Solo Performance
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Garage / Tools Discussions
Old 04-13-2012, 09:56 PM   #1
Cynthius
Cynthius's Avatar
Drives: '11 2LT/RS (M6) & '85 Toyota MR2
Left my Torque Wrench Set...
I know, I know... I should have released it before storing. The damn thing went all Winter set for 76ft/lbs (for my wife's Yaris). I know this will throw off alignment or calibration or whatever, but my question is... will it be significant? Like the only thing I use the tool for is wheels (swapping Winters in and out and break jobs mostly). So that being said... if it's likely only thrown off by a could ft/lbs, it seems kinda negligible for my purposes since I don't need it to be accurate to a tenth or hundredth.
Any thoughts? Am I ok as is or should I pick up a new one? Wish I knew someone with another one so that I could compare.
Cynthius is offline   Reply With Quote
Old 04-14-2012, 08:40 AM   #2
Go Fast Kid
Drives: Camaro 2010 SS LS7 427ci
If it is a Snap-on torque wrench your dealer to recalibrate it for no charge.
Go Fast Kid is offline   Reply With Quote
Old 04-14-2012, 09:52 AM   #3
jeffny09
jeffny09's Avatar
Drives: 2010 camaro
Send a message via AIM to jeffny09 Send a message via Yahoo to jeffny09
why woul it be ruined if you l;eft it at76 lbs? do u have to set it at zero when ev er your done with it?
top 10 reason why real men drive stick.
10. A manual transmission is the ultimate in control
9. You can use automotive jargon and not sound like a total tool
8. You can't spell "manual" without "man"
7. Manual transmissions prove you can do more than one thing at a time
6. You can't drift in an auto
5. You can't pull fancy moves in an automatic
4. You get better fuel economy with a stick
3. You’ll never look like a chump if you can drive stick
2. Manual transmission cars are faster
1. Women like a guy who is good with his hands.
jeffny09 is offline   Reply With Quote
Old 04-14-2012, 09:59 AM   #4
jdcvictory11
Sonja
jdcvictory11's Avatar
Drives: '11 LT/RS, '95 Camaro Conv.
It could lose tension if not set to the lowest setting. If you get it calibrated, I bet it would be slightly less accurate. Also if it is dropped, it could fail all together. I am a tool account manager for the Air Force and we have some strict rules. Just sayin
jdcvictory11 is offline   Reply With Quote
Old 04-14-2012, 11:33 AM   #5
Cynthius
Cynthius's Avatar
Thanks guys, didn't think this would be something covered by warranty. This is the one I've got: http://www.canadiantire.ca/AST/brows....jsp?locale=en
Says there's a lifetime warranty so I'll look into that. In the meantime I'm thinking it's close enough to accurate for the purposes of putting my Summer tires back on safely until I can re-check with a more trusted tool?
Edit: Shit, calibration warranty is only 90 days... :(
Old 04-14-2012, 11:50 AM   #6
The Stig
knows 2 facts about ducks
The Stig's Avatar
I'd torque them an extra 5 lbs/ft just to be safe.
Click to view my build thread
Old 04-14-2012, 01:21 PM   #7
Cynthius
Cynthius's Avatar
Good call, and pretty much what I did. At first I did 140ft/lb but ran into:
http://camaro5.com/forums/showthread.php?t=216186 (post number 15)
Then tried it at 143 in case it had any bearing on the issue...
Old 04-14-2012, 01:23 PM   #8
SC2150
All torque wrenches should ALWAYS be set to zero after each use...
Dynatech Supermaxx Headers w/ Cats--1 set left in stock, special install price!! Torchdvette V8 Bolt-Ons & Tunes 0 08-29-2009 03:51 PM
