Old 04-03-2012, 11:21 AM   #1
GlennP
Drives: 2011 Camaro 2SS
My exhaust is saggy :(
I have ARH headers, HF cats, X pipe, and stock axle back. A month or so after installing it was tapping my brace. I got the elite engineering brace and it went away for about a month, maybe even less. Then it came back. So I got under the car, loosened everything, wedged the X pipe wayyy up a few inches off the brance, tightened everything with a breaker bar and all was good for another month, or a little less (again...) and now...
...its tapping again on bumps and its very close to the brace.
Why wont it stay put?!
GlennP is offline   Reply With Quote
Old 04-03-2012, 11:30 AM   #2
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
Because there are only clamps holding it together.
You probably have these clamps.
My experience has been that these cheaper clamps work better at keeping exhaust from sagging.
Obviously the best solution is to ditch all the clamps and weld all the entire exhaust together. That's what I always do.
SUX2BU is offline   Reply With Quote
Old 04-03-2012, 11:32 AM   #3
kevin1106
kevin1106's Avatar
Drives: 2015 ZO6 3LZ Stage 2 A8
loosen everything and start over...use a jack to push up on the exhaust by the cross member... then torque the hell out of everything.. start at the headers and work your way back....
kevin1106 is offline   Reply With Quote
Old 04-03-2012, 12:22 PM   #4
A.R. Headers
A.R. Headers's Avatar
Drives: Pontiac G8 GT
Glen, Please PM me a contact number where I could reach you. I have some helpful tips that will cure this. If I need to send you new clamps I will. You also need to make sure the X-pipe wasn't installed upside down. That's happened a few times by very enthusiastic Camaro owners anxious to get the job done.
Sux2BU, The clamp you posted a photo of is not what we provide. We supply clamps from Accuseal which is exactly what GM, Ford and Chrysler has used for years for OEM applications. They are extremely high quality and torqued properly (45-50 ft lbs.) work excellent.
Nick
www.AmericanRacingHeaders.com
100% USA MADE
A.R. Headers is offline   Reply With Quote
OK...I'm starting a better V6 exhaust examples thread!! KMPrenger Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 606 01-19-2018 05:18 AM
Official 1/4 Mile (V8) 2010+ Camaro Fast List Merc Dragstrip and Launch Techniques Discussion 3448 01-15-2018 12:30 AM
Unofficial 1/4 Mile (V8) 2010+ Camaro Fast List Merc Dragstrip and Launch Techniques Discussion 250 04-01-2014 11:40 AM
Exhaust Theory revisited Wacker Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 3 11-23-2009 11:12 AM
