Old 04-14-2012, 09:05 PM   #29
Quackersacker
Quackersacker's Avatar
Drives: 2011 Camaro Convertible SS
Jeff if you could please check my VIN I would appreciate it. 2G1FK3DJ6B9199405 Thanks in advance.
Quackersacker is offline   Reply With Quote
Old 04-14-2012, 09:52 PM   #30
zandron263
zandron263's Avatar
Drives: 2011 2LT RS IOM Convertible
Thanks for the info Jeff. I need to get an oil change soon so I will call my dealer and schedule an appointment for both.
zandron263 is offline   Reply With Quote
Old 04-14-2012, 09:54 PM   #31
SCullen
Converts Oxygen to CO2
SCullen's Avatar
Drives: 2016 Black SS Convertable
I had mine into the dealer this morning for an oil change and I asked if my vehicle was covered. It is and they will order parts on monday.
BTW he called it an "enhancement".
2016 Black 2SS Vert A8 MRC NPP
SCullen is offline   Reply With Quote
Old 04-14-2012, 10:49 PM   #32
theragtopguy
Lifetime Philly Fan
theragtopguy's Avatar
Drives: 2015 Spring Edition 2SS M-6
Thanks Jeff!! I'll be in contact with my dealer on Monday!
Phillies Baseball, Hot Dogs, Apple Pie and Chevrolet!!!!
2015 Green Flash, Delivered 4/10/15
CAI, NPP Exhaust, Short-throw shifter
One of 82 GF Ragtops built in '15 out of 811 Total
Member of SEPA5+
theragtopguy is offline   Reply With Quote
Old 04-14-2012, 11:52 PM   #33
alaird65
alaird65's Avatar
Drives: 2012 Camaro 2SS/RS Convertible-RED
Send a message via AIM to alaird65
2G1FK3DJXC9100456
ALAIRD65
alaird65 is offline   Reply With Quote
Old 04-15-2012, 12:12 AM   #34
Wrbrackett
Drives: 2011 camero
Can you check my vin? Thank you
Hi there
I'm about to pull the trigger on this 2011 left over camaro convert 2ss.any chance you could let me know if this car is included in the recall?
2G1FK3DJ0B9205537
Should my dealer do it before I buy it?
Thank you for your time and help bill
Wrbrackett is offline   Reply With Quote
Old 04-15-2012, 04:15 AM   #35
cactuseater
Drives: .
Originally Posted by Chevrolet Customer Svc View Post
To Cactuseater, we don't keep information like what you're asking. Unfortunately you would have to ask around about this. Every Chevrolet dealer in the country should be able to take care of this type of issue for you and any GM dealer should be able to handle warranty repairs on any other GM vehicle. If you're having troubles with getting this taken care of then I would say changing dealers would be a good idea. The We Owe slip from your original dealer shouldn't matter in this case as your vehicle would be covered under this program any way and should be preformed regardless of the slip. If you're not sure if your vehicle is part of this program either post it here or message me your VIN and I'll check it over and get it back to you as soon as I can. Zandron, your vehicle is involved in this program. Hopefully you can get your vehicle to your dealer soon and get this resolved. Have a good weekend guys and galls!
Jeff Morris, Chevrolet Customer Service
Understood and thank you for your replies. Our VIN: 2G1FK3DJ3B9180603
We'll start asking around locally to see if any of these have been done in the greater Phoenix area. With the hole in the top right between the rub marks on the passenger side it's going to be a new replacement top and the TSB fixes. I am hoping the TSB fixes will hold up. Best Regards.....
cactuseater is offline   Reply With Quote
Old 04-15-2012, 06:49 AM   #36
'11 cyber grey vert
"SHARK" Born Apr.26,2011
'11 cyber grey vert's Avatar
Drives: 2011 CGM 2LT/RS Convertible
Cactuseater,
through my own experience with my 5th bow broken,There are not alot of GM dealers around where I am anyway with top experience.GM has not made convertible tops consistently in their vehicle line up with the exception of the corvettes.
What I did was zero in on the big corvette dealers and asked questions re: camaro tops.
My selling dealer which is about an hour away from me is one of the only ones that have experience repairing the camaro tops.they are also one of canada's largest corvette dealers if not the largest.
They also are in a select group that knew what to look for with regards to top problems.
I asked most of the questions with the service manager, he is definitely on the ball and knew his stuff.
All the questions I asked he was able to answer so I felt comfortable that they would be able to fix it and absolutely did not give me the runaround that you are going through right now with your dealer.
You would be surprised (maybe not) by the number of dealers here that have verts on their lots with broken or crappy tops and are trying to sell them in that condition as they have no idea what to look for.Again I think it comes down to the fact that GM has not produced convertible tops consistently through a particle model line(corvette excepted) and therefore the dealers don't have enough experience when issues arise.
'11 cyber grey vert is offline   Reply With Quote
Old 04-15-2012, 08:02 AM   #37
evilive1138
Drives: 2012 Black 2SS RS Convertible
Jeff
Thanks for all your help with these issues. Can you check my VIN as well? I have rub marks, so I'm guessing (hoping) it will fall under the program.
2G1FT3DW5C9106772
evilive1138 is offline   Reply With Quote
Old 04-15-2012, 09:29 AM   #38
kirstie4422
kirstie4422's Avatar
Drives: 2011 Camaro Convertible 1LT RS
Hi Jeff thanks for all your support! Can you check my vin 2G1FB3DD1B9192615.
kirstie4422 is offline   Reply With Quote
Old 04-15-2012, 09:39 AM   #39
Lonewolf
Lonewolf's Avatar
Drives: 2011 SS/RS IOM Vert
Originally Posted by zandron263 View Post
Jeff my vin is 2G1FC3DD4B9156933 I only have very slight rub marks but I would like to have it fixed before they become a big problem. Could you let me know if min is included, thanks.
Same here. VIN 2G1FK3DJ389210649
Lonewolf is offline   Reply With Quote
Old 04-15-2012, 01:33 PM   #40
whidobie
whidobie's Avatar
Drives: 2011 Camaro Convertible 2SS RS
Picked up my car on Friday after the repair of the 5th Bow and the so called fix for the cars that are included by vin number. So far so good but i had the car for a year before the problem started so time will tell!
whidobie is offline   Reply With Quote
Old 04-15-2012, 01:59 PM   #41
'11 cyber grey vert
Whidobie,
good luck!!!
I am in the same boat as you.After 5th bow replacement, so far so good and 100% agree that time will tell.so here's to keeping fingers crossed that problem is solved.
Old 04-15-2012, 10:23 PM   #42
Roll_the_Dice
Roll_the_Dice's Avatar
Drives: 2012 Summit White Camaro 2LT
Jeff, my VIN is
2G1FG3D34C9162728
Thanks for checking... have had her for 2 weeks.
Roll_the_Dice is offline   Reply With Quote
What a joke about top quality!! 95birdible Camaro Convertible Forum 68 10-06-2011 09:42 AM
Convertible top leaking gtoimpulse Camaro Convertible Forum 2 08-10-2011 09:44 PM
hard top convertible? MrandMrsNinja 5th Gen Camaro SS LS LT General Discussions 32 03-28-2011 09:04 PM
THE NEW YORK TIMES reviews Camaro convertible AND says Z28 will follow ZL1 camaro5 Camaro Convertible Forum 12 02-21-2011 10:42 AM
Camaro Convertible First Drive Review by Jalopnik nick at night Camaro Convertible Forum 18 01-31-2011 08:23 AM
