-2009 10:03 PM
