sjm autoprod
Old 04-07-2012, 07:56 PM   #1
ajp
SHK-TRPR
ajp's Avatar
Drives: Camaro 2016 2SS
Engine temp too high, AC deactivated?
WTH!
Had this happen twice today. Outside temp was 88-90c. The fan finally started working and the temp returned to normal but it freaked me out.
Is there a recall or update I need?
http://www.camaro6.com/forums/picture.php?albumid=1554&pictureid=145486
ajp is offline   Reply With Quote
Old 04-07-2012, 08:00 PM   #2
fielderLS3
fielderLS3's Avatar
Drives: 2016 Mazda6, 2011 Mustang 5.0
When you first started it, or when it had been running a while?
The fans should come on before you get overheating warnings. How hot was it? Did the gauge go up, or where you looking at the digital temperature display?
"Proven V-8 power with better efficiency than a turbo V-6"
"The car is the closest thing we will ever create to something that is alive."eds.
fielderLS3 is offline   Reply With Quote
Old 04-07-2012, 08:05 PM   #3
Tyler360
Tyler360's Avatar
Drives: 2011 Camaro 2SS/RS
The AC is supposed to turn off if the engine is over heating, that is normal. It's in the manual.
Tyler360 is offline   Reply With Quote
Old 04-07-2012, 09:06 PM   #4
ajp
SHK-TRPR
ajp's Avatar
I had traveled about 30 miles/30 mins.
I was stopped at a light both times.
The temp gauge got 3/4 of the way to red.
Old 04-07-2012, 09:37 PM   #5
fielderLS3
fielderLS3's Avatar
Sounds like the fans are not coming on early enough. Probably something you want to have checked out. I'm assuming you're still under warranty.
Does this happen every time you stop and idle, or is it more sporadic. If every time, it should be easy for your dealer to reproduce.
Old 04-07-2012, 09:47 PM   #6
ajp
SHK-TRPR
ajp's Avatar
First time. But I dont drive very far usually. Was thinking that the fan should have kicked in earlier.
Old 04-07-2012, 10:09 PM   #7
Chevrolet Customer Svc
Drives: GM Vehicles
ajp. I would agree with fielder. You may want to get this checked over. Hopefully your still covered for this. Let us know how things go for you and if you have any troubles getting things taken care of let me know.
Jeff Morris, Chevrolet Customer Service
Old 04-07-2012, 11:46 PM   #8
ajp
SHK-TRPR
ajp's Avatar
Thanks Jeff,
I have the extended 50k/84 month warranty, but my car only has 7k miles on it anyway lol.
I do have a CAI inc CAI, not sure if that would cause an issue. I will get it checked out Monday and update the thread.
Old 04-08-2012, 01:30 AM   #9
Avenging Orange
Avenging Orange's Avatar
Have you checked you coolant?
2010 Inferno Orange 2SS/RS M6 Black Leather,Sun Roof, OBX Headers, Haltech CAI , non synthetic fluids, Mike Norris tuned 419/413
2015 Ford Interceptor// 2007 Ford F150 XLT 4X4
Avenging Orange: 40 years of not buying into the Hype........and damn proud of it!!
Old 04-08-2012, 02:56 AM   #10
SteveRS
SteveRS's Avatar
Drives: 2010 SIM Cobalt SS
Send a message via AIM to SteveRS
I am the FIRST camaro owner that experienced this problem... i assume you are talking about THIS correct??
If this is what you saw send me a PM.. this happened to my 1LT/RS just barely after i had it for no less than a month.. it happened multiple times after the service techs had replaced the Temp gauge and the PCM... but they wouldnt take my car back so i traded it for the 1SS I have now.. your car is NOT overheating.. its an electrical malfunction somewhere....
2011 Imperial Blue 1.5SS
2010 Silver Ice Cobalt SS
SteveRS is offline   Reply With Quote
Old 04-08-2012, 05:29 AM   #11
ChvyBoss
THAT BOOST TURNS HEADS
ChvyBoss's Avatar
Drives: Camaro 2SS/RS
This happen to my car as well but I thought it was my turbo that was making it to hot under the hood for the AC. So this is an electrical problem ?
SoCal HT5 ENOUGH SAID
ChvyBoss is offline   Reply With Quote
Old 04-08-2012, 12:03 PM   #12
ajp
SHK-TRPR
ajp's Avatar
Yep - thats it!
Old 04-09-2012, 03:48 PM   #13
ajp
SHK-TRPR
ajp's Avatar
I took it to a local place (since I didnt want to drive 30 miles and explode).
They put about 1 gallon of dex+distilled, so I am hoping that was the cause.
Although I would have thought that the 'low coolant' warning would turn on before the coolant got to a level that required the AC to have to be turned off
Anyway hope its fixed, I will get it serviced by a GM dealer in the next few weeks just to be sure.
Old 04-10-2012, 07:36 AM   #14
DJ_BigC
Rockin' Steady
DJ_BigC's Avatar
Drives: 2010 Camaro 2SS
If im not wrong I do not think our cars have a low coolant light, because usually the sensor is located in the expansion tank, since we don't have one, I'm pretty our car is not equipped with the dummy light.
Now this light you are seeing in your dash comes on for a couple reasons, 1 when your engine is overheating, 2 when your ECT sensor is getting faulty readings, 3 when your ECT sensor detects or senses that your coolant is substantially hotter (almost overheating) then the ambient air temperature.
A simple fix for a tech is to observe the ECT data on the scan tool and make sure all parameters are correct, if not, inspect for damaged wires or a faulty sensor. And last but not least, a low coolant level, or improperly mixed coolant can also cause this light to come, like someone posted above.
Top up your coolant to spec, check your freeze protection rating, if all good, drive it and see if the light comes back on. If it does you have other problems, if not your good to go. This light will also set a DTC in your ECM, the tech should be able to pull the code and diagnose it if the problem does ever occur again.
Eric Carrier, proud GM Technician for over 8yrs.
2010 Camaro 2SS Black, L99, SLP headers, GMPP axle back, complete JRE tune, 22" Boss 337's, Nitto Invos 5% tint, Eforce Supercharger w. 3" pulley, ADM FPCM, ID850's, JRE fuel rail mod, Eforce CAI, Moroso catch can, spark plug insulators.
DJ_BigC is offline   Reply With Quote
Kenne Bell vs Whipple boostedyards86 Forced Induction - V8 679 10-21-2013 04:05 AM
Acronyms at C5 hokie2012 5th Gen Camaro SS LS LT General Discussions 34 08-10-2011 04:56 PM
g5cr cai system anybody install or looking at one "pics" camarossrs2150 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 41 07-14-2011 09:26 PM
Pfadt Race Engineering releases new Camaro V8 Engine Mounts PfadtRacing Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 43 06-07-2011 01:09 PM
Acronyms? KEEP RT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 20 03-11-2011 09:57 PM
