Old 04-12-2012, 02:39 AM   #1
v6
v6's Avatar
Drives: 2012 45th 2LT RS
Intake manifold insulator for the LFX?
Any news on products being worked on for the LFX yet? Will they even be available to this engine? Sure hope so, thanks!
v6 is offline   Reply With Quote
Old 04-12-2012, 08:10 AM   #2
Lil' Nasty
[COTW 4/13/15]
Lil' Nasty's Avatar
Drives: Supercharged LLT
Well knowing the manifold for you guy's is an composite IM I believe it doesn't get as hot as the 10-11's. I think they will come out with something, the LFX is slowly coming out with the vararam and ported TB soon
Lil' Nasty is offline   Reply With Quote
Old 04-12-2012, 11:11 AM   #3
sebi1990
Drives: 2012 v6 LFX M6 Black Camaro
Mmmmmmm vararam mmmmmmmm!
Cant wait!
sebi1990 is offline   Reply With Quote
Old 04-12-2012, 11:14 AM   #4
SC2150
Just need a local car to testing the 2012 VMax CNC TB and it will be released soon....
Old 04-12-2012, 01:21 PM   #5
meissen
Founder - Michigan FBody
meissen's Avatar
Drives: 1994 Camaro LT1, 2016 Camaro LT
The purpose of the insulator is to disconnect the metal intake manifold from the engine thus reducing its temperature and reducing the air temperature as it passes through the intake manifold. Since the 2012 intake manifold is composite, it seems like it wouldn't be necessary.
Now I do understand that the added bonus is it also elongates the runners on the LLT, that'd still be an applicable mod on the LFX.
2016 Camaro 1LT V6 A8 - "Elmo" - LGX V6 with 8-Speed Automatic, NPP Dual Mode Exhaust
1994 Camaro LT1 A4 - "Red Alert" - v6-to-LT1 Swapped Cruiser; Cammed, Stalled, Enjoyed
"Gone But Not Forgotten"
2014 Camaro 1LT M6 - "Cherry Bomb"
2012 Camaro 1LS M6 - "Clifford"
Michigan FBody Association
http://www.mifbody.com/
meissen is offline   Reply With Quote
Old 04-12-2012, 02:31 PM   #6
v6
v6's Avatar
Sweet!!
Sent from my iPad using Tapatalk
Old 04-12-2012, 03:04 PM   #7
KMPrenger
KMPrenger's Avatar
This.
There is probably not much of a point of using an insulator to keep the manifold cool on the LFX since it is composit...it should work well for that on its own. But there could be some benefit from the added runner length to help provide some low end TQ.
I'd like to see this for the LFX.
Old 04-12-2012, 03:32 PM   #8
meissen
meissen's Avatar
Yeh, in that case it'd just be a spacer instead of an insulator.
Old 04-12-2012, 06:37 PM   #9
IneedAZ
IneedAZ's Avatar
Drives: 2017 ZL1 A10 & 2012 2LT RS
Does this upgrade require a tune?
2012: e85, 80mm TBody, CAI w/scoop, Solo HFC, ZL1 FP, Magnaflow TruX, Dynomax VT, Elite catch can, HP Tune, Throttle Contoller, BMR; Springs, Sways, Trailing Arms, Toe Ends, & Safety Loop, Koni str.t, Pioneer Z150bh, Phoenix Gold Sub, Hertz speakers & 5ch Amp, 1LE rear with 3.91 gears, BMR bushings, Baer Decela Rotors, Goodridge brake lines, Brembo(GM) 4 piston calipers, Hawk Ceramic pads, ported intake, Circle D 5c. 12.3@112 old setup
2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17
IneedAZ is offline   Reply With Quote
Old 04-12-2012, 06:42 PM   #10
HopeRidesAlone
HopeRidesAlone's Avatar
Drives: 2010 Camaro Black 2SS/RS
Not that anyone has noticed because like whats been said on the LLT the main gain is from where reduction in heat on the IM.
2010 Black 2LT/RS - Injen CAI, ARK DTS Catback Polished Tips, OBX LT Headers, Lowered on Eibach, 3/8 blackiceolator, Trifecta Tuned.- Totaled 3/10/13
2010 Black 2SS/RS - Stainless powers 1 7/8 LT headers, cold air inductions cai, Tuned by dynosteve, Feesler side skirt, Feesler Spoiler, Feesler carbon fiber bowties, H&R Lowering Springs.
HopeRidesAlone is offline   Reply With Quote
Old 04-13-2012, 07:20 AM   #11
IneedAZ
IneedAZ's Avatar
Sorry, last post was in regards to this item. Does this item require a tune? What gain did the 2011/2010 get from this item. I have a 2012.
Old 04-13-2012, 12:55 PM   #12
bmorecam
Not true HOPE. I know there's been tons of debate over this ever since mace and vmax came out with the insulators, but the independent dyno that hapi provided for both insulators on the same engine and on the same day both ran within an hour clearly show that the extra increase in runner size provided alot more hp/tq in the low to mid rpm over the vmax. The increased runner size however did have a small downfall pass 6k rpm but nothing significant.
I am 100% positive the LFX can also benefit with extra runner length. GM engineers clearly stated that the extra hp bump was due to increased intake valve size and more efficient cylinder head design with it's integrated exhaust manifold. Not because of heat reduction due to plastic manifold. The plastic manifold was simply a cost reduction change and nothing more.
Old 04-13-2012, 03:34 PM   #13
RJT Impala
Stovebolt BluFlame 6
RJT Impala's Avatar
Drives: '12 2LT/RS, IBM; '14 Malibu LTZ
It's essentailly doing the same as the old cross-ram manifolds on the dual 4-barrel Z-28s in the 1st generation. Increases the flow of air into the cylinder due to the dynamic pressure and size/volume/length of the air column.
RJT Impala is offline   Reply With Quote
Old 04-13-2012, 04:44 PM   #14
SC2150
The VMax cnc LLT unit shows 4-6 rwhp.
On the heat issue, this one subjet (and its rare) I disagree w/bmore.
We have been doing the heat reduction HP increases for the past 20 plus years. Examples.
BBK 90 MM aluminum intake VS composite LS6 75mm. We saw the LS6 outperform the BBK aluminum in every type testing we did (the 90mm should have more than made up for the heat, but did not). But, when we iced the intake down between runs the BBK would gain 12-18 rwhp for that next run and then heat back up and loose the power.
Our 1000 plus HPdrag motors, we would see 20 plus HP gain with a thin heat shield, but when running methanol that made the alum single plane cool to the touch w/out the spacer we gain more than the spacer alone (Methanol gives extra power over race gas anyway).
And then look at the the videos.....we are reducing a solid 30-35* the temp of the LLT alum intake manifold with the VMax Iceolator....and that is more cooler than the Honda 4 cylinders we used to make these for where we saw around 12 whp gain from the same thickness.
Now, that is not to discount the runner legnth adding some torque, as we did this for years with early fuel injection on our race motors. We would tune each runner length to that specific cylinder. We then did a ton of sheetmetal intake designs to move the powerband, and look at the old Mopar Max Wedge cross-rams....they were 3' long!
The heat issue is something we have worked with for over the past 20 years and can show gains on any motor we cool the intake on.
One last example: My old Dodge Viper. We tried to design and manufacture a composite intake manifold years ago for the power gains from eliminating the heat soak the aluminum intake was experiancing but it would have been close to a $500-700k investment and we could not follow through. What we did see, was run it on the dyno warmed up, ice down the intake maniold, and we would do a run and see between 40 & 60 rwhp more. That was also no runner length change, only the temp difference (that was close to 50* F).
But, we aregoing todoa 1" thick Max iceolator for testing and will report back on the findings. We also have a few othersurprises instorebut cant say more until they are proven.
Cold Air Inductions Intake System! ADM Performance Cold Air Scoop! & Packages! AutoAgenda V8 Bolt-Ons & Tunes 438 11-23-2013 11:49 PM
Vmax ICEolater and RX Ported Intake Manifold OOLIE Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 42 02-25-2012 10:53 AM
3800 intake manifold Gr8_syder 4th Generation Camaros 2 12-24-2009 09:32 AM
