Flowmaster Exhaust
Old 04-03-2012, 08:15 PM   #1
bvcamaro
Drives: '12 LFX
Question '12 LFX Cat Delete
Anybody heard anything about this? Would it really be beneficial? Since it bolts directly to the cyl. head, improving flow here would be similar to adding headers...but then again, it might not improve much. Thoughts?
bvcamaro is offline   Reply With Quote
Old 04-03-2012, 09:52 PM   #2
KMPrenger
KMPrenger's Avatar
Drives: 16 SS Camaro, 06 Colorado
In my opinion it would definitely be beneficial, and I think someone like SOLO needs to offer this soon. Their HFC + resonator kit for the 2010 and 2011s was dyno'd at an additional 15 HP over stock.
Have you looked at the tube before the cats? Is there a flange there that could be unbolted, or does the tube go straight to the cat as one piece? You'd think GM would have put a flange there to make changing the cats easier, but maybe not
Anyways, I think this is really the LFX's best chance at getting gains similar to LT headers on the LLT engine. May not be quite the gains, but you guys area already starting out with more power anyways. I'd bet 10 to 15 rwhp with something like a SOLO HFC would be doable.
Old 04-03-2012, 10:58 PM   #3
bvcamaro
Drives: '12 LFX
Well there are four NUTS (so even after soaking them with PB we're gonna break those rusty studs lol) and then the cat unbolts from the head. Then obviously disconnect O2's and the whole thing drops out. (Only a muffler clamp connects it to the rest of the exhaust.)
Old 05-02-2012, 07:53 PM   #4
bluecam805
Team LFX
Drives: 2012 Camaro LS
well its alot cheaper too. im gonna get my cats taken out and ask to get the biggest down pipe for maximum air flow.. $120 for BOTH . hopefully i get alota gains
bluecam805 is offline   Reply With Quote
Old 05-03-2012, 12:55 AM   #5
JohnnyBfromPeoria
JohnnyBfromPeoria's Avatar
Drives: 2012 LS M6, Black
Good luck.
I'd like to see your theory proven, rather than accept the "butt-dyno" results. Frankly, I'm skeptical. Why do you suppose bigger downpipes will help? Why are the stock downpipes the size they are now?
John B.
12 LS M6, IPF S/C, ASA GT-5 wheels, VMax PTB
1995 Mitsubishi Montero SR
1987 Dodge Raider Turbo Project
1986 Mitsubishi Montero 2.4l FI Transplant
JohnnyBfromPeoria is offline   Reply With Quote
Old 05-03-2012, 12:58 AM   #6
JohnnyBfromPeoria
I don't miss growing up in Peoria, IL. Nothing seems to rust here in Phoenix. I can unbolt exhaust systems that are 20 years old without problems here...as long as they haven't been 'there.'
John B.
Old 05-03-2012, 02:06 AM   #7
bluecam805
Team LFX
yeah im skeptical myself . not too big but probably 2.5 or so. im not sure the size now. ill see tomaro
Old 05-03-2012, 09:26 AM   #8
KMPrenger
KMPrenger's Avatar
I really don't think I'd go with bigger than stock pipes to replace the cats, and instead go with the stock size. I can't say forsure, but I'm guessing it is the same size as the beginning of the catback...which is 2.5"
I don't see how you couldn't get gains from removing the cats, or at least adding HFCs. Its been proven on the LLT.
Old 05-03-2012, 01:52 PM   #9
bluecam805
Team LFX
Yeah ima go 2.5 all the way down eventualy . rite now cat delete , later cat-back. i oredered a trifecta tune so hopefully with tune and all ill see some noticable gains
Old 05-08-2012, 12:33 AM   #10
bluecam805
Team LFX
just had them istalled. RASPY! would mufflers like a magnaflow or flowmaster help eliminate the raspy noise?? i want DEEEEEP tone
Old 05-08-2012, 12:43 AM   #11
lscamaro
lscamaro's Avatar
Drives: 2011 CGM Camaro LS A6
Magnaflow maybe, flowmaster.... Uh no.
Have you thought about a magnaflow resonated x pipe? It will probably do exactly what u want
Old 05-08-2012, 12:53 AM   #12
bluecam805
Team LFX
yeah i was told flowmaster sounds bad and that resonater would muffle the sound nice.. but i didnt want to put more ristriction but its better than putting the cats back on. what magnaflow though?? i wana try gettn the largest maybe? for that DEEP tone
Old 05-08-2012, 01:23 AM   #13
lscamaro
lscamaro's Avatar
The one I'm talking about is a dual in dual out that people replace the h pipe with. It reduces rasp drastically. I'm sure if u do a quick search you'll find it since so many have used it. I'll try to get a part number
Old 05-08-2012, 01:25 AM   #14
bluecam805
Team LFX
thanks that would be great! i read em but cant find a part number. u think i can make due without the resonator? kind of on a budget. so like just an axle back with tips?
Cat delete shortie headers worth it ? Turbo car 1969to2010 Forced Induction - V8 13 07-18-2012 04:36 PM
Cat delete off road pipes for sale 165.00+S/H Ronin_2SS Local Marketplace 1 10-05-2010 09:05 PM
CORSA CAT BACK EXHAUSTS @ BEST PRICES! MoranoRacing V8 Bolt-Ons & Tunes 9 08-24-2010 10:09 PM
SPINTECH CAT BACK EXHAUST INSTALL/SOUND VIDS 1969to2010 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 6 03-23-2010 09:02 AM
Just installed my Magnaflow 3" cat back system...first im[pressions Heelhook22 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 17 02-06-2010 12:50 AM
