Cold Air Inductions
Old 04-05-2012, 03:25 AM   #1
gnturboray
gnturboray's Avatar
Drives: SIM 2010 2SS/RS LS3 LPE750
Clutch pedal stuck
Took the SS up to some higher speeds and my clutch pedal was stuck about 3/4 the way down afterwards. I had to pull it up to the normal position with my foot. Car was shifting fine even when the pedal was stuck in the down position. Brakes also had some fade in them. Do you think this was do to over heated clutch / brake fluid?
gnturboray is offline   Reply With Quote
Old 04-05-2012, 08:13 AM   #2
BigCarrot
xbox: this is tedious
BigCarrot's Avatar
Drives: 2011 1SS M6 Camaro IOM
Sounds like it. That's why a lot of us have seperated our clutch and brake reservoirs for that specific reason. It's just not safe.
May want to change your fluid out
Big Carrot's Changes - It's a work in progress
Originally Posted by Fiftydriver View Post
Seems like just yesterday I spent $450 for a Roto Fab CAI!!! What the hell happened.
BigCarrot is offline   Reply With Quote
Old 04-05-2012, 08:15 AM   #3
stratman2SSRS
stratman2SSRS's Avatar
Drives: Lingenfelter Camaro
Lingenfelter clutch return spring works.
It's cheap.
It's easy to install.
Some may call it a bandaid, but it works!!!
I believe that the ZL1 has a similar spring as well.
stratman2SSRS is offline   Reply With Quote
Street Slayer Ultra Performance Clutches Data/Info Hendrix-Engineering V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 64 07-27-2012 11:08 PM
Stuck gas pedal due to floor mat. SFcamaro 5th Gen Camaro SS LS LT General Discussions 44 12-09-2011 01:58 PM
Street Slayer Brought to you by Hendrix Engineering Hendrix-Engineering V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 2 12-08-2011 05:32 PM
Clutch Pedal stuck, minor driving? AWS-GTAW Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 5 08-19-2011 10:53 PM
Oil Change Ramp mjlash22 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 17 01-21-2010 11:40 PM
