| USA - Florida The Sunshine State |
Thread Tools |
![]() Drives: 2012 Camaro RS Join Date: Apr 2012
SQUEAK NOISE DRIVING ME NUTS!!!!
Hey guys, I have a 2012 RS and when driving for a few mins and going over uneven roads or slight bumps there is a squeaking noise coming from the drivers side on the inside, i've checked all the pannels and mad sure everything was snug and i cant figure it out.........and ideas??? please help!!!!
Like us on Facebook!
![]() Drives: C5 corvette/ 2012Dodge hemi Charger Join Date: Oct 2010
I had that problem once. I checked everything, and found my exhuast wasnt loud enough. Once I changed out to long tube headers and mufflers that woke up the neighbors, many of my car's problems got fixed........Including the piston slap common on the early LSx cars.
#3 | |
Emerald Coast Camaros
Drives: 2012 2SS LS3 45TH Join Date: Jan 2011
I have it too! Still haven't found the cause.
Current Car: 2012 Camaro 2SS LS3 45TH Edition
![]() Drives: 2010 2ss Join Date: Jan 2012
I had the same thing with my car but on a non stock exhaust..
There was a small bolt on the passenger side around the y rubbing against the exhaust. You wont notice it unless you actually look above the exhaust.
2010 2SS Bolt On's
98 z28 - in progress.. |
Tri-County Camaros Tampa
Drives: 2011 Camaro 1SS/RS VR/BLK A6 Join Date: Jan 2011
If drivers side inside check your speedometer bezel. When the noise starts place your hand directly on top of the dash above it and press down. See if it stops. Mine did this. I removed had it painted and replaced. No more noise.
This is the best way to find rattles and such inside car. Drive where you know it will make noise then press down on everything with some pressure and see if it stops repeat to verify. Now you pinpointed where the noise is. To find exhaust rattles simply grab pipes and pull up and down or tap with a mallet to fins source of contact. |
#6 | |
3CC5 **Midnight Express**
#7 |
I just had the dealership do TSB 09-08-110-010 on mine for an inside vibration/squeak from the rear trim panel, is your squeak coming from the front or the back?
![]() SQUEEZE THROTTLE. FEEL GROUND RUMBLE |
#8 |
ITS HARD TO TELL I THINK FROM THE FRONT BUT IM NOT POSITIVE.
#9 | |
UCF Knights
#10 |
![]() Drives: 2011 2SS RS L99 Blk/Blk Join Date: Oct 2011
I had the same thing on a 2011 2 SS RS, chased it for a month or so. back to the dealer a couple time, last time one of the technicians told me he had accidently put his hand on the overhead "console" and the noise stopped, so they took it apart, tightened everything up and I have had no squeak/rattles since... EVERYONE that listened for it swore it came from the middle of the dash towards the drivers side.
Just my 2 cents
EWMAN
Evil, Wick, Mean and Nasty Carpe diem, quam minimum credula postero |
#11 |
OK WELL I PUT MY HAND ON THE DASH AND OTHER SPOTS WHEN IT MAKES THE NOISE, THE NOISE DOES NOT CHANGE WHEN I DO THAT. ALSO IF I START TAPPING OR BANGING THE DASH AND TRIM IT DOES NOT MAKE THE NOISE, ALSO WHEN I GO OVER A SPEED BUMP THE NOISE ONLY COMES FROM THE FRONT ON THE INSIDE....IDK
#12 | |
2010 2SS Bolt On's
#13 | |
...unleashing the fury!!
Drives: 2012 Inferno Orange Metallic 1SS/RS Join Date: Sep 2011
Thread title reminds me of this part of a movie:
2012 Inferno Orange Metallic 2SS/RS Engine mods: None yet Exterior mods: Heritage grille Interior mods: Hurst shifter, MTX Magnum subs w/Alpine 500w amp!! Getting there one piece at a time!! |
#14 |
So i finally found out that sqeak noise it was coming from the hood.
#15 |
![]() Drives: 2012 RS 45th Join Date: Oct 2012
Squeaking noise
How did you figure out it was the hood? and what did you do. I am having the same issue.
#16 |
![]() Drives: 2012 Black Camaro Join Date: Nov 2011
How did you find the source of the problem and how did you fix it?
| Thread Tools | |
| Clunking/clattering noise when pressing clutch - INFO HERE | DarkObsession | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 15 | 01-13-2013 02:35 PM |
| Front End Knocking Noise | Dave Sparkes | Camaro Price | Ordering | Tracking | Dealers Discussions | 4 | 04-14-2011 07:06 AM |
| OBXR Headers Installed | Smoky10 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 44 | 12-17-2010 11:01 PM |
| How Many Camaro5 members does it take to change tighten spoiler nuts | ffrcobra_65 | 5th Gen Camaro SS LS LT General Discussions | 59 | 02-17-2010 06:31 AM |
| Ontario (Canada) Highway Traffic Act.. read so you dont lose your car | sigma_1966 | Canada | 10 | 08-11-2009 05:51 PM |
