Old 04-12-2012, 12:47 AM   #1
partymn
partymn's Avatar
Drives: 2014 1ss 1LE
Axle play
I have been having some sloppiness in the drivetrain, a chatter when I push in the clutch. Its not a big deal because I feel that its normal for a manual car, just seems to have gotten worse over the coarse of 12K miles. I got under the car today checking to see if I had anything obviously wrong and noticed a lot of play on my right axle where it connects to the wheel. When I grab it I can move it in and out about half an inch, the left side is tight and has no movement at all. How much play can be expected from this area and could it be exasperating the chatter that I am feeling?
2014 1SS 1LE, bone stock for now.
partymn is offline   Reply With Quote
Old 04-12-2012, 02:10 AM   #2
Slickcas
Drives: 12' 2SS/RS LS3 IBM
Take the tire off and make sure the nut is tight on the shaft. Forgot the size 23mm or so. Hard to say if that's your problem.
Slickcas is offline   Reply With Quote
Old 04-12-2012, 11:15 AM   #3
partymn
partymn's Avatar
Interesting, thanks. I wander what would cause the neut to back off. I will check it.
Trade: My SLP Loudmouth 1 Axle Back for your? hoffmk2003 V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment 5 01-06-2011 06:45 AM
Camaro's axle to be produced in GM's Mexican assembly plant. Bruno 5th Gen Camaro SS LS LT General Discussions 31 10-27-2010 11:43 AM
MagnaFlow Axle Back w/ Mufflers - Install and Review (now with drone!) themossman Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 29 07-12-2010 09:56 AM
New Camaro 4130 and 300m Axle packages coming soon GFORCE1320 Transmission / Driveline 4 01-16-2010 04:21 PM
AR Headers And Axle Backs A.R. Headers Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 2 09-09-2009 08:50 PM
