BeckyD @ James Martin Chevy
Old 04-13-2012, 11:53 AM   #1
Fragnarok
Gavin
Fragnarok's Avatar
Drives: 2010 Camaro 2SS RS Inferno Orange
What's your detailing routine?
What do you do to keep your ride shiny? Are you a daily detailer or a occasional autowasher? What do you use?
Fragnarok is offline   Reply With Quote
Old 04-13-2012, 11:58 AM   #2
woodj
woodj's Avatar
Drives: 2SS/RS RJT Vert
There's a whole sub-forum on this subject. It's under the Cosmetic Maintenance etc. sub-forum. I'm sure this will be moved over there.
K&N Typhoon CAI, Flowmaster Outlaw axle backs, Vertini 20" Wheels, Sparks Restorations SS Emblems, GM Wind Restrictor, Splash Guards
woodj is offline   Reply With Quote
Old 04-13-2012, 12:23 PM   #3
ctk1
Camarofanatic
Drives: 1969 SS, 1998 RS, 2010 VR 2SS/RS
I have detailing OCD! My car is only driven in sunny weather, and if I only drive it a few hours it gets dusted off, spray detailed and covered back up in the garage when done. If the car is too dusty to use the California car duster on then it gets washed, spray detailed and covered. It also gets the full Adam's treatment at least 2-3 times per summer. I can't stand seeing my baby even dusty!
2010 Victory Red R6P 2SS w/RS package. Gloss black Rallys, 6 speed manual, SLP Loudmouth I exhaust, LS7 style blackout panel, SS emblems front and rear, Custom 69 inspired headlight covers, Vararam no tune, Hurst Short Throw, and MTI Racing rear spoiler, SLP Front Splitter, ZL1 Side Skirts
ctk1 is offline   Reply With Quote
Old 04-13-2012, 12:27 PM   #4
1BADLS3
1BADLS3's Avatar
Drives: Sold: 2011 2SS/RS
3...2...till this gets moved to the detailing forum...
I wash. With a big bucket of water, a cotton wash mit, carwash soap. Top to bottom, front to back, and if the car is really dirty I'll pop the doors and wash the rocker sills and where it meets the quarter panel. I hit the wheels and exhaust tips with simple green and clean them up with a separate wish mitt. To dry, I squeegee with a water blade and then touch up with an Absorber.
Once or twice/year I'll fully detail the car. I've got a pressure washer. I open up the doors, hood, etc and hit all the jambs, engine bay, fender wells, wheels, underside of the hood, cowl, gas door, etc with simple green. If it's really dirty, I'll work it in with a brush around technical spots. Let it soak for a minute while I fire up the pressure washer. I blast it all. Then I button the car back up, hit the exterior with a pressure washer. Then I hand wash the car as mentioned above. Pressure-rinse. Then, clay. Another quick once-over and rinse. Dry as mentioned above, except I use an air compressor to blow out the gaps and common 'drip' spots, jambs, etc so I can wax it without soaking a wax pad. I haven't had an older car in a while, so usually just a hand wax is fine. No cutting or polishing necessary, just wax.
The interior gets its cracks blown out with the air compressor, same with the seats, then the hard surfaces and seats wiped down, carpets vacuumed, the leather surfaces cleaned and conditioned with Lexol, the plastic gauges and radio face get wiped down with a MF cloth that's got a bit of wax on it to keep the surfaces from scratching, same with HUD. Windows get cleaned with newspaper.
I go back and clean up any missed spots, or residual water on the underside of the hood, engine bay, etc with a wet rag.
Takes me 2-3 hours total, I'll usually start in the morning and finish up well before lunch so I can enjoy the rest of the day and a clean car. If I'm going crazy, I'll hit the tires with tire shine, but on the whole I don't like to do that for environmental reasons. If I need to touch up the tires, honestly, a stiff scrubbing in the wash process followed up by using a bit of cheap leather conditioner when the car is all done gives them a very nice matte-black finish just like new with no overspray or fling on adjacent panels.
All the mitts/rags get washed after I'm done. And since I'm paying attention to the car anyhow I'll check all the fluids, tire pressure BEFORE I do the process so I don't have little fingerprints on everything.
Edit: FYI, I'm not a product whore. Simple Green is the only name brand product that I really like. Wax--I go with pure caranauba, no petroleum distillates EVER, the brand varies depending on what I buy, but I think Mother's is probably the most readily available. I also use their claybars, which are ridiculously small, so I bought two and smashed them together. I keep it in a glass mason jar when it's not in use, and before I use it, I knead it real well so it's warmed up and soft. When I've had to "cut" before, I used Meguiars scratch-X or whatever it was, by hand. Not advisable to use that crap unless you've got and know how to use a buffer. Light cutting agents available at an autobody supply store are MUCH better, and if the Camaro ever gets real bad with swirls, etc, that's what I'll go buy. But with good care I don't ever see having to cut the clearcoat for a very long time. My wash mitts are whatever's on sale and doesn't pull apart. I prefer chenile cotton to synthetic as synthetic mitts tend to leave light scratches. Hand waxing...I do a panel at a time, let the wax haze over, and then wipe with a microfiber cloth. *your hands shouldn't get tired*.
1BADLS3 is offline   Reply With Quote
Adam's Vol 7 Instructional Videos are Now Online! Adam's Polishes Wash/Wax/Detailing and Cosmetic Maintenance Parts 0 04-01-2011 07:45 PM
Detailing Your New Camaro Uncle Harvey Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 45 11-17-2010 10:52 AM
NEW Porter Cable 7424XP RV/Marine Detailing Machine At ProperAutoCare.com Angelo@Autopia Wash/Wax/Detailing and Cosmetic Maintenance Parts 0 04-15-2010 12:01 PM
Detailing around Houston, TX Big Turkey USA - Texas 8 04-07-2010 02:22 PM
Glimmer-Glass Detailing - new owner intro Chris@glimmerglass Wash/Wax/Detailing and Cosmetic Maintenance Parts 1 12-13-2009 03:23 PM
