SDTW Custom Wheels & Tires
Old 04-02-2012, 10:05 PM   #1
Kyle2k
LVL 50 Troll Stomper
Kyle2k's Avatar
Drives: 2010 Camaro
Tune with gears?
So I have an automatic and I am aware that a tune is required for proper shifting if you change the rear gear ratio. However, I intend to get other things installed later this year and I was wondering if I can go without the tune if I keep it out of WOT for the time being? Thanks in advance!
Kyle2k is offline   Reply With Quote
Old 04-02-2012, 10:19 PM   #2
The Stig
knows 2 facts about ducks
The Stig's Avatar
you have to get the speedo tuned after swapping gears. Totally different than the tranny tune
Click to view my build thread
Old 04-02-2012, 10:33 PM   #3
Kyle2k
Kyle2k's Avatar
Drives: 2010 Camaro
I could care less about the speedo, I swear I heard someone say the transmission needs to be tuned to shift properly on the auto though?
Old 04-02-2012, 11:20 PM   #4
klatterblast
klatterblast's Avatar
Drives: 2010 camaro 2ssrs blk.
I think shift points , it will hit the rev limiter before it shifts I think. Not 100% sure though. You could tap shift and be good . Or just take it easy no full throttle shifts in D or S in the lower gears. Speedo will log more miles than it should.
T-BONES BLACK 2SSRS TEAM L99
CAI w/ADM scoop,Magnacharged 3.8 pulley,L92 ported heads,ss valves,patriot springs,yella terra rockers,Comp cam,L99 to LS3 conv.ATI super damper,Taylor plug wires,NGK plugs,ARH 1 7/8 lt headers w/Borla stingers,Elite oil catch can,trans cooler,Jannetty built Richmond 4.11 rear end,Spohn trailing arms,front Racing Brake rotors,Hawk hps pads,BMR end links,AACstyle lighting. Thanks to Shane & crew for engine work at Thunder Racing & tuner Jeoff at EPS. 501rwhp-463rwtq ++
klatterblast is offline   Reply With Quote
Old 04-03-2012, 05:15 AM   #5
toml_pa
ʇuɐıʌǝp lɐıɔos
toml_pa's Avatar
Drives: 2011 2SS/RS LS3/M6
If you don't change the gear ratio to match the gears in the calibration (tune), you will constantly get ABS brake related Diagnostic Trouble Codes (DCTs). This is because the computer constantly monitors each wheel's speed (RPM) and expects the reading to be within a certain range. The range it looks for is determined by several factors such as gear ratio, transmission gear, and engine RPM. If the programmed gear ratio is incorrect, wheel speed will be outside the range and you will get DCTs. The transmission control module also uses wheel speed along with other factors to determine when to shift into a lower or higher gear. If the wrong gear ratio is in the calibration, wheel speeds will be out of range and the transmission will not shift at the correct time. So you are correct that it will not shift properly. Personally, I would only drive the car from the gear shop to the tune shop to have the correct ratio put in. With the DCTs and screwed up shifting the car's driveability is going to suck. I would try to find a tuner who is willing to work with you. Explain your plans and see if you can work something out.
Way too many mods and way too much money. Wouldn't have it any other way.
toml_pa is offline   Reply With Quote
Old 04-03-2012, 07:40 AM   #6
IndeedSS1
IndeedSS1's Avatar
Drives: 2010 Camaro SS LS3
I wouldn't drive it until the transmission has been tuned to match the gears. Depending on how it reacts you could break hard parts. I had gears done on my Impala SS. For a very short period of time the tune wasn't exactly right and when it shifted it felt like I had dropped in a really big pothole. The speedo calculations were slighly off.
She is only memory now.
IndeedSS1 is offline   Reply With Quote
Old 04-03-2012, 11:27 AM   #7
swiftkart
swiftkart's Avatar
Drives: 2010 SS/RS LS3 M6
I hear the manual 6 spd doesn't need retuning, is that correct? Does it relearns after a gear swap on the manuals and corrects the speedo for you? Sorry to thread jack, but I'm thinking of changing the gear in my LS3 and was wondering the same thing.
swiftkart is offline   Reply With Quote
Old 04-03-2012, 12:18 PM   #8
MA2010SS
You will have to adjust the calibration in the tune for the gear swap, via HP Tuners, SCT, EFI Live etc
2010 Camaro SS Whipple SC, CAI Inc Intake, TSP 1 7/8" LT headers no cats, 3" magnaflow exhaust, HPT, RX Catch Can, LSR Toe Rods, LSR Trailing Arms, ALKY Control Meth, McLeod RXT Twin Disc, ZL1 fuel pump, 3.73 ZL1 Differential Kit, BTR PDS Stage 2 Cam, Tuned by SLOWHAWK Performance Bridgewater MA
MA2010SS is offline   Reply With Quote
Old 04-03-2012, 12:30 PM   #9
Kyle2k
Kyle2k's Avatar
Drives: 2010 Camaro
Hrmmm, okay, because the tuner is about 200 miles away and I don't really want to spend an extra 400 for a programmer when I'm going to get an a custom dyno tune less than a week later, but I guess if I have to....
Old 04-03-2012, 04:13 PM   #10
swiftkart
swiftkart's Avatar
Thank you!
Old 04-03-2012, 05:43 PM   #11
tonetone
Drives: 2010 Camaro 2SS IOM M/T
Been considering a gear swap myself and had the same question.
LPE has a set of 3.91 gears and the product information section says:
"Manual transmission vehicles do not require ECM calibration changes to correct the speedometer. Automatic vehicles will require ECM calibration changes to correct the speedometer."
I'm no expert just pasted what's on the site
tonetone is offline   Reply With Quote
Old 04-03-2012, 08:08 PM   #12
MA2010SS
Any vehicle when you change the ring and pinion to a different ratio will throw the speedometer off regardless, olden days you would change the speedo gear in the trans, now you will have to adjust within the tune the calibration of the speedo via HPT, SCT, EFI Live etc, hope this helps
Rear End Gears 101 danhr V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 82 08-04-2017 11:38 AM
Richmond Gear Camaro gears RichmondGear V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 85 01-19-2015 10:43 AM
MarylandSpeed DYNO TESTED: Diablosport Predator Canned Tune on 2010 SS A6 MarylandSpeed Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 27 05-18-2013 10:01 PM
Standard vs Automatic Racing HarrisraTx Dragstrip and Launch Techniques Discussion 74 10-29-2010 09:26 PM
Supercharger tuning: Why shop tune instead of tune with the S/C? JProberts Forced Induction - V8 10 12-28-2009 03:54 PM
