Frankenstein Engine Dynamics
Old 04-04-2012, 09:38 PM   #1
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
Adams Wet Sanding Supplies............
Figured that would get Adams attention.
Ok. So I wet sanded my front fascia after I had it painted and had the painter give me some thick clearcoat.
Using swirl and haze remover I got it to a high shine but when I look at juuuuuust the right angle it's not hard to see the lines. From the 3000 grit sandpaper/cloth.
I fear that when I get it out in the sun it will look bad. I can't imagine it because it's shining so much but I need it to be better.
The lines look like they are in the paint under he glossy smooth clear but I know they aren't because I can literally change the direction of the lines by sanding in the other direction. (I have plenty of clear on it)
So I tried different sanding techniques, different polishing techniques with the orange pad and SHR and come up with the same super shiny, yet lines if you look deep.
3000 grit is the most common sandpaper and the SHR just doesn't 'cut' it.
So my question is..................
Does the Severe Swirl and Haze Remover cut better enough to take care of this or is there a compound I can use first?
Old 04-04-2012, 10:07 PM   #2
jeffny09
jeffny09's Avatar
Drives: 2010 camaro
Send a message via AIM to jeffny09 Send a message via Yahoo to jeffny09
pm sent
top 10 reason why real men drive stick.
10. A manual transmission is the ultimate in control
9. You can use automotive jargon and not sound like a total tool
8. You can't spell "manual" without "man"
7. Manual transmissions prove you can do more than one thing at a time
6. You can't drift in an auto
5. You can't pull fancy moves in an automatic
4. You get better fuel economy with a stick
3. You’ll never look like a chump if you can drive stick
2. Manual transmission cars are faster
1. Women like a guy who is good with his hands.
jeffny09 is offline   Reply With Quote
Old 04-04-2012, 10:19 PM   #3
nUcLeArEnVoY
Oldbie that nobody knows
nUcLeArEnVoY's Avatar
Drives: 2011 1SS/RS M6
Meg's (Meguiars) m105 with a yellow (or in Adam's case, orange) pad followed up by S&H Remover followed up by FMP. Done.
(But seriously)... to get wetsanding marks out, you need a genuine compound. S&H Remover is a little too gentle. The most highly rated compound out there is Meg's M105 because it of its non-diminishing abrasives. It can actually clear out 1200 grit wetsanding marks, so it should make quick work of yours. It has a super fast working time, not to mention a lot of people are satisfied with the finish left by m105 alone but on a black car you'd want to follow it up with a finer polish. If used with a PC, it won't leave trails like a lot of compounds will.
I can understand if you're apprehensive about using such a powerful compound on 3000 grit marks, though, so maybe try to use a slightly less abrasive compound first. But I can tell you now, you'll be at it for awhile with S&H Remover... more than you should be when there are other abrasives that'll get the job done quicker. You pointed out Severe Swirl and Haze Remover... that might be just the ticket. It's just that personally, I like to get shit done quick so I'd just use m105. Even with a compound like m105, I wouldn't worry about removing too much paint if you're not behind the handlebar of a rotary. Not to mention you said your painter laid the clearcoat on thick, so that helps.
Let me know how it goes! Hope I was of some help.
nUcLeArEnVoY is offline   Reply With Quote
Old 04-04-2012, 10:25 PM   #4
Iomcamaro
The enjoyment never ends
Iomcamaro's Avatar
Drives: 2010 1LT/RS IOM #25223
M105 will remove up to 1000 grit sandpaper marks. I used it yesterday with my Flex. I've seen it with my own eyes. You won't need to go that aggressive. SSHR should do the job.
Iomcamaro is offline   Reply With Quote
Old 04-04-2012, 10:35 PM   #5
PQ
Booooosted.
PQ's Avatar
Whoa, awesome guys. That's exactly what I was told already.
We used the SSHR and green pad on my rocker panel with 2000 grit paper and it didn't quite cut but want' far off. Might get the 3000 out.
If I can find the Megs local I'll get it. if not I'll order both just for kicks.
Old 04-04-2012, 10:47 PM   #6
nUcLeArEnVoY
Well, when it comes from three mouths, then I guess that's all the feedback ya need! Hope it works out.
You're probably not gonna find products from Meg's Mirror Glaze line in local stores. Occasionally, a random offshoot Advance Auto Parts might carry it, but it's not likely. You're probably going to have to order it online. Autogeek's warehouse is over in in FL and I usually get my stuff two days after I order it, so it shouldn't take long to reach Alabama.
Old 04-04-2012, 10:52 PM   #7
Buffnshine
So Cal Camaro5 Race Team
Buffnshine's Avatar
Drives: '10 SS/RS, '06 HHR, '70 El Camino
the Meguiars 105 and 205 are great for those heaver paint corretion needs that are out of the wheel house for Adams. Autogeek or Auto Detail Specialists are great places to get these.
TEAM L99 - So Cal Camaro5 Race Team #27
9/5/09 Purchased #36962 Black 1SS/RS L99 "E-TCKT" Base Dyno 328hp/341tq @BBK meet
Mods to Date: Window Tint 5% & 15%, ACC P13W Lighting, Adaptive DRL Harness, Ghost Armor, Lloyds "SS" Mats, Dash Plaque, Flowmaster Outlaw Exhaust, Drake Front Bowtie Delete, Stealth 3457 Chrome/Mirror Signal Bulbs, Grant Revolutions Steering Wheel, PFADT Sport Springs, Sway Bars, End Links, Trailing Arms, 4 Wheel Alignment, Hurst Auto Shifter and Paddle Shifter, Satin Black Rear Tail Light Bezels
Buffnshine is offline   Reply With Quote
Old 04-04-2012, 10:52 PM   #8
PQ
Booooosted.
PQ's Avatar
I'll try it out. Awesome.
So the 105 is harder cutting than the 205?
Old 04-04-2012, 10:59 PM   #9
Iomcamaro
Iomcamaro's Avatar
105 is the compound, 205 is a finishing polish like FMP. You should be able to get 105 at Autozone. They just recently picked up some of the Meg's Mirror Glaze line. If you can't get it out with what you have, and don't want a full bottle of M105, PM me your address. I'll send you a sample of 105/205.
Old 04-04-2012, 11:10 PM   #10
PQ
Booooosted.
PQ's Avatar
Wow. Thank you. Let me check at AZ tomorrow first. I don't mind buying a bottle because I can use it on ....... other stuff too.
Old 04-05-2012, 01:04 AM   #11
Buffnshine
Buffnshine's Avatar
yes
Old 04-05-2012, 01:12 AM   #12
PQ
Booooosted.
PQ's Avatar
Originally Posted by Buffnshine View Post
yes
Got it.
Old 04-05-2012, 02:32 PM   #13
cam fan
cam fan's Avatar
Drives: fast
i see what you did there
cam fan is offline   Reply With Quote
Old 04-07-2012, 11:34 PM   #14
PQ
Booooosted.
PQ's Avatar
Ok. Haven't ordered the compound yet. Looked local first. Gonna have to order it. But this morning I took the best sample pics to show you that I could.
In the last one you can see the sanding lines.
Adam's Shine Crew preps Pace Car for Auction Adam's Polishes Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 8 03-05-2012 11:14 AM
GPC Custom Adams Sampler Kit With Bag GPC1 Wash/Wax/Detailing and Cosmetic Maintenance Parts 1 09-19-2011 11:18 AM
Adam's JUMBO Vac N' Blo Pro Series by MetroVac Dr Jkel Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 16 07-28-2011 01:02 PM
