JDP Motorsports
Old 04-07-2012, 08:59 PM   #1
Allanski
Drives: Car
What rear gears for a 4L80?
Car is for weekends only, will need to drive on highway to Camarofest. I want some good 60' times and great 1/4 mile times. I was considering 373? Any suggestions?
Allanski is offline   Reply With Quote
Old 04-07-2012, 09:04 PM   #2
Hendrix-Engineering
Drives: First 9 inch-12 bolt IRS Camaro
Power? type of power adder?
Hendrix-Engineering is offline   Reply With Quote
Old 04-07-2012, 09:22 PM   #3
Allanski
Drives: Car
Supercharged and should be 700 to rear wheels.
Old 04-07-2012, 10:13 PM   #4
jrpxxii
jrpxxii's Avatar
3.90 or 4.10 are going to give you best 60' and 1/4 mile et but you will be in higher rpms for highway driving.
Old 04-08-2012, 08:02 AM   #5
Allanski
Drives: Car
Is there a halfway set up between 3.73 and 3.90?
Old 04-08-2012, 11:29 AM   #6
Hendrix-Engineering
pd blower i would go 3.50 if your not trying to set a 1/4 record and 3.73 if you have a centri charger
Old 04-08-2012, 12:01 PM   #7
JLE58
Drives: CGM,twin turbo, cam 2010 SS/RS
+1
JLE58 is offline   Reply With Quote
Old 04-08-2012, 05:48 PM   #8
jrpxxii
jrpxxii's Avatar
He is saying its for weekends only and wants best 60' and 1/4 et. Only time he says it will be on highway is for camarofest. If you want a track performer go 3.90 or 4.10.
Old 04-08-2012, 07:34 PM   #9
Hendrix-Engineering
I would disagree ,especially with a pd,you wouldnt put alot of gear in a diesel would ya .With over 700 rwhp he should be out of gear by the 1/4 with a 4.10
Old 04-08-2012, 07:41 PM   #10
HufferSS
I Wanna Go Faster!!
HufferSS's Avatar
Drives: 2011 2SS Synergy Green M6
4.10 maybe....but at that power level my 3.90 put us right through the traps at mid 6k range....perfect.
Built by Vengeance Racing
9.31@154.81 mph
Procharger F1-X
RPM Level 7 4L80e + Coan Converter
Hendrix 9" Rear Axle + 3.50 Gear
ARH 2" LTs+3.5" Exhaust
Fore Fuel System, Bogarts + Hoosier Slicks
Pfadt Drag Pack Suspension
My Build Thread | Best Pass To Date
HufferSS is offline   Reply With Quote
Old 04-08-2012, 08:04 PM   #11
Hendrix-Engineering
Keep in mimd this is an auto and he will have some converter slip ,with a pd we have found they et better when you let them spend more time in there power band insted at upper RPMs .I would have loved to run your car with 3.50s
Old 04-08-2012, 08:36 PM   #12
HufferSS
I Wanna Go Faster!!
HufferSS's Avatar
Yeah...me too. The good thing about that combo I had is almost the entire rpm range is in the powerband. Big, broad and flat torque curve made it pull hard the entire time. A PD blower is a recipe for permagrin for sure.
9.31@154.81 mph
Procharger F1-X
Old 04-08-2012, 09:59 PM   #13
JLE58
What gear do you have now?
Old 04-08-2012, 10:26 PM   #14
jrpxxii
jrpxxii's Avatar
I ran 3.73 with 727rwhp with the tvs2300 and wish i had more gear. I have run everything from a 3.25 gear to a 3.90 with 3 different combos and think i have a pretty good idea what works in these cars as i have also run a manual and auto as well.
CAMARO ZL1 FAQ and INFORMATION radz28 Camaro ZL1 Forum - ZL1 Specific Topics 280 11-04-2011 02:33 PM
Richmond 4.33 Rear End Gears Available At Apex Motorsports!!! Apex Motorsports Transmission / Driveline 84 05-13-2011 03:26 PM
3.45 M6 SS rear gears AG454 Local Marketplace 1 07-10-2010 10:17 AM
