Old 04-09-2012, 10:03 PM   #1
bigwayne3000
Drives: 2011 Camaro LS
Adams APC question
Bought a gallon of the stuff and plan on washing my car sometime this week. Can I use it straight or do I need to dilute it in order to use it on the paint and engine compartment?
bigwayne3000 is offline   Reply With Quote
Old 04-09-2012, 10:13 PM   #2
The Stig
knows 2 facts about ducks
The Stig's Avatar
you don't wash your car with All Purpose Cleaner. You use Adam's Car Shampoo. APC is too harsh for washing the car.
Click to view my build thread
Old 04-09-2012, 10:15 PM   #3
bigwayne3000
I wasnt going to use it to wash the car, I was going to use it on certain spots that have tar (I've tried Bug and Tar remover and it still doesn't come off) and I was going to use it to mist the engine compartment to clean that.
Old 04-09-2012, 10:20 PM   #4
The Stig
The Stig's Avatar
Ah. When you said "wash the car" I thought you meant you were going to wash the car. You don't need to dilute the APC, but just rinse off the area with water after you've sprayed it down and you should be fine.
Dylan please feel free to correct me if I'm giving false info.
Old 04-09-2012, 10:33 PM   #5
bigwayne3000
Thanks for your help. Should have been more clear originally. Thanks again!
Old 04-09-2012, 10:44 PM   #6
camaro2ssblack
camaro2ssblack's Avatar
Drives: 2010 Camaro 2SS - Black on Black
IMO, I would only use APC at full strength if you have to. You will get so much more mileage out of a gallon by diluting it with water at least 50%. However, with tar you may be forced to use full strength. If your car stays relatively clean, you wont need full strength for general maintenance washes.
camaro2ssblack is offline   Reply With Quote
Old 04-10-2012, 11:39 AM   #7
Adam's Polishes
Adam's Polishes's Avatar
Drives: The shiny ones.
Usually a 50% mix with water is strong enough... start with it diluted to see if it does the job, if it doesn't then amp it up a bit. Be sure not to spray onto anything while its hot... especially wheels.
Old 04-10-2012, 03:17 PM   #8
DangerZL1
Drives: Future ZL1 Owner
WD-40 works great at removing tar and won't harm your paint.
DangerZL1 is offline   Reply With Quote
Old 04-10-2012, 04:56 PM   #9
Mark's SS
Mark's SS's Avatar
Drives: 17 Silverado 2500HD LTZ 4x4 Duramax
I know I have recommended this before, but this stuff works really fast removing tar.
Mark's SS is offline   Reply With Quote
Old 04-10-2012, 05:14 PM   #10
ibmrs
ibmrs's Avatar
Drives: 2011 2LT RS IBM
Really? MSDS says that it contains Dichloromethane, also called methylene chloride. That chemical is widely used as a paint stripper and a degreaser. Specifically used to remove clear coat. Brilliant.
Won't be using that on my paint, ever.
Retract previous statement, i mistakenly read the MSDS for the liquid, not the spray can. sorry.
Tampa Bay Camaros, Team LLT
ibmrs is offline   Reply With Quote
Old 04-10-2012, 05:26 PM   #11
Mark's SS
Mark's SS's Avatar
I read the MSDS for this product and it does not have the component that you mentioned. I just know that I have used it and it did not damage the paint.
Old 04-10-2012, 05:36 PM   #12
=Stephens=
=Stephens='s Avatar
Drives: 2011 LS
APC works great at full strength on road tar. I had some on mine behind the rear wheels, sprayed it on there, let it set for a few seconds and it wiped off. I was very impressed.
=Stephens= is offline   Reply With Quote
Old 04-10-2012, 05:48 PM   #13
Mark's SS
Mark's SS's Avatar
Maybe the gum and adhesive remover is a little too strong for some people to use. I just used it to remove a lot of tar when nothing else would do the job. I will say use it at your own risk. But it did work for me. Sorry if this was not a good recommendation for others.
Old 04-10-2012, 05:53 PM   #14
Mark's SS
Mark's SS's Avatar
That's cool. I was getting worried that I told people to use something that would remove their paint. The stuff really does a number on tar. Maybe it is too strong.
Another A+ for Adams & Dylan fz6r Vendor and Seller review / feedback / experiences 1 02-20-2012 05:22 PM
Current Specials at Detailer's Domain DetailersDomain Wash/Wax/Detailing and Cosmetic Maintenance Parts 30 12-21-2011 10:23 PM
Question on Americana wax from Adams bigwayne3000 Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 4 11-16-2011 11:42 AM
Adam's question ctk1 Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 12 10-28-2011 11:22 AM
Adam's Leather Cleaner & Conditioner 2LTRS Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 14 07-16-2010 03:04 PM
