Old 04-09-2012, 03:04 PM   #1
Carriccp
Carriccp's Avatar
Drives: Sold
Creaking Noise (Rear Deck?)
I have a creaking noise in the rear of my Camaro that drives me absolutely INSANE. The noise wasn't there when I purchased the car, but since has developed and I can't figure out what it is. It only happens when I go across uneven ground at low speeds. I thought it was the rear deck rattling, so I placed foam between the back glass and the rear deck...no luck. Replaced the suspension...no luck (stock struts/springs to SS struts/Pfadt springs).
I have noticed that when I sit in the back seat and move the car up and down, I can get the car to make the creak noise. If I fold down the back seat, I can not get the car to make the creak noise. That to me indicates it's in the upper portion of the back seat, or something attached to the seat.
Anyone else experience this? Hate hearing my $30K car making this noise like it's falling apart.
Carriccp is offline   Reply With Quote
Old 04-11-2012, 02:10 PM   #2
jtzako
Drives: 2010 IBM Camaro SS
I've noticed a slight creak in the rear deck area when I first start moving from a stop. I usually only hear it the first 'start' of the day though.
2010 Camaro SS Imperial Blue | CAI Inc, CAI | Solo Hi Flow Cats | X-Pipe | Backup Camera | PDIM
jtzako is offline   Reply With Quote
Old 04-11-2012, 02:34 PM   #3
Bo Tie 1
Bo Tie 1's Avatar
Drives: 11 Camaro SS,05 Vette Z51,76 Camaro
I had a cracking, light popping sound that I could have swore was coming from the back area. Turned out it was coming from the drivers seat. I used to have the seat all the way back, just moved it up a touch and noise stopped
Bo Tie 1 is offline   Reply With Quote
Old 04-11-2012, 03:49 PM   #4
Mikamaro
MikeNoMaro
Mikamaro's Avatar
Drives: A 2016 Challenger R/T M6 STP
I have the same noise... After searching I found that its the plastic around the back seat latch that moves around. The lack is not tight enough against the back seat. I've try to add those under chair plastic caption on the plastic around the latch without results...I'm trying to add space between the touching surface or to tight them up together. If I find a part to stick it in there I will let you know...please do the same too.
Good luck.
Mike
Track Day Videos: http://www.youtube.com/user/mrgoodman2000/videos
Built #83817, Born January 18th, Christened June 11th 2010, Stolen October 3rd 2016.
Mikamaro is offline   Reply With Quote
Old 04-11-2012, 06:06 PM   #5
Carriccp
Carriccp's Avatar
Drives: Sold
I actually figured this out yesterday after I made my post. Mikamaro is dead on. I wrapped some electrical tape around metal latch portion that the back seat latches to to tighten it up and the sound went away. Now to find something a little prettier.
Old 04-12-2012, 09:00 AM   #6
Mikamaro
MikeNoMaro
Mikamaro's Avatar
Yes, electrical tape..that should do this morning!! Yes good idea. thanks
Comp Series Gen 1 Style Rear Deck Spoiler! GROUP BUY at Unrestricted Motorsports! AutoAgenda Exterior Parts & Accessories 61 09-19-2012 10:11 PM
Buzzing and Tapping noise from rear superchris Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 4 04-27-2012 11:17 PM
Bottoming out noise in rear SolidOrange 5th Gen Camaro SS LS LT General Discussions 16 10-19-2011 09:50 AM
help with rear end noise kevin1106 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 0 04-20-2011 04:14 PM
Dealer blaming rear dif noise on lowering of car. Dion_1969 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 15 04-18-2011 07:51 PM
