Jason 98 TA
Old 04-12-2012, 10:19 PM   #1
ZL1Dave
ZL1Dave's Avatar
Drives: 2012 ZL-1 #1442
Anyone got plans for headers?
Being new to the 5th gen scene and coming from a 3rd gen I'm not down on what is the good stuff for these new camaros yet. What header brands are preferred on the camaro 5? Anyone know of ones made for the ZL1 yet?
ZL1Dave is offline   Reply With Quote
Old 04-12-2012, 10:59 PM   #2
1MtnGoat
1MtnGoat's Avatar
Drives: '12 SIM ZL1, 1 of 49
On a SC engine headers will cause a loss of boost. (more effecient exhaust) The SC will need to be overdriven to compensate. The exhaust manifolds on the ZL1 are a fairly effeceint design. Headers are not your best bet for increasing power.
1MtnGoat is offline   Reply With Quote
Old 04-13-2012, 01:06 AM   #3
hognutz
hognutz's Avatar
Drives: 2013 ZL1
I like the kooks design from what I have seen for the LS3. ball and socket connection to the cats.
I think longtubes will work great as long as you get the pulley to match. This seem like a good recipe to get 600whp.
any company that puts out big power without forging the engine usually has longtubes in the mix.
2017 zl1 or GT350 hmmmm
2015 Hellcat-sold
2013 ZL1 -sold
2013 Dart
2013 Megacab 8" lift 38"mt's
hognutz is offline   Reply With Quote
Old 04-13-2012, 03:18 PM   #4
2012ZL1
CaRaHoLiC
2012ZL1's Avatar
Drives: '12 ZL1,67 Cam,68 Biscayne 427 4 sp
Headers make more power with less boost. Always a good choice. adding boost for even more power is only a 139.00 pully away...
The REAL waste of money is putting heads on a supercharged engine, especially this engine. The heads flow astronomically well as is, and blowers make even crap heads superstars.
Ehaust port work may help a little, but its easier to add more boost to make more power up to the point of piston/rod trouble in these engines.
The reason people arent too quick to suggest headers is that many headers for these models run upwards of 1100.00 or more a set.
So you see why a 139.00 pully seems like a better choice at first glance.
2012 ZL1
2.55 upper, 10" lower pullies, Innovators west billet hub and sfi balancer, solid blower drive isolator, 50 mm idler kit, full length S/S headers no cats, comp cams custom grind cam, comp roller rocker trunion kit, comp push rods,dual valve springs retainers and locks, Injector dynamics ID850 inectors, Rotofab ZL1 cold air kit, Lingenfelter 160 thermostat, Rotofab intercooler reservoir, stock plugs, LS7 90mm throttle body, GTO clutch reservoir mod, my own custom catch can, Tuning by Jannetty, install by me.
2012ZL1 is offline   Reply With Quote
Old 04-14-2012, 05:38 PM   #5
Andy@Livernois
Andy@Livernois's Avatar
Drives: 1987 Buick Regal Turbo-T
I actually must disagree with this statement that the heads flow well. These heads flow substantially less than an unported LS3 head. On our CTS-v Builds we saw typical gains in the are of 30 rwhp with lower boost, cooler IAT's and of course proper recalibration as it dramatically changed the needs of the engine. The intake port was actually more than half of the gain as our initial testing involved improved exhaust ports only.
Andy@Livernois is offline   Reply With Quote
Old 04-14-2012, 07:34 PM   #6
Pgoldston
Drives: 1999 camaro
Im new getting into the ls world, but whats the physical difference between the lsa and ls3 heads and can they be interchanged if not why?
Sorry if it seems to be a elementary question, again just new to the ls world
You can lead a horse to water but you cant force people to look at the data
Pgoldston is offline   Reply With Quote
Old 04-15-2012, 04:39 PM   #7
jay@redline-motorsports
Drives: 930
the wing in the intake port is what needs to be work for the most gain and yes we've seen the same
jay@redline-motorsports is offline   Reply With Quote
Old 04-16-2012, 04:38 PM   #8
2012ZL1
CaRaHoLiC
2012ZL1's Avatar
The OEM posted flow numbers for these heads are pretty good, so I am not sure what you are getting at..just turn up the boost. Heads are a waste of money on a supercharged engine obviously as long as they are at least half ass good to begin with.
Not disputing that gains can be made with porting, just that there are cheaper easier ways to gain hp with a blower imho.
BTW do you have flow data on a stock set of LSA ZL1 heads compared to stock LS3 heads done on the same flow bench?.
2012 ZL1
Old 04-16-2012, 06:39 PM   #9
Andy@Livernois
I can ask our cylinder head department, but I believe it was around 35 cfm less then an LS3 head.
Old 04-16-2012, 09:34 PM   #10
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Wow! That's a lot. Isn't the wing there to make the air/fuel mix better ultimately leading to greater efficiency and power? I understand the comments about a power difference but am just confused as to why GM would do this. I know the head is better, structurally, but I guess the buck stops there.
Hmmm...
05 Hummer H2 SUV on OEM Air Ride
Forged 11.4:1 408 LQ4 (K1 crank & rods; Mahle pistons)/CPP LS3 CNC heads/BTR Stage IV LS3 cam/home ported L92 intake manifold/ported 90mm TB/custom Volant CAI/Kooks 1 7/8" LTs and 3" H-pipe/AFE dual 3" CB/Corvette Servo/el cheapo lift/Cognito UCAs/Sphon poly adjustable TA/Sphon adjustable rear LCAs/e'fan conversion/DirtyMax radiator/Moroso catchcan/HPTuners/HID conversion/LED exterior lighting/LED interior accents/Autometer Cobalts/AEM WB/ Pioneer AVH-5600BHS/Pioneer GM-9601/2-Pioneer TS-W310D4s/Obcon Labyrinth dual-12 box/lots of other little stuff
Old 04-16-2012, 09:44 PM   #11
rjdapilmoto
DAP-ONE [COTW - 12/23/13]
rjdapilmoto's Avatar
Drives: 2010 - 2SS/RS IOM
I've had my ARH long tubes since August 2011 and love 'em!!
rjdapilmoto is offline   Reply With Quote
Old 04-19-2012, 08:37 AM   #12
Stainless Works
Stainless Works's Avatar
Drives: Fast
Stainless Works should have a ZL1 here at the shop very soon to verify header fitment, stay tuned!
Stainless Works is offline   Reply With Quote
Old 04-30-2012, 05:01 PM   #13
ZL WON
ZL WON's Avatar
Drives: too many to list
I'm putting the ARH headers and x-pipe on my car in a couple of days. I'm the ARH Guinea pig
ZL WON is offline   Reply With Quote
Old 04-30-2012, 07:34 PM   #14
2012ZL1
CaRaHoLiC
2012ZL1's Avatar
Why would Chevrolet put crappier heads on a ZL1 than on an LS3?...doesn't make sense at all....
2012 ZL1
Plans for July 4th weekend? Mindz USA - California 100 07-07-2011 01:38 AM
Backup Plans The_Blur General Automotive + Other Cars Discussion 22 01-11-2009 03:59 PM
Hyundai Assurance Muscle Master General Automotive + Other Cars Discussion 18 01-05-2009 09:00 PM
Possible camaro future plans? logan1080 5th Gen Camaro SS LS LT General Discussions 23 08-27-2008 01:02 AM
GM To Unveil Future Business Plans On Tuesday Mr. Wyndham General Automotive + Other Cars Discussion 5 06-03-2008 10:02 AM
