Old 04-12-2012, 09:41 AM   #1
Nutro
Nutro's Avatar
Drives: 2011 2SS Synergy Green
Which backing plate and pads?
Just bought my first PC and need to order some pads and a backing plate. I keep seeing either 5" or 6" plates and I am unsure what I need to use.
Looking on Autogeek since I have a credit with them that I need to use up.
Do I need a 6" plate and 7.5" pads?
Do I need a 5" plate and 6" pads?
2011 L99 W/ Kooks Long Tubes, Ported TB, Roto-Fab CAI, MightyMouse can, Stainless Works 3" ZL-1 Catback, Overdriven Maggie @10 Pounds boost putting down 511/535 on a conservative tune.
Nutro is offline   Reply With Quote
Old 04-12-2012, 09:48 AM   #2
Todd@Autopia
Todd@Autopia's Avatar
Drives: 2010 Mazdaspeed 3
A PC is going to generate more polishing power (which will save you time) by using a smaller diameter pad.
I would go with 5.5 inch pads and a 5 inch backing plate. You could go even smaller (down to 4 inches) but then you loose some trade off in surface area, so you might end up taking longer to do an area. The machine will also 'wobble' a little more with a smaller pad. For most polishing 5.5 inch pads give you the best possible results.
Old 04-12-2012, 10:01 AM   #3
Sir Nuke
Master of All Things
Sir Nuke's Avatar
Drives: '17 Corvette Z51 Coupe
Nutro, have you decided on who's products you are going to use?? If it were me, I would ask them what works the best for their product, and in some cases, they may have backing plates and pads made of specific materials designed for their product.
Old 04-26-2012, 02:57 PM   #4
Nutro
Nutro's Avatar
Ok so I received an order from Autopia with my Black fire and Meguiar's products now I just need to order the pads. Here is what I have in my cart for the (6) pad deal:
Pad 1: Orange
Pad 2: Orange
Pad 3: White
Pad 4: White
Pad 5: Red
Pad 6: Red
Does this look correct?
Old 04-26-2012, 04:17 PM   #5
Adam's Polishes
Adam's Polishes's Avatar
Drives: The shiny ones.
FWIW - I've always subscribed to the theory of stocking heavier on pads for fine polishing than anything else.
Waxing/glazing pads see very little abuse so they require less frequent replacment.
Heavier polishing pads shouldn't be needed too often if you're doing a good job of upkeep and swirl prevention.
So the pad that most commonly gets worked is my white pads... those are the ones I'm using for light touchup most frequently.
Take it for what its worth.
Old 04-26-2012, 04:32 PM   #6
Angelo@Autopia
Angelo@Autopia's Avatar
Drives: 2014 Ford Focus ST
Pad 1: Orange
Pad 2: Orange
Pad 3: White
Pad 4: White
Pad 5: Red
Pad 6: Red
Looks good from what you wrote, are these CCS or Smart Pads?
Old 04-26-2012, 04:36 PM   #7
Angelo@Autopia
Also if your putting on your LSP by hand you can skip the Red pads and stock up on Black pads.
Old 04-26-2012, 04:36 PM   #8
Nutro
Nutro's Avatar
Yep, these are CCS pads.
I was thinking of using the white pads for a cutting (on my 2003 GMC truck) followed by the white pad.
On my Camaro, I was looking at just using the white pads for the light cutting and swirl remover then the red pad for the sealer or glaze?
Does that seem correct?
I could always apply the sealer or glaze by hand if needed.
Old 04-26-2012, 04:39 PM   #9
Angelo@Autopia
Apply your LSP by hand and stock up on some Black pads for your final polishing.
Old 04-26-2012, 04:43 PM   #10
Angelo@Autopia
Yellow Cutting 5.5 inch Foam Pad - Use this pad to apply compounds or polishes to remove severe oxidation, swirls, and scratches. It is the most aggressive and should only be used on oxidized and older finishes. Always follow this pad with an orange or white pad and a fine polish to refine the paint until it is smooth.
Orange Cutting 5.5 inch Foam Pad - Firm, high density foam for scratch and defect removal. Use this pad with polishes and swirl removers. It’s an all around pad that will work on most light to moderate imperfections.
White Polishing 5.5 inch Foam Pad - Less dense foam formula for the application of waxes, micro-fine polishes and sealants. This pad has very light cutting power so its perfect for pre-wax cleaners.
Green Polishing/Finishing 5.5 inch Foam Pad - Use this foam to apply one-step cleaner waxes. It is a balance of polishing and finishing that is perfect for all-in-one product application.
Gray Finishing 5.5 inch Foam Pad - Composition is firm enough to withstand added pressure during final finishing to remove buffer swirls. It has no cut and will apply thin, even coats of waxes, sealants, and glazes.
Blue Finessing 5.5 inch Foam Pad – Flat pad has soft composition for applying glaze, finishing polish, sealants, and liquid waxes. Flat pad provides full contact with paint surface to minimize the pressure applied by the user.
Red Ultrasoft Wax/Sealant 5.5 inch Foam Pad - This soft, imported foam is ideal for applying the final coat of wax or sealant. The foam works especially well when applying liquid waxes or sealants because it is firm enough to keep the majority of the product on the paint, rather than soaking it up. The red foam has no cut or cleaning ability.
Go with a few of the Black/Gray Pads IMO.
Old 04-26-2012, 04:47 PM   #11
Nutro
Nutro's Avatar
Ok so let me make sure I have this right:
Orange or white pad with Meguir's 105 on my older paint ('03 GMC) since it has some swirl marks and such after many years of never being waxed/polished etc
White pad with Meguir's 105 on the Camaro (not many scratches at all) followed by a white pad with Megs 205? Or GREY pad with 205?
Blackfire Wet Diamond sealer by hand or use the GREY pad for the sealant
Carnuba by hand
Old 04-26-2012, 05:06 PM   #12
CamaroDreams07
CamaroDreams07's Avatar
Drives: Slow V6
Carnuba by hand
I haven't used those pads specifically, but I would assume based on reading that you'd want to use the Grey pad with the 205, and then a blue one, or by hand for the sealant.
[B]
Old 04-26-2012, 05:09 PM   #13
Angelo@Autopia
Carnuba by hand
Orange with M105 for compounding
White with M205 for polishing
Black with M205 for final polishing
BFWD or any LSP by hand
Old 04-26-2012, 06:08 PM   #14
Todd@Autopia
Carnuba by hand
M105 is an amazing product. You could use it with an orange pad for increased cutting action or with a white pad for a more polishing action. So that is spot on.
M205 is a finishing polish that has a little cut. It could produce a better finish with a gray pad, although a lot of times a white pad (on a porter-cable style polisher) is going to finish equally as well.
Detailing questions answered here! Moose Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 636 06-04-2011 12:27 PM
KNS Brakes - Camaro Brake Pads from Hawk, Carbotech, Ferodo, Stoptech and more. KNS Brakes Suspension / Chassis / Brakes 3 01-27-2011 09:19 AM
Adam's Gen3 Porter Cable Pad System - Now Shipping!! Adam's Polishes Wash/Wax/Detailing and Cosmetic Maintenance Parts 1 12-08-2010 01:01 PM
NEW Meguiar's 2-Pack Mirror Glaze Soft Buff 4" Foam Polishing Pads At PAC Angelo@Autopia Wash/Wax/Detailing and Cosmetic Maintenance Parts 0 04-14-2010 07:21 PM
