JDP Motorsports
Old 04-03-2012, 08:38 PM   #1
zkengo
zkengo's Avatar
Drives: 2010 Camaro SS M6
Stainless Power Headers
I just unpacked my new Stainless Power headers. I have some concerns about installing them. It came with rtv sealant which i have no intention of using. I will be reusing factory gm gasket. My concern is I`m not sure they will seal properly without some minor touch ups. On both headers, the welds on the primaries at the flange bother me. On a couple of the primaries the openings are perfectly flush with no weld protruding. On the rest it looks like I need to use a Dremel to smooth it out. Should I grind it flush or do you think it will seal ok against the factory gaskets. Here are some pics taken with my Android phone.
zkengo is offline   Reply With Quote
Old 04-03-2012, 09:08 PM   #2
Camarowguy
Camarowguy's Avatar
Drives: 2011 imperial blue SS, black 92 RS
If it were me, I'd flatten them with a big machinists file.
2011 imperial blue SS/RS a6 12.43@112 vararam, tune, jba cats, magnaflow axle back, self ported tb, under drive pulley, NO headers, Stock tires. 1.87 60ft. Stock tires.
2000 1500 silverado extra cab
Camarowguy is offline   Reply With Quote
Old 04-04-2012, 01:30 AM   #3
2012ZL1
CaRaHoLiC
2012ZL1's Avatar
Drives: '12 ZL1,67 Cam,68 Biscayne 427 4 sp
the flange needs to be flat and true.
2012 ZL1
2.55 upper, 10" lower pullies, Innovators west billet hub and sfi balancer, solid blower drive isolator, 50 mm idler kit, full length S/S headers no cats, comp cams custom grind cam, comp roller rocker trunion kit, comp push rods,dual valve springs retainers and locks, Injector dynamics ID850 inectors, Rotofab ZL1 cold air kit, Lingenfelter 160 thermostat, Rotofab intercooler reservoir, stock plugs, LS7 90mm throttle body, GTO clutch reservoir mod, my own custom catch can, Tuning by Jannetty, install by me.
2012ZL1 is offline   Reply With Quote
Old 04-04-2012, 10:57 AM   #4
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Yeah - find a true file and just make sure they're flat. It's better safe than sorry. Those don't look too bad anyways
05 Hummer H2 SUV on OEM Air Ride
Forged 11.4:1 408 LQ4 (K1 crank & rods; Mahle pistons)/CPP LS3 CNC heads/BTR Stage IV LS3 cam/home ported L92 intake manifold/ported 90mm TB/custom Volant CAI/Kooks 1 7/8" LTs and 3" H-pipe/AFE dual 3" CB/Corvette Servo/el cheapo lift/Cognito UCAs/Sphon poly adjustable TA/Sphon adjustable rear LCAs/e'fan conversion/DirtyMax radiator/Moroso catchcan/HPTuners/HID conversion/LED exterior lighting/LED interior accents/Autometer Cobalts/AEM WB/ Pioneer AVH-5600BHS/Pioneer GM-9601/2-Pioneer TS-W310D4s/Obcon Labyrinth dual-12 box/lots of other little stuff
Old 04-04-2012, 11:30 AM   #5
zkengo
zkengo's Avatar
Thanks guys I just wasn`t sure about grinding the weld down. With them being welded overseas I wasn`t sure how deep the weld would be or how good. The welds look very clean but on a couple as you can see it looks a little sloppy. 1 of the ports looks like someone used a deburing bit and got a little carried away. As far as the rest of the headers, they look badass. The hi-flow cats that come in the kit look awesome.
Old 04-04-2012, 11:40 AM   #6
SlingShot
SlingShot's Avatar
Drives: 2012 ZL1 - #670
You'll have to use a grinder or belt sander, a file won't work on the weld.
Old 04-04-2012, 03:43 PM   #7
2012ZL1
CaRaHoLiC
2012ZL1's Avatar
How much were these headers? I just got a stainless set that looks the same (minus the welding errors on the flange) for 299.95
2012 ZL1
Old 04-04-2012, 09:07 PM   #8
zkengo
zkengo's Avatar
Stainless Power (Stainless Works) 1 7/8 with 3" slipfit collector, 3" hi-flo cats, O2 extentions, 3" to 2.5" reducers with o2 bungs, plus clamps and bolts $799 shipped. Had them ship to a buddy`s Florida address and he brought them up to Ottawa when he came back from vacation.(No duty,No tax and no f***in rip off brokerage fees). I was going to go with a set of TSP but they told me that the kit didn`t come with rear o2 bungs.
Old 04-05-2012, 08:06 AM   #9
ZO6 Bryan
ZO6 Bryan's Avatar
Drives: 02 Z06, 95 Trans Am, 2012 ZL1
Why were they welded overseas. Isn't Stainless Works in Ohio. I'd be sending them back. Looks like they didn't finish the flange surface after welding. Every decent set of headers I've seen has the flange machined flat after the welds are done. Headers are a pain in the ass to install and those look like they will leak and be ticking all the time. RTV will seal initially but ultimatly would be blown out by exhaust pressure.
ZO6 Bryan is offline   Reply With Quote
Old 04-05-2012, 08:09 AM   #10
ZO6 Bryan
ZO6 Bryan's Avatar
Actually it looks like the flange WAS machined flat and they went back and re-welded a couple tubes.
Old 04-05-2012, 08:19 AM   #11
zkengo
zkengo's Avatar
Stainless Works has another brand called Stainless Power. They started this line to compete with chinese knock offs. They send the flanges and the prebent pipe overseas and have them welded to their specs, then ship them back to Ohio. This apparently save them a lot of money, so they`re able to sell them cheaper.
Old 04-07-2012, 05:50 PM   #12
2012ZL1
CaRaHoLiC
2012ZL1's Avatar
cheaper yet are the same headers from MBS...299.95
Mine came in and they are awesome. SS, merge collectors, installs to stock pipes,02 bungs installed, studs and gaskets not silicone.
2012 ZL1
Old 04-08-2012, 06:54 PM   #13
zkengo
zkengo's Avatar
They are exactly the same as their Stainless Works headers. Exact same tubes and flanges just that they are assembled overseas. They also have the merge spike. They look nothing like yours. Yours look just like the Borla`s. Can`t install cats on them unless you want to hack them up. Stainless Power/Stainless work don`t have the same fitment issues I read about the MBS on another thread. I took a straight edge to mine and it wasn`t to bad around the welds. Took a dremel with a stone bit smoothed them right out.
Old 04-12-2012, 11:06 AM   #14
2012ZL1
CaRaHoLiC
2012ZL1's Avatar
Oh.
Well they look like the ones you recently pictured, except the collectors are merge collectors on mine not like the box collector on the stainless works.
Slip on cats as you pictured are no problem on the MBS, although I am not using any anyway so doesn't matter to me.
Straight edge mine are perfect exactly true. I always split the flanges on all headers anyway as are the oem's, so I never have a leak problem on any headers flat or not.
Not diss'in your headers in any way, just offering an alternative idea that I have had good luck with so far anyway. Haven't installed them, so we will see.....
btw I don't see them on their site anymore, so maybe discontinued?
2012 ZL1
New Camaro Exterior and Interior Stainless Steel Trim Parts from RPI Designs! RPI Designs Cosmetics and Lighting Modification Discussions 36 06-25-2017 09:57 AM
WOW!!! New Stainless Power Line Headers JANNETTYRACING Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 87 04-16-2015 11:59 AM
Stainless Power headers by Stainless Works sound amazing! Video Clip The SwiftChancelor Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 5 02-28-2012 06:41 AM
Stainless Power by Stainless Works V8 Camaro Headers w/DiabloSport Predator $1199.00 Xplosive Performance V8 Bolt-Ons & Tunes 20 12-01-2011 04:23 AM
Stainless Power by Stainless Works V8 Camaro Headers starting at $699.00 Xplosive Performance Local Marketplace 1 11-19-2011 06:31 PM
