ADM PERFORMANCE
Camaro Issues / Problems | Warranty Discussions | TSB and Recalls Report, discuss and diagnose any issues and problems with your Camaro, including warranty discussions.
Old 04-27-2012, 12:27 AM   #26
AdamZ
AdamZ's Avatar
Drives: Eve - 2011 Camaro 2SS/RS
Good thing I sold my 2012 LS and got an 11 2SS
AdamZ is offline   Reply With Quote
Old 04-27-2012, 03:12 AM   #27
THUMPER20X
GM fix my PAINT U suck!
THUMPER20X's Avatar
Drives: 2010 Black 1SS/RS 6Spd
Originally Posted by liquidsmoke View Post
Prob not. They likely will just glue it back down instead of replacing it.
No chance of that it'll keep lifting.
THUMPER20X is offline   Reply With Quote
Old 04-27-2012, 04:45 AM   #28
OPP
OPP's Avatar
Drives: 45th anniversary SS Coupe L99
Checking in. Mine has the same problem since I drove it off the lot. I may get it replaced when they figure out a better solution for it.
OPP is offline   Reply With Quote
Old 04-27-2012, 06:30 AM   #29
djm96z28
djm96z28's Avatar
Drives: 2012 Camaro 1SS LS3
Can you press on the area and feel a loose space between it and the dashboard? Mine sort of looks like that in a small area, but when I press on it, there is no give at all. It seems attached to the surface below it.
Also, if you look at it from the side, can you see the raised spots from that angle? Mine looks pretty flat from the side, so I'm not sure if I have this problem (yet) or not.
djm96z28 is offline   Reply With Quote
Old 04-27-2012, 08:07 AM   #30
strych9
U can't handle the truth
strych9's Avatar
Drives: 2012 2SS/RS/TF3
I'm always paranoid about dash damage from sunlight. That's why the first thing I do is get the windows tinted dark, and I always put up a windshield shade when parked in the sun.
@ 900 miles as of this morning, dash is perfect. I'll keep a sharp eye on it.
SP 1 7/8" LT Headers | Cat Delete | Flowmaster AT Cat-back | CAI Intake | JRE Scoop | Jannetty Tune
**1 of 371 total TF3 SS 6-speeds built**
strych9 is online now   Reply With Quote
Old 04-27-2012, 08:12 AM   #31
DuhKoDuh
DuhKoDuh's Avatar
Drives: 2011 Camaro 2SS/RS (Black) L99
Originally Posted by BowtieBelle View Post
Glad it's not an issue on our '10's-11's!
X2
DuhKoDuh is offline   Reply With Quote
Old 04-27-2012, 08:16 AM   #32
_Nick_
Drives: '87 T/A, '87 IROC
Landau top adhesive should hold it down permanently if it is seperating from the plastic dash, but that isn't exactly easy to obtain.
_Nick_ is offline   Reply With Quote
Old 04-27-2012, 08:27 AM   #33
powerslave
Assembly: April 12/12
powerslave's Avatar
Drives: A Self-Propelled Mechanical Vehicle
Mine looks fine and it's the same as the pics since I drove it off the lot. It looks like leather stretched over plastic, which looks much better than plastic... If an edge lifted or something then I'd care.
EDIT: No "give" to it.
powerslave is offline   Reply With Quote
Old 04-27-2012, 09:01 AM   #34
Fiveg56
Drives: Yes
Just curious cuz I have a 2010, but is the dash even real leather or is it just like the leather on the rear seats, which is not real.
Not sure if it's real....it looks and feels like leather to me. It's nice upgrade from the 10-11 dash, but not if it's going to start falling apart. No problems on mine yet, but I'll be keeping an eye on it.
Fiveg56 is offline   Reply With Quote
Old 04-27-2012, 09:16 AM   #35
garcmol
garcmol's Avatar
Oh crap. I'm getting visions of C5 Corvette doors. Same thing happens (to some). Not good.
The Corvette leather is vacuumed/glued on and there are little sealed holes on the back of the door skin. I don't know if it would be the same for the Camaro leather on the dash, and frankly I can't see a way to get behind it.
http://forums.corvetteforum.com/c5-g...up-how-to.html
This is a how to on that process. Someone may be able to use part of the write-up to find a fix or a DIY. Good luck OP, hope this gets fixed for you!
Old 04-27-2012, 09:47 AM   #36
THUMPER20X
THUMPER20X's Avatar
its definitely because its a triple curve in the area. As everything contracts and expands it pulls it away from the dash carrier, this is ultra common on alot of older exotic cars, thats why now you rarely see leather wrapped in an indent bordered by two humps. It's a bit of a cardinal rule of upholstry and surprised GM did this. I could see them TSBing this to swap in to a 10-11 dash carrier. It's just a bad idea on a dash they coulda left as it was and just upgraded the console stack, dash cluster etc. Hizzah!!!!! for my bland plastic dash lol.
Old 04-27-2012, 04:43 PM   #37
hawk02
Convertible threepeat
hawk02's Avatar
Drives: 2013 Victory Red ZL1 Convertible
Originally Posted by blackswan View Post
The strip of dash just under the center vents has a bubble in it that seems to have formed over time (I know it wasn't that way a few months ago).
Anyone else have this?
When I wipe that area of dash it makes a popping, crackling sound. I'm guessing the glue has lost its hold and it's just a matter of time before a bubble appears.
hawk02 is online now   Reply With Quote
Old 04-27-2012, 04:46 PM   #38
FL1CK
MOVE!
FL1CK's Avatar
Drives: 2011 Camaro
Originally Posted by 11BEE View Post
We have a 2011 RS V6 that is my daily driver to and from work. I am one of the bad Camaro drivers that puts about 20K a year on my car.
We also have our weekend car (actually my wife's that she lets me think I have some ownership in) which is the 2012 2SS 45th Anniversary package. That is the one having the issue.
I am not childish, you're just being a poopy head!
FL1CK is offline   Reply With Quote
Old 04-27-2012, 04:52 PM   #39
11BEE
11 BEE
Drives: 2011 LS2 RS & 2012 2SS RS 45th Vert
Mine visibly move around and you can see where air has filled in to the bubbles.
11Bee and I♥My45th
11BEE is offline   Reply With Quote
Old 04-27-2012, 05:01 PM   #40
awfarley
awfarley's Avatar
Drives: 2011 5.7L Tundra Double-Cab X-SP
Yes, I was going to post the exact some thing until I found this thread. I can replicate your image 100%. Mine is bubbling in the exact same spot.
Will post photo when I get home.
I understand its just a bubble, but I didn't put my money into something new to have an inferior quality dash panel come apart. Talking to my dealer soon.
awfarley is offline   Reply With Quote
Old 04-27-2012, 05:43 PM   #41
strych9
strych9's Avatar
If it's a widespread enough problem, they will issue a TSB to address it. Unless you're nearing the end of your 3/36 warranty, it would be best to wait to see if a TSB comes forward. Why? If you don't, they'll just put the same inferior design right back in the defect's place. Don't know about any of you, but I really don't want a tech tearing into my interior any more than is absolutely necessary. If anything, have them draw up an invoice to show the complaint, but don't let them fix it. That will at least make GM aware of the issue. My $.02
Old 04-27-2012, 05:51 PM   #42
Hurst equipped
Hurst equipped's Avatar
Drives: 02 ceta
+1 i agree..
only a problem of not enough glue..
Hurst equipped is offline   Reply With Quote
Old 04-27-2012, 05:53 PM   #43
awfarley
awfarley's Avatar
Good Point.
Old 04-27-2012, 05:57 PM   #44
cmb74656
cmb74656's Avatar
Drives: 2011 Camaro 2SS/RS CGM/BLI A6
Originally Posted by _Nick_ View Post
Landau top adhesive should hold it down permanently if it is separating from the plastic dash, but that isn't exactly easy to obtain.
It's probably been banned because it's not 'environmentally friendly.'
Dan Wheldon (1978-2011)
MODS: RX Performance catch can, Jegs CAI, ZL1 grille, chrome license plate frame, GM locking gas cap, Defender Worx chrome DRL bezels, GM molded splash guards, Oracle LED side markers, DRLs, tag lights and reverse lamps, Technostalgia Rapid Fire tail lamps, Vitesse shift paddle extenders, MBRP cat back.
FUTURE: front splitter, slotted/drilled rotors, leather console and e-brake handle boot, remote fuel door and rear seat release, sway bars and bushings.
WISH LIST: Edelbrock E-Force SC, LS3 conversion
cmb74656 is offline   Reply With Quote
Old 04-27-2012, 07:22 PM   #45
awfarley
awfarley's Avatar
Here ya go. Small ones forming on the right and left of the main one...
Old 04-27-2012, 10:12 PM   #46
blackswan
blackswan's Avatar
Drives: 2012
Same
blackswan is offline   Reply With Quote
Old 04-28-2012, 07:39 AM   #47
My Caroline
My Caroline's Avatar
Drives: Black 2011 Camaro LS
Uh oh. Wonder what's gonna happen when it reaches 110 here in Texas? Is the whole interior gonna melt?
White Fender Hashes from Big Worm Graphix
Custom White Bowties
GM Factory Remote Start and Factory Key Fob
SS Fascia
Factory RS HIDs
Plasma P13W fog lights
Non-RS to RS and fog light harness by Gen5DIY
LED Interior, Trunk, and Licence Plate lights in white
Stock SS 20s (Coming soon)
My Caroline is offline   Reply With Quote
Old 04-28-2012, 07:51 AM   #48
Satins Spawn
Drives: Black SS
nope
Satins Spawn is offline   Reply With Quote
Old 04-28-2012, 02:42 PM   #49
Chevrolet Customer Svc
Drives: GM Vehicles
At this point in this issue I would suggest that everyone who has this get it checked over by your dealers and see what they can do for you. Hopefully that gets it fixed. If not let me know and I'll do what I can to help all of you.
Jeff Morris, Chevrolet Customer Service
Old 04-28-2012, 02:54 PM   #50
blackswan
blackswan's Avatar
Drives: 2012
Who said this was heat related?
F/S: Alpine Dash Kit and W910 Combo! pyr0b0y Local Marketplace 23 07-22-2012 12:18 AM
Is there Interior ambiance lighting across dash? Bumblebee2012 Cosmetics and Lighting Modification Discussions 10 03-09-2012 09:34 PM
Where to buy dash inserts? OHIOSS Cosmetics and Lighting Modification Discussions 3 02-27-2012 04:34 PM
Dash Panel Swap -- FOR ANYONE LOOKING TO DO ABL MOD 2010ABM USA - Texas 6 05-25-2011 10:57 AM
Dash Scratches what to do? strauchpete Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 0 02-14-2010 07:07 PM
