| Cosmetics and Lighting Modification Discussions External and Internal cosmetics modifications. |
Thread Tools |
sanity check: non-rs halo lighting, adding a switch
I've got a non RS that I added a bunch of Oracle lighting from AAStyle to this weekend.
I have NON-RS headlights/foglights with a single color (orange) halo. Because I didn't want to drill into the dash (yet) and because it was easiest, I tapped the side markers for the halo connections on on the head/fog lights. Currently the halos are on when: a) The headlights are turned on b) when the parking lights are on b) The foglight switch is set to fog lights on (turns on headlight and foglight halos as well as fog lights themselves) What I want to do is use an oracle LED switch to turn the halos on/off (and potentially to turn on/off grill lighting if I add it later). I've perused the forums for details on how to change my setup but wanted a sanity check from experienced DIYers (I am a total noob). My understanding is that to power the LED on the switch I can use a fuse tap. I identified two on the autzone website: "Cooper Bussmann/ATM fuse tap" and "Cooper Bussmann/ATC fuse tap" Both state "converts one into two fusible circuits - 10 Amps maximum on added circuit" but I am not sure which one is appropriate. I am guessing I use one of those to tap and hook to the pos on the LED switch and then the ground to the negative pins on the outside of the switch. The inside of the switch has 3 more pins. I am a little confused after reading all the DIY threads on what to connect to the switch? The once I found were for 2 color halos on RS equipped vehicles... I know I need to tap some 12V power source for the four halos, but am not sure where/how to do so (I am guessing the fuse box under the hood, but not sure how) and how the wires should run from the halos through the firewall to the switch and ground.
My V6 build thread: http://www.camaro5.com/forums/showthread.php?t=213540 - gone but not forgotten, my 1st Camaro
My V8 build thread: doesn't exist yet! Too busy modding! |
Here is a wiring diagram to kind of explain what I am trying to figure out....
![]() Also wondering what gauge of wire I should use...18?
| Thread Tools | |
| How To Wire Dual Halos On Single Switch | kismyss | Camaro DIY & HOW-TO instructions & discussions | 53 | 04-23-2012 07:00 AM |
| fieldgoal00 DRL harness group buy #1 | FwyFlyer | Exterior Parts & Accessories | 41 | 08-08-2011 08:55 AM |
| Halo Headlamps WITHOUT RS for the 2SS FROM FACTORY? | gglefty | 5th Gen Camaro SS LS LT General Discussions | 18 | 04-27-2011 12:40 PM |
| QUICK AAC lighting Halo Question! RS Camaro - Ordering in about an hour. | crewxp | Cosmetics and Lighting Modification Discussions | 13 | 02-02-2011 06:05 PM |
| Voice Your Comments/Suggestions/Input for Focus Group on 2010 Camaro | Mr. Wyndham | 5th Gen Camaro SS LS LT General Discussions | 236 | 04-22-2008 12:43 AM |
