Jason 98 TA
Old 04-14-2012, 01:26 PM   #1
mikey1107
mikey1107's Avatar
Drives: 2012 ZL1
Pedders work with FE5 rear bar?
I am wanting to convert my rear sway bar and rear lower control arms to FE5 ZL1 but I have seen some people say that it can not be done with coil overs installed. Is this correct?
2017 SW SS 1LE
2012 AGM ZL1 M6 #574-SOLD
2010 SW 1SS/RS-SOLD
mikey1107 is offline   Reply With Quote
Old 04-14-2012, 05:24 PM   #2
L99CAMA2011
L99CAMA2011's Avatar
Only KW variant 3 coilovers or Clubsports with welded on reservoir is in the way of the newer endlink. Coilovers without external reservoirs would not be an issue. Supercars, BC ER series also should work I hope haven't looked into that yet. FE4/5 rear swaybar setup is way better than FE3, DO it, DO it.
Old 04-16-2012, 02:34 PM   #3
mikey1107
mikey1107's Avatar
Drives: 2012 ZL1
Cool,thanks! Parts are ordered!
2017 SW SS 1LE
2010 SW 1SS/RS-SOLD
Old 04-16-2012, 02:47 PM   #4
garcmol
garcmol's Avatar
It will work!!
The new 32mm bar takes up space, but there are ZERO clearance issues.
Old 04-16-2012, 03:07 PM   #5
sting808
Drives: 2010 SS RS
Garcmol, What size rear wheels are you running?
sting808 is offline   Reply With Quote
Old 04-16-2012, 03:12 PM   #6
garcmol
garcmol's Avatar
That's not my car. They're two different cars. Both 2SS with the stock P Zeros. I have Pedders coilovers but haven't gone to this bar yet.
Old 04-16-2012, 11:46 PM   #7
600hp-lpe
Drives: 2010
The Pedders ZL-1 swaybar will clear the Pedders Supercar reservoirs. I bolted my rear ZL-1 swaybar in place yesterday. Only thing I had to do to clear is re-position the reservoir and slightly turn the reaservoir mounting bracket so there was enough clearance for all the parts.
Addition: I forgot to mention that I am making my own endlinks. I need the endlink to clear my 18" race tires, and the poly bushing/bolt below the Lower control arm will not clear. I am modifying my LCA's using a rod end and the EP098 kit to build the endlinks.
I am doing most of the fabricating this weekend and will have pictures afterwards.
600hp-lpe is offline   Reply With Quote
Camaro ZL1 Photos / Videos Mega Compilation Thread Tran Camaro ZL1 Forum - ZL1 Specific Topics 173 04-07-2012 02:57 PM
pfadt and pedders coilovers bmbbl be Suspension / Brakes / Chassis 47 02-14-2011 05:50 PM
Better Handling Tbanks Suspension / Brakes / Chassis 30 12-15-2010 12:50 PM
Hotchkis versus Pfadt Sway Bars Avalnch Suspension / Brakes / Chassis 77 10-08-2010 11:37 AM
Where are Pedders coilovers made? g-townmach Suspension / Brakes / Chassis 69 05-03-2010 01:44 PM
