Cold Air Inductions
Old 04-10-2012, 09:09 PM   #1
Wuiquen
Wuiquen's Avatar
Drives: 2011 Summit White 2LT/RS
Water dripping from Exhaust pipes...HELPPPP!!
Hey guys,
So last night as I worked on changing my bumper, I was doing a inspection of the underside of the car and realized that I had water dripping from the mid section of my exhaust. It is right were the X pipe connects to the pipes coming from the headers. I took a look at it and the pipes at that connection are rusting pretty bad. is this normal?? if there is water dripping out, isnt there also air leaking out??? Do I just need to make the connection tighter to make sure no water comes out??? what got me is that it was a lot of water in a matter of 3 hrs or so.
Any advice would be appreciate it,
Wuiquen is offline   Reply With Quote
Old 04-10-2012, 09:16 PM   #2
Muscle SS
All blackkk
Drives: 2010 2SS/RS LS3
That looks really bad, I would take it to the dealer ASAP! Maybe even get it towed, that is scary stuff
Drivin it like I stole it.
Muscle SS is offline   Reply With Quote
Old 04-10-2012, 09:22 PM   #3
The Stig
knows 2 facts about ducks
The Stig's Avatar
Looking at the pics I can tell that the exhaust clamps aren't tight enough. Also, do you have a catch can installed?
Click to view my build thread
Old 04-10-2012, 09:30 PM   #4
usafboy
usafboy's Avatar
Drives: 2010 Silver SS/RS LS3
wow are these pics from the future?!?! 2198
2010 Silver Ice Metallic Camaro SS/RS LS3
Mods...so far: resonator/muffler delete, tinted everything, '13 shift knob/boot, bowtie delete, PFADT sway bars, CAI intake, Hurst short shifter, JBA cat deletes, BMR trailing arms/outer bushings/steering rack bushing, Bo White ported TB.
Rhino79 Dyno tuned...405 HP/399 TQ
usafboy is offline   Reply With Quote
Old 04-10-2012, 09:32 PM   #5
iHasCamaro
Drives: Silver 2012 1SS
An exhaust catch can? Lol.
iHasCamaro is offline   Reply With Quote
Old 04-10-2012, 09:34 PM   #6
Wuiquen
Wuiquen's Avatar
Yeah i do have a catch can. Why??? Well the car runs just fine... no problema at all...
Old 04-10-2012, 09:39 PM   #7
Wuiquen
Wuiquen's Avatar
Why do you say that?? The lighting??? It was like 4 am last night.. sory i was part of the pics... that looks scary at first
Old 04-10-2012, 09:42 PM   #8
ColdCamaroSS
ColdCamaroSS's Avatar
Drives: 1
Water is a by-product of combustion, this is normal tighten your clamps and drive your car. I suspect you let it idle alot too.
ColdCamaroSS is offline   Reply With Quote
Old 04-10-2012, 09:44 PM   #9
rlem00
Drives: 2010 Camaro 2SS
condensation in the exhaust pipe. When you drive your car the exhaust gets hot as it cools the air condensates and collects in the pipes. If you drive only short distances you might let the exhaust get hot, but not evaporate all the water that was already in the pipes. Try some longer drives to get the pipes hot for a while (30 min at least) then see what it looks like. Being in DE I would bet it's still pretty cool at night too so that will make it worse.
rlem00 is offline   Reply With Quote
Old 04-10-2012, 09:50 PM   #10
Burnt_RS
Burnt_RS's Avatar
Drives: '10 1LT/RS
My car is terrible for this too. It leaks at the clamps where my SLP axle back exhaust connects. The clamps are tight but it still leaks. I have had mine stored for the last 5 or so months. Upon changing my oil a few weeks back (put the car on front ramps) the car left a relatively large puddle on the floor, not much different than in your pictures. It happens, no concerns at all. Just like others have said, its condensation. Mine is particularly bad because I start my car through the storage time and let it run for 15 mins. the exhaust doesn't get very hot so the water continues to accumulate in the exhaust. Nothing a good run wont fix, when I put it on the road in a few weeks.
Burnt_RS is offline   Reply With Quote
Old 04-10-2012, 09:56 PM   #11
Superman09
Account SNAFU
Superman09's Avatar
Drives: 13 Tahoe 79 Scout II 15 1LE
Perfectly normal byproduct of internal combustion. If you are terrible worried about it drill a small hole in the low point of you exhaust system or right where you see the water and install a small sheet metal screw. When you park your car remove the screw the water will drain out easily and won't collect in your pipes.
Sent from my campfire using smoke signals
Superman09 is offline   Reply With Quote
Old 04-10-2012, 09:59 PM   #12
The Stig
The Stig's Avatar
an oil catch can to prevent blow by in the PCV system
Old 04-10-2012, 10:40 PM   #13
KMPrenger
KMPrenger's Avatar
Old 04-10-2012, 10:42 PM   #14
turboguy327
Banned
Drives: 2011 Chevy Camaro
You do know that's the worst thing you can do with a stored car right??
turboguy327 is offline   Reply With Quote
Official 1/4 Mile (V8) 2010+ Camaro Fast List Merc Dragstrip and Launch Techniques Discussion 3448 01-15-2018 12:30 AM
My second exhaust build this time with j pipes IDEALG Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 39 09-21-2012 07:27 AM
NEW GROUP BUY- Solo Performance Axle Back with J pipes & Mach XL (L99) with J Pipes GOINGSOLO2 V8 Bolt-Ons & Tunes 130 12-20-2011 08:15 PM
Exhaust Question Why do we need X or Y pipes rackmaster Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 1 03-12-2011 03:00 PM
Exhaust Theory revisited Wacker Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 3 11-23-2009 11:12 AM
