Emblempros
Old 05-06-2009, 06:07 PM   #1
Smokintires
Great Member
Smokintires's Avatar
Drives: 2010 Victory Red Camaro SS/RS
Talking What is the difference between a Optima Red Top and Yellow Top?
I was on http://www.optimabatteries.com/optim...wtop/index.php
and i couldn't notice the difference between the both color top batteries. Both say they are "High Performance". So tell me the difference.
Smokintires is offline   Reply With Quote
Old 05-06-2009, 06:35 PM   #2
alftinc
Drives: 2010 2LT RS Camaro
Color.
alftinc is offline   Reply With Quote
Old 05-06-2009, 06:36 PM   #3
Txturbo
Keeper of the Faith
Txturbo's Avatar
Drives: 2001 Z28 Agressively
Red Tops are higher Cold Cranking Amps and 3 year warranty, yellow tops are 1 year warranty and lower Cold Cranking Amps.
2010 Camaro SS R6P
2001 Camaro Z28
1969 Camaro SS clone
Txturbo is offline   Reply With Quote
Old 05-06-2009, 10:20 PM   #4
kdoske
Waiting For My 1SS/RS SIM
kdoske's Avatar
Drives: Sold My Lancer, now carless :/
I'm just curious because I honestly don't know, but why are people concerned with replacing the batteries in a brand new vehicle?
Is it for stereo modifications or something?
kdoske is offline   Reply With Quote
Old 05-06-2009, 10:24 PM   #5
ShnOmac
ShnOmac's Avatar
Yellow top is also a deep cycle batt.... It is made to be drained down to lower levels without a charge and then charge back up. Good for Car or audio events where you would be using juice but not running the car.
ShnOmac is offline   Reply With Quote
Old 05-06-2009, 10:26 PM   #6
ShnOmac
ShnOmac's Avatar
From optima site.....
RedTop: Use this for normal engine starting where an alternator immediately monitors the state of charge and provides energy to the battery whenever it is needed. This would describe most stock vehicles.
Automotive and RV under-hood starting
Heavy equipment where starting is the primary function
Diesel powered vehicles with no aftermarket electronics
YellowTop: Use this when electrical loads are higher than average, or when the discharge cycle is more than typical engine starting, such as vehicles without alternators. This also includes vehicles with significant electrical loads that may exceed the average alternator output (for example aftermarket audio system, GPS, chargers, winch, snowplow, inverters, drag cars). This can also include vehicles that have a lot of electronics from the factory, such as a minivan with power sliding doors and a DVD player, especially if the DVD player is used when the engine isn’t running.
Racing vehicles without a charging system (alternator or generator)
Dedicated drag racing vehicles
Diesel powered vehicles with aftermarket electronics
Car audio/video applications exceeding 250 watts over the OE system
Vehicles or heavy equipment with inverters, hydraulics, winches or other accessories
Electric vehicles
http://www.optimabatteries.com/product_support/faqs.php
Old 05-06-2009, 10:38 PM   #7
camaro5's Avatar
Drives: 2019 Louis Chevrolet Camaro
Yep.
In everyday terms...The Yellow can come back from being completely dead.
The Red, and most other batteries, cannot. They are permanently damaged with even one full-discharge.
Oh, they may work, but not as well, and not as long.
Get the Yellow.
Go from the presence of a foolish man, when thou perceivest not in him the lips of knowledge
General Motors ASEP, A.S. Automotive Technology, Telecommunications Specialist, CISCO Certified Network Engineer
STANDARD DISCLAIMER
camaro5 is furnishing this information "as is". camaro5 does not provide any warranty of the information whatsoever,
whether express, implied, or statutory, including, but not limited to,
any warranty of merchantability or fitness for a particular purpose or any warranty that the contents of the information will be error-free.
camaro5 is offline   Reply With Quote
Old 05-16-2009, 01:05 PM   #8
Smokintires
Great Member
Talking
Originally Posted by camaro5 View Post
Yep.
Get the Yellow.
Ok, So the yellow top battery is for car shows, and aftermarket electronics. It drains the battery fast, but you can recharge it and it will be fine. But I don't want to recharge the battery every year. Right?
AND the Red Top battery doesn't discharge so fast but after 1 recharge the battery is damaged. Right?
Im looking for a battery for a long lasting daily driver/ slightly modified camaro. So someone help me out.
Old 05-16-2009, 01:09 PM   #9
Bear
Bear's Avatar
Drives: 2015 Green Flash 2SS M6
Seriously?Its called a stocker. Now you have more money for useful mods.
Back in the Game.
Bear is offline   Reply With Quote
Old 05-16-2009, 01:22 PM   #10
westvanGT
westvanGT's Avatar
Drives: 2006 Mustang GT
You'd need to be running a lot of electronics to need to get the yellow top. What does the standard alternator puch in the Camaro, 130W? Thats plenty of juice unless you're putting in a huge system.
westvanGT is offline   Reply With Quote
Old 05-16-2009, 01:32 PM   #11
Gentry78
HOOK'EM
Gentry78's Avatar
Drives: 97 c1500/92 olds
red top is a starting battery meaning it puts out a big punch for the the first 5 seconds to get the car started easily, and a yellow top is a mix between a staring battery and a deep cycle, so you get starting power and the benefits of a long lasting deep cycle that can be recharged from dead many times as well as low internal resistance to power electrical components easily and more efficiently.
Gentry78 is offline   Reply With Quote
Old 05-16-2009, 04:35 PM   #12
CWI
Helping Build America
CWI's Avatar
Drives: 2010 2SS/RS,LS3 2013 Duramax 3500HD
Alternator output is measured in amperes at a given voltage, somewhere around 13.8 VDC. Watts are output power ratings on stereo amplifiers.
This is at least the second thread the OP has started on this subject. If he is just using his car as daily driver with minimal mods, The factory battery should last for years. No need to spend $100+ on a new battery just to have a "custom" battery. I will use mine till it dies, then consider a yellow or what may be on the market a couple years from now.
Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting "Holy shit, what a ride!"
CWI is offline   Reply With Quote
Old 05-16-2009, 05:23 PM   #13
Iroczlover
The Krazzy bytch
Iroczlover's Avatar
Drives: Which car I have 9 vehicles?
Send a message via MSN to Iroczlover Send a message via Yahoo to Iroczlover
Ok lets do it this way, I have a 72 buick skylark vert that is only ran during the summer months, so it sits in my garage every winter, it has a Yellow topped optima in it.
Sitting right next to it is a 71 RS/z28 camaro, which is ran about the same amount of time, that has a red top in it.
Guess which one I have less issues with?????
The yellow top one.
Both cars have similar Sound systems in them.
Thinking about going yellow all the way around.
Heart breaks everyday when you cant take care of your family because you are unemployed, cant give your family what you want or what they need
I am not a man I have boobies.
Cars are like women, If you treat her rough shes going to complain & you will hear about it. If you treat her right she will purrrrrrrrrrrrr
Current cars owned , 72 Skylark vert,86 fiero GT Sold , 87 Iroc-z (sold), 90 Vette Vert SOLD , 95 Z28, 99 Silverado K1500 Totaled, 2010 CGM Camaro 2ss/rs (had to sell & I hate it ) ,2012 Cruze LT repoed.
Current current list lol 2006 Silverado 2500hd.
Iroczlover is offline   Reply With Quote
