| Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons Bolt-Ons | Intakes | Exhaust |
Thread Tools |
"Chevy" rumbles best
My long awaited cam install has begun
I finished my audio system over the weekend now its time for my long awaited cam install. was going to wait till the weekend but it looks like a lot of work so im starting it today.
here we go
![]() ![]() Drives: 2012 45th AE 2SS Coupe Join Date: Sep 2011
what parts did you go with?
cold air inductions
Jannetty ported throttle body custom ground comp cam on the dreaded 111 lsa but im going for it. comp valve spring kit 26926TS Comp trunion kit 13702 Trick flow timing chain set tfs-30778536 BBK ceramic coated headers w/high flow cats 40210 Jannetty Tune I wasn't going to spend $1500 for a set of headers and cats so BBK it is. After i get it running I may take the three hour trip to Jannetty Racing and have him tune it on the dyno. I'd like to see what it really makes after all this work.
![]() ![]() ![]() Drives: 2009 Pontiac G8 GXP Join Date: Feb 2012
If its just 3 hour drive I would have them do it for sure.
2009 PBM G8 GXP M6
im jealous! i want to do more to mine I just can't get past dumping the warranty yet.
#6 |
I'm not worried about my warranty, I dont like letting people touch my car anyway. If i need something important i got a friend who works at a chevy dealer.
#7 |
all apart, now to get that damn oil pump off.
#8 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2013 E92 M3 Join Date: Nov 2009
blue springs, is that a 2011 thing ? mine are yellow
#9 |
Dont know, but when i took my valve cover off my dad goes " hmm i wonder if a red car has red springs"
#10 |
My 2010 LS3 had yellow springs too. Replaced them with Comp Cams 26-918.
Ed M.
RJT 2SS/RS, AAM 3.70's, MTI Sway Bars, Shifter & SS brake lines, BMR Trailing & Toe Arms, full rear cradle & diff bushings, Pedders XA's, Camber/Toe eccentrics, Radius arm inserts, Hawk HPS Brake pads, GTO clutch reservoir, LS9 cam, Comp Cam valve springs, Melling 10296 oil pump, CR 5 timing chain, LS2 damper, CAI Cold Air Induction, ARH LT headers w/HF cats, GMPP touring axle back, Elite Engineering Catch Can, Forgeline 20x9 & 20x11 DS3 wheels with Pirelli Pzero 275/40/20 & 305/35/20 tires, '11 Convertible spoiler, Lloyd "SS" Floor Mats, GM Camaro Trunk Mat, GM SS Fender & LS3 Emblems.
#11 |
i just finished my install..it wasnt so bad uninstalling the oil pump,,,its a pain to install it though
top 10 reason why real men drive stick. 10. A manual transmission is the ultimate in control 9. You can use automotive jargon and not sound like a total tool 8. You can't spell "manual" without "man" 7. Manual transmissions prove you can do more than one thing at a time 6. You can't drift in an auto 5. You can't pull fancy moves in an automatic 4. You get better fuel economy with a stick 3. Youll never look like a chump if you can drive stick 2. Manual transmission cars are faster 1. Women like a guy who is good with his hands. |
#12 | |
working on it now. dropping the pan
#13 |
![]() Drives: 2012 2SS M6 Join Date: Dec 2011
The spring color thing is strange. My 2012 had blue springs. I just sold them today. Don't throw your stock parts out. I've sold everything except the plug wires. Just thought I'd mention it because I had no idea the cam and springs would sell. Didn't get much, but enough to be worth packing & shipping them.
2012 2SS Convertible
CAI Intake, Solo Catback, RX Catch Can, VMAX Ported Throttle Body, LT headers with hi flow cats, BMR Trailing Arms Comp Cams 227/243 cam, Magnuson supercharger, ZL1 Fuel Pump, ADM Fuel Pump Control Module, JRE Tune |
#14 | |
#15 | |
By the way, I wish I would have had the guts to take on the cam install myself. When I saw how different this was from the old small blocks that I used to work on, I chickened out and paid to have it done. Your lucky to live so close to Jannetty Racing. I'm thinking of asking Ted if there is some way he can check the tune on mine just to double check it, but I sure can't drive there from Phoenix.
#16 | |
i wasn't worried about tearing into it , i just didn't like that you have to drop the oil pan to get the oil pump out. im fighting with this now. i can't get mine out. i got all the bolts out and the bolt out for the pickup tube and it still wont come out. its pissing me off. and after im done i will always be worried about the pan leaking. yeah Jannetty is about 3 hours away so i'm going to do a day trip to him when im done. i also have east coast supercharging about 20 - 30 minutes away too.
#17 |
wow got it off, going to suck putting back in.
#18 |
putting it back on really sucks man..its no joke bro..took me a couple hours while being careful doing it since u dont want to pinch that o ring..u gotta leak the oil pump bolts loose and tilt it.kind of towards the pick up tube and get the pick up tube on first. then turn the crank to get it on then tighten the bolts its a pain
Sent from my SCH-I510 using Tapatalk 2
#19 | |
well i'll worry about that after i dial the cam in
#20 |
couple of pics, just to show you guys the proper tool for holding the tensioner. not that it matters much a simple nail will do the trick
#21 |
oh its really going to be fun trying to get the pickup tube bolt back in after i install this timing chain set that requires you to shim out the pump. haha gotta love life
#22 |
Thanks for posting the pictures. Even though mine is done they have been real interesting. That tensioner is sure a cheesy looking thing. And good luck getting that oil pump pickup line back on. That's the thing that put me off from doing it myself.
#23 |
yeah that tensioner is a real piece of shit. looked like it was going to break when i sqeezed it. I'll get the pump in somehow, might have to have my dad pry the pickup tube forward a tad while i try to get the bolt started.
#24 | |
![]() Drives: cts-v Join Date: Dec 2011
Just in case you weren't aware of this already, but you will need to clearance your front cover after installing that timing set. You may also need to "adjust" the mounting legs on the oil pump pick-up to pull it forward enough to get it installed properly. Also recommend switching to a damper instead of that tensioner, especially with the double chain.
#25 |
Anabolic Connoisseur
Drives: 2012 Camaro 2SS/RS LS3 - 2007 Tahoe Join Date: Sep 2010
| Thread Tools | |
| OK...I'm starting a better V6 exhaust examples thread!! | KMPrenger | Camaro V6 LLT Engine, Exhaust, and Bolt-Ons | 507 | 06-11-2013 12:58 PM |
| Cam basics | CamaroSpike23 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 59 | 01-27-2013 07:28 PM |
| should i have GM dealer install jannetty racing cam and long tubes | Yellow1lt | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 8 | 01-05-2012 07:29 PM |
| Cunningham Motorsports Cam install Packages | Ryne @ CMS | USA - California | 6 | 01-26-2011 12:38 PM |
| Another L99 cam question....VVT! | SS-screamer | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 90 | 06-28-2010 06:41 PM |
