Old 04-13-2012, 10:56 PM   #1
avacamaro
avacamaro
avacamaro's Avatar
Drives: 2016 silver SS
Engine turns over slow
Like the title says. The dealer checked the battery and said it cked fine but admitted that it turned over kinda slow. Should I be worried? I bought the 2ss/rs used w/4k miles on it. Anybody else have this problem or is it normal?
I have had a ls1,ls2,ls7 and none of these turned over slow.
avacamaro is offline   Reply With Quote
Old 04-14-2012, 12:36 AM   #2
cajun1le
The Mechanic
cajun1le's Avatar
Drives: a sports car
You can pass by to a trusted auto parts store and have them load test the battery. Alternatively, if you have a amp clamp you can test the amp load between your starter and another. If there is issue with either the field or armature windings, it will show up as a increase or decrease in current(amps). The result of the test will determine if the issue is a short or break with the windings/brushes.
cajun1le is offline   Reply With Quote
Old 04-14-2012, 07:17 AM   #3
avacamaro
avacamaro
avacamaro's Avatar
Thanks,
I will try it today.
Roto-Fab | Cold Air Intakes | Engine Covers | Washer Reservoir Relocation Kit | Fuse+ AutoAgenda V8 Bolt-Ons & Tunes 7 07-11-2011 07:50 PM
Acronyms? KEEP RT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 20 03-11-2011 09:57 PM
LS3 engine specifications Tran Wiki 3 10-06-2010 11:56 PM
Why i think you cant do a Dyno in the same day 2SSRS@Gen5diy Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 123 10-22-2009 08:37 PM
L99 engine specifications Tran Wiki 0 10-19-2008 12:40 PM
