Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Garage / Tools Discussions
Old 04-05-2012, 01:19 AM   #1
Vette TPI
Vette TPI's Avatar
Drives: 1987 Corvette TPI
How strong will this hold?
Will this be sufficient enough to hold my vehicle? I've thought and planned this out a thousand times. My design comes from others who have tried. There is this and this. I added extra diagonal bracing's and then triangular bracing on front, plus the ramps being on the back of the lift. Will this suffice and be safe enough for exhaust, oil/trans oil change? It should be 16" off the ground. I know many will not think this is safe, but it's honestly better than the above links.
P.S. there would be 280 square inches of contact patch to the 2x12's, with all the verticle and diagonal bracing.
Vette TPI is offline   Reply With Quote
Old 04-05-2012, 01:33 AM   #2
sene
Drives: 2011 Summit White 2LS
Only one way to find out...
sene is offline   Reply With Quote
Old 04-05-2012, 02:18 AM   #3
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
Looks good to me, but it seems like a lot of work compared to using a jack and 4 jack stands.
SUX2BU is offline   Reply With Quote
Old 04-05-2012, 10:39 AM   #4
rolnslo
Rolling along...
rolnslo's Avatar
Drives: 2011 2SS/RS SGM
Honestly, I wouldn't do it. Why risk your life to save a few dollars?
I was going to suggest getting a KwikLift instead but it looks like they didn't survive the economic downturn and went out of business a couple of months ago. Too bad, since they actually had a decent alternative to a 2 or 4 post lift.
rolnslo is offline   Reply With Quote
Old 04-05-2012, 11:54 AM   #5
Synner
Drives: not stock
A 2x12 shouldn't be used for the vertical members, thats where the 4x4 or 6x6 should be used. A 2x12 isn't strong in the direction you were planning on using it. Lateral bracing can be made from 2x6, not 4x4. It should only be providing bracing in a single direction so square lumber isn't necessary if you design it properly.
Its tough to understand the drawing for what you're planning. Its possible to do this safely but I can't tell if your specific plans are. The fact that you're using incorrect dimensions for support pieces I'd say "contact a professional before proceeding."
Old 04-05-2012, 12:04 PM   #6
Camarowguy
Camarowguy's Avatar
Drives: 2011 imperial blue SS, black 92 RS
Your gonna use wood?????
2011 imperial blue SS/RS a6 12.43@112 vararam, tune, jba cats, magnaflow axle back, self ported tb, under drive pulley, NO headers, Stock tires. 1.87 60ft. Stock tires.
2000 1500 silverado extra cab
Camarowguy is offline   Reply With Quote
Old 04-05-2012, 02:18 PM   #7
Vette TPI
Vette TPI's Avatar
I know this is wood but just seems better the weight more spread out instead contact patch to the ground vs Jack stands.
I really want one of those after seeing one! Thank you for your advice. Is there anything similar with only this height? I don't have a lot of money or space for something bigger.
It's basically exactly the first mustang thread but with 4x4 s in each section diagonally. It's exactly why I came out here. To hopefully find something better or safer.
haha yeah. I can't weld at all or find something of significant other.
Old 04-05-2012, 04:03 PM   #8
rolnslo
Rolling along...
rolnslo's Avatar
Originally Posted by Vette TPI View Post
I really want one of those after seeing one! Thank you for your advice. Is there anything similar with only this height? I don't have a lot of money or space for something bigger...
Used Kwiklifts pop up from time to time on craigslist and car forum classifieds (check Corvette forums, they tend to like them). As far as alternatives, I'm sure that there is something similar out there, just haven't seen or heard of one yet.
Old 04-05-2012, 04:06 PM   #9
Vette TPI
Vette TPI's Avatar
I'll have to look for them! I'm in need of one!
Old 04-05-2012, 04:32 PM   #10
justa25thTA
justa25thTA's Avatar
Drives: 2011 Camaro SS/RS LS3
instead of all that fancy stuff, you could just lay out some long pieces of 2x12's stacked on top of each other for the whole thing. Not fancy and definately not light, but would be much stronger and safer ( and I bet not too expensive).
Yeah, I'll get around to it...
justa25thTA is offline   Reply With Quote
Old 04-05-2012, 04:48 PM   #11
Vette TPI
Vette TPI's Avatar
oh #*@$ probably cost the same as buying all that wood too. So need to buy sixteen 2x12 boards.. Thanks
Old 04-05-2012, 05:06 PM   #12
Synner
Drives: not stock
http://www.derekweaver.com/update/W-...uct.aspx?id=61
I clicked on the link, the ramp portion is a death trap with no lateral bracing. They were using the plywood as lateral bracing where the car is. A boxed 2x12 frame would be way safer.
Old 04-06-2012, 08:32 AM   #13
knitetrain05
Drives: 2012 Camaro SS 45th Anniversary Edi
Thats not at all a good idea.You better think out what your really doing here. Really think.
knitetrain05 is offline   Reply With Quote
Old 04-06-2012, 08:38 AM   #14
motorhead
motorhead's Avatar
So how are you going to get it up onto that truss system?
Firearms Section Mr. Wyndham Off-topic Discussions 9299 Today 02:55 PM
Modifying for " Dummies" Dr Jkel Tuning / Diagnostics -- engine and transmission 209 06-18-2012 12:24 AM
2011 1SS SG - On Hold In Oshawa Since 8/16 Autofind Camaro Price | Ordering | Tracking | Dealers Discussions 13 08-30-2010 08:47 PM
the dreaded QC Hold status!!! cab2g Camaro Price | Ordering | Tracking | Dealers Discussions 14 06-10-2010 06:16 PM
Convertible on hold? Crowley 5th Gen Camaro SS LS LT General Discussions 29 11-14-2008 04:54 PM
