Gen5DIY
Old 04-09-2012, 05:51 AM   #1
J666
Drives: Camaro
License Plate Lights Not Working Sometimes?
I have noticed that my lights will randomly stop working. I have to kick the housing lightly with my shoe, and it turns on. I have LED lights on order, so hopefully this stops once they're installed.
Anybody else ever have this issue? I did replace the bulbs a while back, and they are in tight.
J666 is offline   Reply With Quote
Old 04-09-2012, 05:56 AM   #2
mastertypodemon
Late Night Crew
mastertypodemon's Avatar
Drives: 2010 SIM 1LT
I'll be honest, I don't typically look at my license plate when I'm driving.
mastertypodemon is offline   Reply With Quote
Old 04-09-2012, 08:50 AM   #3
pierre777
HT5 COTW 9/3/2012
pierre777's Avatar
Drives: Cyber Bullet
I had the same problem with my LEDs installed then I took the led out and moved the pin a little and put it back and now everything works fine.
Old 04-09-2012, 09:27 AM   #4
cowjazz
Drives: 2010 2SS
I'm not sure if I had the same problem, but here is my story...
License plate light stopped working, a few days later I noticed a perfect circle with a dimple in the center on my bumper, and a few days after that the dimple turned brown. Turns out the housing for the light was broken, and the bulb burned through my bumper. All covered under warranty.
My point is, check out that bulb and housing before you roast a bumper cover.
cowjazz is offline   Reply With Quote
Old 04-09-2012, 09:50 AM   #5
Blue17CamaroZL1
650HP soon to come
Blue17CamaroZL1's Avatar
Drives: 2017 Chevy Camaro ZL1
I had a similar issue. One of my bulbs was out so I pulled the bulb to replace it, a chunk of glass was taken out and the housing itself was melted. The two tightening tabs on the housings broke off and the bulbs were flopping around:
Got them replaced under warranty with new LED lights:
2017 Camaro ZL1
Hyper Blue Metallic
A10, PDR, NAV, Premium floor mats
Blue17CamaroZL1 is offline   Reply With Quote
LED license plate lights IronMike Cosmetics and Lighting Modification Discussions 7 03-15-2011 01:19 AM
License Plate Lights Pulse Red GTO Cosmetics and Lighting Modification Discussions 1 03-06-2011 07:42 PM
Front License Plate The Stig USA - Mid-Atlantic 9 06-18-2010 10:58 AM
NO MORE FRONT PLATE! SUPPORT NYS Bill A09426 LT1Jeep USA - NY / NJ / PA 17 05-04-2010 10:23 PM
