Emblempros
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Garage / Tools Discussions
Old 04-10-2012, 12:13 AM   #15
S3XPanther
by Odeon
S3XPanther's Avatar
Drives: '12 SS/RS A6 IOM SOLD, '13 1LE IOM
Originally Posted by SilverIceman View Post
Yes, watched the corvette video. Good idea but I'd rather have the stands under the frame. The pinch rails under the rockers just don't look look as strong. I'm sure they are.
LOL, it's where GM recommends you lift from, but ok. To each their own.
To answer your question I would use a small 3" ramp to get the car high enough.
http://www.raceramps.com/jack-assist-ramps.aspx
"It works 60% of the time, every time."
"Some say it's a waste of time, others say it's an incredible waste of time."
"The ultimate measure of a man is not where he stands in moments of comfort and convenience, but where he stands at times of challenge and controversy."
2013 IOM SS/RS - 1LE. Born 5/6/2013 (1 of 32 1SS IOM 1LE's)
S3XPanther is offline   Reply With Quote
Old 04-10-2012, 05:24 AM   #16
jeffny09
jeffny09's Avatar
Drives: 2010 camaro
Send a message via AIM to jeffny09 Send a message via Yahoo to jeffny09
But, how would I lift both the right and left of the rear to put jack stands on each side'so I could drop the subframe?
top 10 reason why real men drive stick.
10. A manual transmission is the ultimate in control
9. You can use automotive jargon and not sound like a total tool
8. You can't spell "manual" without "man"
7. Manual transmissions prove you can do more than one thing at a time
6. You can't drift in an auto
5. You can't pull fancy moves in an automatic
4. You get better fuel economy with a stick
3. You’ll never look like a chump if you can drive stick
2. Manual transmission cars are faster
1. Women like a guy who is good with his hands.
jeffny09 is offline   Reply With Quote
Old 04-10-2012, 05:32 AM   #17
USARCPT
USARCPT's Avatar
Drives: 2012 Camaro 2SS/RS TF3 LS3
Even without ground effects, my hydraulic jack (nothing fancy; run-of-the-mill Autozone hydraulic floor jack) doesn't fit under any good place.
Ultimately had to sneak under the car between the wheel and fender.
Gave me a chuckle and about a minute's worth of "Hey, how am I going to do this?" the first time I wanted to get under the car!
I didn't use the jack points listed above for the front, but I did jack the vehicle up using the frame....close to the area where the jack stands were eventually inserted.
USARCPT is offline   Reply With Quote
Old 04-10-2012, 10:47 AM   #18
S3XPanther
by Odeon
S3XPanther's Avatar
You guys need lo-pro's from Summit
Old 04-10-2012, 02:29 PM   #19
Montducati
Montducati's Avatar
Drives: 45th Edition SS, Ducati Diavel, 996
Originally Posted by gml1998 View Post
Put a hockey puck on the pad of the jack
Great idea
On another note; I know there's a thread on this already; however, what's the Jack of Choice?
2012 45th Edition SS LS3 Hurst equipped
Bowtie!! What Bowtie??
Montducati is offline   Reply With Quote
Old 04-10-2012, 09:27 PM   #20
lionssfan
drive it like U stold it
lionssfan's Avatar
Drives: 2010 2ss camaro
I cut squares out of the hard rubber floor mates that you can buy. that are about 3/4 or inch thick and use those for the hyd. jack and jack stands so my undercarriage doesn't get scratched. we use them on hoists in our garage also.
lionssfan is offline   Reply With Quote
Old 04-29-2012, 10:40 AM   #21
Montducati
Montducati's Avatar
I purchased the 2 ton heavy duty floor jack from Tire Rack this week, very nice!!!
I'm fortunate as my garage slab is up about an inch from the driveway so when I pull the nose of the car in the slab gives it that extra bit of clearance to get the jack under.
The jack also has a rubber pad on the cup so no need for wood or hockey puck to protect the frame.
Thanks for all the advice.
Old 08-27-2012, 09:33 PM   #22
dcplus14
dcplus14's Avatar
Drives: '12 Camaro 2SS/RS/Hurst
Sorry to revive this thread, but what he said! Going to work on installing some Subframe inserts, but both the floor jack and jack stand positions show all the subframe mounts. Surely there is another location in the rear.
2012 Camaro 2SS/RS: Black on Black, Hurst
[AAC DRL LED's, AAC LED's for trunk, cabin, license plate, CAI Intake, RX Catch Can, Skip shift eliminator, Pedders Sub-Frame Inserts, Pedders Radius Rod Inserts, Pedders Rack & Pinion Bushing, 1LE front and rear sway bars]
dcplus14 is offline   Reply With Quote
Old 08-28-2012, 05:33 AM   #23
nyrfan
Let's go Rangers!
nyrfan's Avatar
Drives: 13' AGM 2SS/RS L99
Myself and many others lift the rear using the rear differential with no issue. Some people will not suggest this but I've had no issues.
Refer to this post:
http://www.camaro5.com/forums/showpo...26&postcount=4
FSP tuned: 377/389
Old 11-02-2012, 09:32 PM   #24
AKA-51
Drives: Ellie
book
AKA-51 is offline   Reply With Quote
Old 11-04-2012, 07:24 PM   #25
james347
Drives: 2006 Crownline
Where to place the floor jack?
Under the the car?
james347 is offline   Reply With Quote
Old 11-04-2012, 08:15 PM   #26
rtcat600man
having FUN now 13.66@101
rtcat600man's Avatar
Drives: 2010 2LT IOM
Under the the car?
Sissor jack and floor jack locations.
Local tire place messed up my paint, need advice philipdistefano 5th Gen Camaro SS LS LT General Discussions 35 04-21-2010 08:12 AM
L99 all over the place! 2SSARMY Dragstrip and Launch Techniques Discussion 24 04-20-2010 11:51 PM
Wheres a good place in North NJ to get a Maggie installed stealth camaro USA - NY / NJ / PA 13 04-15-2010 07:24 AM
"There's no place like Kansas." The_Blur USA - Rockies / Midwest 1 10-18-2009 10:30 PM
Looking for a place to go hunting ZZcamaro Off-topic Discussions 11 10-07-2009 12:53 PM
