| Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum All audio, video, bluetooth, nav, radar, and electronics discussions. |
Thread Tools |
![]() Drives: 2011 Camaro 2SS/RS Join Date: Nov 2011
Shuffle setting for USB
Hey All,
Keep a USB thumb drive plugged into the USB port in the console. In order for the stereo to shuffle the songs, I have to go into the settings and choose shuffle music every time I start the car. Have been unable to find a way to keep that setting. Has anyone happened to find a way? Thanks Scooter
2011 2SS/RS
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2SS/RS Join Date: Sep 2008
There was an issue with an early version on the software where it wouldn't keep the random option on when you turned off the car. This issue has since been fixed through a update. What you need to do is go to your local dealer, tell them you've been having issues with it and ask for a PDIM software update.
... well, not yet.
Drives: 2012 Chevy Silverado ZL1 Join Date: Apr 2011
Does this apply to iPod also? Seems like mine always needs reset?
Not sure. I use a USB drive and don't have an ipod to test it.
Master of All Things
Drives: '10' Camaro 2LT/RS,'08' Caddy STS Join Date: Jul 2009
YOU DO NOT want to have the dealer do a software up-date....that will NOT fix his problem. There is a TSB (Technical Service Bulletin) that will get you the latest Hardware and Software for your system. just the UPDATE will not do it.
i have gone through this already.....and this is the fix. Attached below is a copy of the TSB, on the top of it is the GM P/N you will need them to order and install. print it out and you take it to your dealer and have them install the new PDIM ...... btw......this is 100 % warrantee work. PI0055B with GM PN#.pdf
#6 |
YES IT DOES....you too will need to do the same.
| Thread Tools | |
| How can I shuffle songs with an Android via USB? | stt816 | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 8 | 03-27-2012 08:10 AM |
| What is the proper Wheel Alignment? Is there a specific setting? | CamaroBC | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 7 | 03-21-2012 06:55 PM |
| Setting 5 | toilets | Camaro ZL1 Forum - ZL1 Specific Topics | 29 | 02-01-2012 11:22 AM |
| Adjustable sway bar setting for daily driver? | JProberts | Suspension / Brakes / Chassis | 128 | 12-01-2010 11:19 PM |
| New iPod Shuffle | destroyer4 | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 12 | 07-25-2009 02:08 AM |
