HURST
Old 04-11-2012, 10:00 PM   #1
brucedd
Drives: xxx
Creative Solution Needed
Once my ZL1 is delivered, I will have the polished 5-spokes powdercoated. This means I need to get all 4 wheels off the car, tires removed and wheels to powdercoater for 2 or 3 days.
Does anyone have any creative ideas how to leave the car safely for 2 or 3 days without the original wheels & tires?
Given the underside of the ZL1 (and other factors) I really dont like putting it up on jackstands. Does anyone know if some really cheap existing wheels fit the ZL1 over the Brembos OK so I might buy used wheels and tires to just let sit for 2 days?
Can you think of any other creative solutions?
Thanks in advance for any suggestions you might have!
Bruce
brucedd is offline   Reply With Quote
Old 04-11-2012, 10:53 PM   #2
Chavira2009
Chavira2009's Avatar
Drives: 2011 Camaro 2SS/RS M6 Hurst RJT
You should be ok just laying it on some jack stands, but I do understand your concern for the suspension, it having magnetic ride and all. If you do use jackstands, make sure you put them in the right places, so you don't damage anything underneath. But if you could get some wheels to set it on, it wouldn't be such a bad idea. Anyways, congrats on the new ZL1!!! Enjoy.
Chavira2009 is offline   Reply With Quote
Old 04-12-2012, 12:59 AM   #3
brucedd
Drives: xxx
Thanks! I don't have it yet, but my concern with the stands is more that there are no exposed jack points or frame to place the stands. At least it seems so from the underside pictures posted due to the huge underside pan.
Thanks again-
Bruce
Old 04-12-2012, 01:23 AM   #4
ZL1Dave
ZL1Dave's Avatar
Drives: 2012 ZL-1 #1442
There is a thread on here about a product called Jackpoint jack stands You should check them out might just what your looking for
ZL1Dave is offline   Reply With Quote
Old 04-12-2012, 02:25 AM   #5
brucedd
Drives: xxx
Thanks, I saw it in the ZL1 First Oil Change thread and ZL1 Jack Points Thread. It is a possibility, BUT the are a little pricey, almost better to buy 4 cheap new wheels and tires.
Thanks for the thoughts!
Old 04-12-2012, 02:41 AM   #6
S3XPanther
by Odeon
S3XPanther's Avatar
Drives: '12 SS/RS A6 IOM SOLD, '13 1LE IOM
I was just about to post that. They seem like your best option.
"It works 60% of the time, every time."
"Some say it's a waste of time, others say it's an incredible waste of time."
"The ultimate measure of a man is not where he stands in moments of comfort and convenience, but where he stands at times of challenge and controversy."
2013 IOM SS/RS - 1LE. Born 5/6/2013 (1 of 32 1SS IOM 1LE's)
S3XPanther is offline   Reply With Quote
Old 04-12-2012, 10:36 AM   #7
brucedd
Drives: xxx
For 4 stands and the jack, it is ~$1,000. Reusable I know, but very little future need.
I am hoping something not as steep as this would make the overall cost of this powdercoating project in excess of $2000. I think I would buy new wheels before I go that steep.
Any thoughts on wheels / tires known to fit the ZL1?
Thanks for the ideas so far!
Old 04-12-2012, 10:41 AM   #8
Joebot8484
ZL1 # 1307
Joebot8484's Avatar
Drives: 2012 Camaro ZL1, 2008 Hummzilla H3
Cut four disks out of 3/4 inch plywood, drill the holes for the lugs and bolt them on. I'm not saying it will work, but I've seen it done before and it's a cheap way to get r done!
Click on my signature for my build thread
Joebot8484 is offline   Reply With Quote
Old 04-12-2012, 10:46 AM   #9
noxqq
noxqq's Avatar
Drives: '14 C7 Z51 VY & '16 Z06 LBR
Plywood wheels...interesting. Might just work.
I was going to be a smart azz and ask if concrete blocks were out of the question.
I have been watching this thread myself because I was planning on doing some wheel mods when/if my order ever gets picked up.
noxqq is offline   Reply With Quote
Old 04-12-2012, 11:34 AM   #10
brucedd
Drives: xxx
And I could custom paint them myself! Wonder how they would do with launch control? ;-)
I do like the creativity factor, but this feels a bit too high risk.... and I suppose for standing only the could have flat bottoms?
Thanx guys, please keep 'em coming!
Bruce
Old 04-12-2012, 11:36 AM   #11
HDRDTD
That's what they did for one of the project cars on the TV show 'Musclecars (I think)' as part of Powerblock TV.
They cut round pieces of 3/4 plywood, drilled holes for the wheel studs and hub, and just bolted them on like a wheel.
Old 04-12-2012, 11:53 AM   #12
Joebot8484
ZL1 # 1307
Joebot8484's Avatar
Yup, thats the last place I've seen that done. I've also seen it somewhere before. If 3/4 inch doesn't interest you how about 1"? I'm not saying, I'm just saying....
Old 04-12-2012, 12:05 PM   #13
adamgl
adamgl's Avatar
Drives: '98 Camaro Z28, '06 Z06
Roll up on some ramps. Take off the front aero stuff. Then you have room for a jack on the K member and jack stands???
'10 Camaro 2SS/RS A6 Sold :( ARH, FM Super 44's, K&N CAI, ADM scoop, Diablo Tune, RX catch can.
'98 Camaro Z28 M6 TSP headers, true duals, AIR/EGR/AC/muffler delete, CAI, Subframe con.,
shock tower brace, Stg. 2 T56 rebuild. Monster Clutch Stg. 2, Electric Water Pump, TT2 wheels, 315 NT555's
'06 Z06 2LZ, Cam, P/P/M Heads, FAST Intake/TB, ARH, CAI, HP Clutch/FW, C5 Axles,
Pfadt Coilovers/Poly Bushings, Carbon Fiber: Everything, lol. HID's, 360 Forged Spec 5's/Invo's, Custom Interior. 550 RWHP
http://www.camaro5.com/forums/showthread.php?t=235911
adamgl is offline   Reply With Quote
Old 04-12-2012, 12:08 PM   #14
2001ragtop
2001ragtop's Avatar
Drives: V8 american car
gm plant location of 4 lifting points of camaro
I would try to lift the car at these points located under the car. I assume the jacking points in the owners manual are these same places shown in this photo below.
(GM plant location of 4 lifting points of camaro After the suspension is already installed. taken from Rick Mercer comical video where he visited GM Plant.)
If that's where THEY lifted the car, then that's where you should lift it. I would get four hydrualic jacks and place them in those 4 spots.
Everyone else on this website puts a jack under the front engine frame brace. It doesnt sound like you should do that.
2001ragtop is offline   Reply With Quote
Torque Solution Short Shifter for your camaro!! @ IIR******************************** ImportImage Transmission / Driveline 71 11-06-2011 05:42 PM
SS sway bars on v6? jatt5ab1soorma Suspension / Brakes / Chassis 9 07-07-2011 09:32 PM
Brake system experts, help needed (non-Camaro) Rogue Leader Suspension / Brakes / Chassis 12 06-07-2011 11:46 AM
Oracle HOD Input Needed (solution to yellow halogen) Tshepp Cosmetics and Lighting Modification Discussions 11 05-07-2011 09:51 AM
