tandtperformance.com
Forced Induction - V8 V8 Supercharger, turbo, nitrous discussions
Old 04-05-2012, 06:47 PM   #1
infernometallicSS
infernometallicSS's Avatar
Drives: 2012 Camaro SS
Positive Displacement vs. Centrifugal
So I'm going to supercharge my 2012 L99, just wanting to hear some opinions on the type of supercharger they would go with, or have gone with. I am running on a stock bottom end so won't be running a lot of boost about 7-8 psi. I'm wondering about power down low with a centri. Obviously a centri doesn't pack the low end punch like a pd.
If there is anyone in the Phoenix area that has either type of blower that wants to give me a ride along, please let me know. I am going back and forth between the two types.
infernometallicSS is offline   Reply With Quote
Old 04-05-2012, 06:55 PM   #2
BullF-16
USAF retired! Thank God!
BullF-16's Avatar
Drives: 2011 1SS, 1LT red, 1LT/RS SGM
I run a centri and love it and will always do so. They are beastly with rpms above 4000 and insane at 5000-6500. I will never go PD, YMMV
I recommend a PD for a street driven ride because it is instant gratification when using the right foot. The centri is pretty much useless below 3000-3500. It just depends on you goals, and based on what you typed, i think a Whipple will make you very happy
HKE LSX427(Mast blk lbl 305 6bolt LS7heads, PatG231/246 blower cam, ARH LT s, Procharger D1SC, Squash dual 400LPH/ID1000s, ALKY 4 gal meth, AM AFR/Bst/oilpres/oiltemp gauges,SWretro3" exh, VMaxx TB, RX monsterCC. Pedders Justice road crs pkg: All HD bushes, supercar 12kg coil overs, supercar ZL1 sways, camber plates setup by JusticePete! :Gforce 9" 35spline S-Trac, 300M axles, 3.5"alum DS, MCLeod RXT clutch, 4xForgeline 19x10.5 4xBridgestone 305/30R19 RE-11, next CTS-v calipers/ZL1rotors/carbotech pads
BullF-16 is offline   Reply With Quote
Old 04-05-2012, 06:59 PM   #3
10aSSee D
10aSSee D's Avatar
Drives: Silver 2010 SS Camaro
Just depends on where you like your power at. Both are fun but mine sees the street alot more than the strip so I like the PD for the street, instant torque as soon as you step on it. PD's are probably harder to hook at the strip but I love my whipple and all the fun that comes with it!!!
MODS:
Whipple 2.9L SUPERCHARGER 666RWHP 562TQ
ADM Stage 2 Cam
ADM Dual Fuel Pump System
ADM CAI
ADM Boost & Air Fuel Ratio Gauges
Patriot Performance Dual Valve Springs
Hurst Short Throw Shifter
KW V1 Coilovers
Stainless Works Full Length Headers & Full Exhaust
Elite Engineering Catch Can
Forgeline GA3 Satin black wheels 20x9.5-20x11
Old 04-05-2012, 07:56 PM   #4
HufferSS
I Wanna Go Faster!!
HufferSS's Avatar
Drives: 2011 2SS Synergy Green M6
They're both awesome and quite frankly if you run a wastegate on the centri it will do a great imitation of a PD blower down low and run away from it like a scalded dog on the top end.
Built by Vengeance Racing
9.31@154.81 mph
Procharger F1-X
RPM Level 7 4L80e + Coan Converter
Hendrix 9" Rear Axle + 3.50 Gear
ARH 2" LTs+3.5" Exhaust
Fore Fuel System, Bogarts + Hoosier Slicks
Pfadt Drag Pack Suspension
My Build Thread | Best Pass To Date
HufferSS is offline   Reply With Quote
Old 04-05-2012, 08:30 PM   #5
infernometallicSS
My car is more of a "for fun" car. I take it to the track sometimes. But I have a feeling I would love that blast of power down low. But really I don't know cause I havent seen either.
Old 04-05-2012, 10:20 PM   #6
RSBAD454
RSBAD454's Avatar
Drives: 2010 Camaro 2SS/RS
Send a message via Yahoo to RSBAD454
I have plenty of torque down low....I just installed a Procharger on mine. All the Supercharger systems are awesome in my book. I chose the Centri for the fact of the installation along with the mid to top end charge and there aren't any cooling lines, extra water pumps etc to deal with. I too thought long and hard about it, but made the correct choice for my application. IMO, the RPMs come up fast enough where all the talk about no torque down low etc is out the door.
http://www.camaro5.com/forums/image.php?type=sigpic&userid=23393&dateline=127333  4105
2010 ABM RS/SS with a Procharged LS3, Flowmaster exhaust.
RSBAD454 is offline   Reply With Quote
Old 04-05-2012, 11:15 PM   #7
thebeast916
Drives: Blown G8 GT
I have ridiculous torque Down low with my d1 procharger. Pulls very hard for only being around 9.5 lbs of boost or so. It's easier on the valve train. Not an instant hit of torque and lose top end power as rpms climb like a pd blower.
This thing just keeps on pulling and doesn't stop till you ease off the gas. I am very impressed with the linear power as it kicks in.
I recommend centrifugal all the way
2008 G8 GT-Procharger D1-Livernois Stage 1C Cam-Kooks 1 7/8 Longtubes-Magnaflow Exhaust-Camaro SS Wheels and Brakes-Demon8 Designs Triple Gauge Pod( Dual Aeroforce and Wideband)- Dual Kicker CVX10-BMR Sway Bars, Trailing Arms, Toe Rods and Cradle Bushings
596/526 @9.5 lbs
11.6 at 123. 1.92 60ft
thebeast916 is offline   Reply With Quote
Old 04-05-2012, 11:39 PM   #8
Fiftydriver
Fiftydriver's Avatar
Drives: 2010 Camaro 2SSRS RJT L99
My plan was to build a stout street car only, no intent to run on the track. I wanted all the grunt I could get from idle to around 4500 rpms. Now, at times I go above this but not all that often.
Because of this, and after asking about the same thing you just did, and getting hundreds of good recommendations, I went with the maggie on my L99 and I could not be happier.
I have heard that the Centri blowers are similiar to turbo units, they start building boost at higher rpms then the PD blowers but they will continue to build boost right up till the limits of the rpm ranges. For this reason, for a strip car, the centri blowers would probably be best.
I have also heard they are easier on a stock engine. If your really hard on your car with a stock bottom end, the PD blowers will probably be the hardest on your stock bottom end.
Fiftydriver
2010 SSRS, RJTC, L99, Maggie 2300 SC, 3.4" pulley, Roto-Fab CAI, Dynatech Supermaxx LT headers, Dynatech High Flow cats, Corsa Cat back exhaust, Elite Engineering catch can, MSD wires and Jannetty custom tune, JRE custom diff w/ posi mod, 3.91 LPE gears, Pfaht trailing arms, Pfaht trailing arm and Diff bushings, drop springs and sport sway bars front and back, Fesler dual guage pillar pod w/ AM Cobalt Boost and A/F guages.
LS3 conversion, LPE dual fuel pump, Upgraded injectors, JRE Maggie Stage 2 upgrade kit, JRE smooth Idle Blower cam. Looking for 700 RWHP in the end.
Fiftydriver is offline   Reply With Quote
Old 04-06-2012, 12:57 AM   #9
camslambam
Drives: 2010 SS, 06 SRT10 Ram
Have you done an ls3 conversion?
If you want to make any type of real respectable power out of the L99 swap over and put a blower cam. At 8lbs my tvs2300 is throwing out 620rwhp.
camslambam is offline   Reply With Quote
Old 04-06-2012, 07:57 AM   #10
infernometallicSS
No LS3 converstion done as of yet. I'm still up in the air with that one too. Lol.
Old 04-06-2012, 09:01 AM   #11
Fiftydriver
If your going over 550 RWHP, I think you will probably need to do the LS3 conversion, or if your looking to run at high RPMs alot. If for street use only, and you will stay under 550 HP, the stock valvetrain will probably be fine from what I have been told.
Fiftydriver
Old 04-06-2012, 09:04 AM   #12
EvoWake
SSTOCK
EvoWake's Avatar
Dyno of my car with a PD blower (TVS2300)
Area beneath the curve says it all. Instant 'holy shit' anywhere you want.
2010 Camaro 2SS/RS
EvoWake is offline   Reply With Quote
Old 04-06-2012, 10:18 AM   #13
Fiftydriver
Whats going on with your car above 5500 rpms? Are you having some belt slippage issues? I hear this is common with the Maggie on upper RPM levels, what belt are you using?
Fiftydriver
Old 04-06-2012, 11:26 AM   #14
Detoxx03
Futral Motorsports Beast
Detoxx03's Avatar
Drives: 2008 Corvette
Centrifugal all the way. The no torque down low argument is total bs and a gimmick to get you to buy a heat pump, I mean positive displacement blower. I know on this site that's what the majority go with but you can beat having a Procharger. The Centri will run cooler, make enough torque for you to have fun and allow you to get traction while maintaining constant power, the power won't fall off as the rpm's climb, it doesn't stress your motor like a PD blower, etc. I could go on and on but I'm having a blast with my Centri so don't get caught up in the overrated lack of torque down low argument.
This is on 7lbs with a D-1SC on a LS3 with no headers or meth
D1SC Procharger 700/602 8PSI
A Futral Motorsports Creation
www.calloutsnola.com
Detoxx03 is offline   Reply With Quote
Old 04-06-2012, 12:43 PM   #15
Fiftydriver
I do not think anyone has said anything about the Centri's not having any low end torque, they just do better at upper RPM levels which is exactly what your dyno chart proves. At 3000 rpms, your getting around 400 lb/ft or torque. At the same rpms, Evowake has 550 lb/ ft and his torque curve is much broader and flatter compared to yours. Now different engine specs are certainly going to produce different power levels but on average, from the dyno charts I have studied, the PD blowers make a very wide, broad, flat torque curve and the centri's make a gradually building torque curve.
This is the difference between the two, this is why a Centri may be better for a race car as they do not top out like a PD does. This is why a PD offers more usible grunt at street rpms.
Both are very different, not saying one is better then the other, just need to see which one matches up with your wants, needs and goals better for the way you will be driving your car. Both are great, both have their advantages, both have their disadvantages. All you have to do is look at the shape of the dyno graphs to tell you what each blower will do at different RPM levels.
Fiftydriver
Old 04-06-2012, 01:37 PM   #16
Detoxx03
Detoxx03's Avatar
All that torque will be useless if you can drive, have drag radials, or both. Everyone has their preference and mine is a Centri. The whole centri's are better for racing and pd's are better for the street is a silly argument too. It all comes down to driver mod and traction. If your pd car doesn't perform at the strip it's because you can drive not because of the type of blower you have.
Old 04-06-2012, 01:41 PM   #17
EvoWake
SSTOCK
EvoWake's Avatar
First off nice numbers man! I had a P1SC on my last camaro just to validate that i'm not trying to start a fight here. That being said, i have to point out that your statement.....
Is utterly false. Horsepower is a function of torque. if you are generating more torque across a wider range of engine speed, you ultimately have a better performing vehicle provided you can put the power to the ground.
Because it is difficult in most cases for any car over 500HP to put power to the ground, this is where a centri. gets a point for most street applications in my book.
as far as the PD falling on its face, my car has a cam that runs out a bit up top, and if you want more, build up, pulley down
Either way, PD or Centri, you'll have a bad ass ride.
2010 Camaro 2SS/RS
Old 04-06-2012, 01:59 PM   #18
94guy
94guy's Avatar
Drives: 99 Camaro; 2010 Camaro 2SS/RS
cyber how fast is your car?
94guy is offline   Reply With Quote
Old 04-06-2012, 02:04 PM   #19
EvoWake
SSTOCK
EvoWake's Avatar
Originally Posted by CyberPredator View Post
Hahaha this again. To answer question neither!!!! Go twin turbo!!!!! 693whp 708wtq 9.5psi stock exhaust, stock cam, stock heads. + a boost controller allows you to turn it up and down as you please.
Dang, talk about efficient boost! Noice!
oh, and OP, I went with a PD because i liked the OEM nature of its appearance more than anything. Any FI setup is going the be fun as hell and more than you can realistically use on the street without a LOT of suspension work.
2010 Camaro 2SS/RS
Old 04-06-2012, 02:16 PM   #20
Detoxx03
Detoxx03's Avatar
This is also a great option. I've rode in this car and it's a absolute monster. Totally stock looking and once you've found out its not it's too late.
Old 04-06-2012, 02:24 PM   #21
Detoxx03
Detoxx03's Avatar
Putting the power to the ground is key. Both produce enough torque to leave the car sitting still.
Old 04-06-2012, 02:29 PM   #22
EvoWake
SSTOCK
EvoWake's Avatar
Amen
2010 Camaro 2SS/RS
Old 04-06-2012, 02:46 PM   #23
xx_ED_xx
xx_ED_xx's Avatar
Drives: 04 Silverado
I second that motion
xx_ED_xx is offline   Reply With Quote
Old 04-06-2012, 03:24 PM   #24
MANNYS2SS/RS
TRI-COUNTY CAMAROS
MANNYS2SS/RS's Avatar
Drives: 2010 Camaro 2SS/RS,LS3
I agree!!
LS-3, ProCharger D1SC
665. rwhp /562. rwtq @ 9.3 psi
MANNYS2SS/RS is offline   Reply With Quote
Old 04-06-2012, 04:58 PM   #25
infernometallicSS
Holy Christ that's a lot of torque!!
l99, maggie, procharger, supercharger, whipple
Positive Displacement Blowers vs NA at Altitude... Mr. Wyndham Forced Induction - V8 10 02-27-2012 10:22 PM
Edelbrock SC vs Whipple? Rocky918 Forced Induction - V8 121 08-19-2011 09:59 PM
What is the displacement of an LS3? UCI CamaroFan Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 8 08-23-2009 09:47 PM
Positive Battery Cable issue (not near starter) shiftz33 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 4 08-12-2009 04:20 PM
Finally Some Positive CAFE opinions stovt001 5th Gen Camaro SS LS LT General Discussions 37 03-07-2008 04:18 AM
