Old 04-08-2012, 11:57 AM   #1
trz174
trz174's Avatar
Drives: Blue Camaros
ZL1 First Oil Change
Time to change the oil after a 1000 mile drive. Jacking the car up was a pain because the underbelly pan covers most of frame. We used a combination of floor jacks and jack stands to get it done. Not pretty but we applied maximum overkill and it's safe until we figure out something better.
Removal of the underbelly pan is easy. Just remove about a million bolts (love my 1/4 air wrench!), pop the two plastic holders at the rear and slide it backwards. The plastics holders don't look like they will last more than a couple of pulls. I'll probably replace them or just leave them off. Plenty of bolts hold the pan on and the plastic clips just keep the pan from hitting you in the head when the bolts are out.
We are headed to the parts store for a filter. Manual says PF-48 AC. Looks like these will also work: HP1017 K&N, PL12222 Purolator and PH10060 Fram. Couldn't find the ZL1 in the online lookup so we use the CTS-V.
First photos attached.
trz174 is offline   Reply With Quote
Old 04-08-2012, 12:00 PM   #2
2012ZL1
CaRaHoLiC
2012ZL1's Avatar
Drives: '12 ZL1,67 Cam,68 Biscayne 427 4 sp
Is that salt on the floor pan?
2012 ZL1
2.55 upper, 10" lower pullies, Innovators west billet hub and sfi balancer, solid blower drive isolator, 50 mm idler kit, full length S/S headers no cats, comp cams custom grind cam, comp roller rocker trunion kit, comp push rods,dual valve springs retainers and locks, Injector dynamics ID850 inectors, Rotofab ZL1 cold air kit, Lingenfelter 160 thermostat, Rotofab intercooler reservoir, stock plugs, LS7 90mm throttle body, GTO clutch reservoir mod, my own custom catch can, Tuning by Jannetty, install by me.
2012ZL1 is offline   Reply With Quote
Old 04-08-2012, 12:05 PM   #3
thebatdude
thebatdude's Avatar
Drives: 70 Chevelle big block
It looks like there may be an extra benefit of the pan as it will keep the engine and trans cleaner.
thebatdude is offline   Reply With Quote
Old 04-08-2012, 12:09 PM   #4
htron50
htron50's Avatar
Drives: 2017 ZL1 Status "Thank You!"
I had the same question... was salt between the belly pan and on frame from factory or from your break in driving?
It looks like the oil filter can drop out nicely without making a huge mess on subframe parts as well! Nicely designed!
Thanks for posting the photos and providing part numbers for us! Very much appreciated.
PS: Did you happen to replace the oil pan bolt with a magnetic one? Sourced from? Thanks!
htron50 is offline   Reply With Quote
Old 04-08-2012, 01:04 PM   #5
thebatdude
thebatdude's Avatar
What do the jack points look like?
Would something like this help? (It's a bit rich for my blood, but maybe over the long run it might be worthwhile or does anyone know something similar?)
http://jackpointjackstands.com/Home_It_Works.html
Old 04-08-2012, 01:26 PM   #6
shockandawe
shockandawe's Avatar
Drives: 2014 Z51 Corvette
Why didn't you just use ramps?
shockandawe is offline   Reply With Quote
Old 04-08-2012, 01:43 PM   #7
jdenotter
jdenotter's Avatar
Drives: 2010 2SS/RS,M6,Black w/CGM Stripes
+1
Sent from my DROID BIONIC using Tapatalk
3" RDP Motorsports aggressive cat-back exhaust w/ x-pipe, Vararam CAI, Hurst's short throw shifter, Gary's Customs painted bowties, Ofer's HID DRL/Fog Light wiring harness, Kelvin 8K HID DRL bulbs, ZL1 grille. Johnson's window tint film, LSR lowering springs, Metra dash kit with Pioneer In-Dash DVD head unit.
jdenotter is offline   Reply With Quote
Old 04-08-2012, 01:48 PM   #8
IOMZL1
IOMZL1's Avatar
Drives: 2017 Viper ACR Extreme
What is a good ramp for a ZL1 or other car with even lower ride height and wider tires?
IOMZL1 is offline   Reply With Quote
Old 04-08-2012, 01:52 PM   #9
BlackM6RS/SS
BlackM6RS/SS's Avatar
Drives: 2010 Black M6 RS/2SS
I'd leave that off. Looks like the pan that came off my bothers GTO.
First start of weight reduction right there, easy 10lbs I bet.
10 Blk/Blk RS/2SS w/CGM Stripes
ADM H/C/I M6 480rwhp 435rwtq
FE4 LCAs w/Pfadt ZL swaybars Diff bushings Trailing arms Drop springs
BlackM6RS/SS is offline   Reply With Quote
Old 04-08-2012, 01:57 PM   #10
thebatdude
thebatdude's Avatar
Here's a video of the Jackpoint Jackstands.
After a few minutes of Googling these are starting to look to me like they might be worth it.
Old 04-08-2012, 01:57 PM   #11
Unobtainium
Fabricator
Unobtainium's Avatar
Drives: 2011 2SS Summit White
Looks easy enough.
I'd also wager a nice aero advantage with it on. Isn't K&N hp1017 same as the SS?
If you haven't already, load it up hard now to seat the rings. I usually take it to the dyno for this. Much safer and less expensive.
Roto-fab CAI
Unobtainium Welding Exhaust
ARH LT's
393whp L99
GPI VVT Turbo Cam-in
Twin Mini's...soon
Permagrin...Always
Unobtainium is offline   Reply With Quote
Old 04-08-2012, 02:01 PM   #12
KevinK
KevinK's Avatar
Drives: '02 SS 345/M6 conv.
In addition to the 'aerodynamics' purpose, ...the pan has cooling features designed into it. Notice in the pan photo above, on the right side (tail end), that is shaped for air flow up to the tranny for cooling.
KevinK is offline   Reply With Quote
Old 04-08-2012, 02:07 PM   #13
shockandawe
Go to raceramps.com, I bought a pair for my Camaro and Vette and they work extremely well. They are made of foam and are coated with a rubbery abrasive finish so they won't slip on concrete. They only weigh approx. 6 lbs. a piece. I saw them demoed at Elkhart Lake, Wi. They are made in Michigan. You guys will love these ramps!
Old 04-08-2012, 02:23 PM   #14
HDRDTD
Another feature is they are made with shorter ramps or longer ramps for cars that have low ground clearance.
get the two-piece version that the ramp portion can be taken off once the car is up on the ramp for better access to the underneath of the car from the side.
DIY: Camaro Oil Change adub4185 Camaro DIY & HOW-TO instructions & discussions 180 04-23-2014 07:11 PM
best synthetic oil to use hollywoodjose Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 130 01-26-2014 09:51 AM
Need help with order please zfuzz Camaro ZL1 Forum - ZL1 Specific Topics 7 11-22-2011 07:40 AM
Should I trust my oil life computer? 2011CamaroRS/SS Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 39 11-15-2011 11:10 PM
How to see if oil is in intake manifold? CamaroC-17 5th Gen Camaro SS LS LT General Discussions 53 03-23-2011 06:06 PM
